Old 04-12-2008, 07:43 AM   #991
Send a message via Yahoo to windellmc
I think the OS .28 case is stronger than the .21 which can break in bad crashes.
MP9 tki4
Truggy?
windellmc is offline   Reply With Quote
Old 04-12-2008, 08:00 AM   #992
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
When I last checked, the Speed and new OS ninja had the same big bore, short stroke displacement. A .28 case would just need a smaller bore to remain the same. And yes the VSpec should be the same bore and stroke also. As for the Sirio, its cheaper for me than the OS Ninja right now.
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Old 04-12-2008, 05:04 PM   #993
tmperformance1's Avatar
Send a message via Yahoo to tmperformance1
they were after case VOLUME, thats why the .28 case. saved time and money .
Mugen Seiki,Sidewinder Fuels,Airtronics,O.S.Engines,AKA Products,Ascendency Racing clutches,Fastlane Graphix,TKO,IDRC,M2C RACING
tmperformance1 is offline   Reply With Quote
Old 04-13-2008, 02:57 AM   #994
PACE's Avatar
Our Mugen factory driver here in Australia (Wayne Walker) has been running the new JX engines for a few months now. I've seen these things go and their weapons! Wayne said to me that their alot more powerful then the old ninja MRT's. I just picked up a my new JX with pipe and the finish is very good! The new pipes are very large! I cant wait to run it in. Also the motor isn't heavier because of the .28 block. I weighed the motor against a sirio and Picco and its lighter! Wayne also recommends the long header. It increases bottom end with no effect to the top.
PACE is offline   Reply With Quote
Old 04-14-2008, 12:32 AM   #995
n.e.r.d's Avatar
Hi PACE,
juz wondering, did Wayne use the C-shaped or U-shaped manifold?
my LHS has the U-shaped one only.
apparently he heard from Kenji Osaka that the U-shaped manifold gives more bottom end to mid whereas the C-shaped one has a smoother powerband and more top-end..
and all the Japanese Mugen drivers are using the U-shaped manifold only..
btw, tell Wayne that Andrew from Singapore sends his regards!
I'm a close friend of Andrew and I also met Wayne at Mugen Cup in Pattaya last year..
n.e.r.d is offline   Reply With Quote
Old 04-14-2008, 04:33 AM   #996
PACE's Avatar
Originally Posted by n.e.r.d View Post
Hi PACE,
Hi Mate.
Wayne told me he only uses the C-shaped manifold. He tried the other one but it took bottom end away and didn't seem to give anymore top.
Me and Wayne do alot of racing together in Australia. His a great guy and also loves to help you. We have our national titles here in 2 weeks. It'll be my first meeting with the new JX so i'll let everyone know how it goes. So far Wayne seems very pleased with them so im sure it'll be a power house.
Oh and i told wayne about your friend Andrew. He remembers giving him his setup after the final.
Cheers
Old 04-14-2008, 05:09 PM   #997
ask wayne if has an old msr 1005. try it same bottom and topend pulls to infinty.
Old 04-14-2008, 05:17 PM   #998
ezveedub's Avatar
How is this pipe? I heard some say it awesome and some say it was the worse. I have seen a newer pipe. I think it was a MSR 1001 on a Nova 21-7BT JP black and it had very good power from bottom to top. I could be wrong and it may have been the 1005.
Old 04-17-2008, 11:55 AM   #999
Starter box's Avatar
Hi,
What clutch bearings do you guys use on the stock Mugen clutch (ceramic or regular; metal-/rubber-sealed or dual shield)?
How do you treat them (oil, grease, none)?
The stock Mugen clutch bearings are five times the price of ProTek (A Main) or Advantage (Carolinas), but I think the Mugen ones hold up quite a bit.
Thanks a lot,
Frank
Starter box is offline   Reply With Quote
Old 04-17-2008, 12:28 PM   #1000
jaylude22's Avatar
Trader Rating: 93 (99%+)
I use Protek metal shielded bearings for the clutch. I use them until they fail, or until a Main race, whichever comes first. 99% of the time, it's the main that comes first. I just throw them away and put new ones in.
jaylude22 is offline   Reply With Quote
Old 04-17-2008, 12:42 PM   #1001
GREGORY!'s Avatar
hi!can someone post a complete set up for the mbx5r?i run in medium track,with medium traction and medium surface.any help please!
GREGORY! is offline   Reply With Quote
Old 04-17-2008, 06:17 PM   #1002
Slippery's Avatar
Originally Posted by Starter box View Post
Hi,
Thanks a lot,
Frank
Agree with this one cheapest bearing you can get and change them often , especially before a big main don't think it matters as the amount of alloy coming off shoes etc will get into any bearing as well as the heat pretty much cooks them as well
Slippery is offline   Reply With Quote
Old 04-17-2008, 06:27 PM   #1003
Turbine_au's Avatar
The mugen clutch bearing last forever with no maintenance. I had around 10L on a set without changing them and I could still put them back in now.
It's mine: http://au.youtube.com/watch?v=usYhSWbmx6s
Turbine_au is offline   Reply With Quote
Old 04-17-2008, 06:44 PM   #1004
Integra's Avatar
Bearings that SPIN FOREVER and feel Uber smooth are ushally on there last legs...A little heat and Guarenteed they will grenade....at 1$ a peice i dont see why guys make such a big deal about swapping them out....i Would only HOPE u guys are maintaining ur clutch's throughout these 2-3-4+ gallons some guys "claim" to get on there bearings.
Old 04-18-2008, 05:59 AM   #1005
OBMIT's Avatar
Hey Guys
If you are after bearings give this Guy a try. He has just started to stock bearings.
http://www.plaig.com.au/store/produc...roducts_id=318
He is a really good friend of mine and his service is of a very high standard. feel free to contact him to get a price and shipping.
Regards
Tim Nicol (obmit)
Tell him I sent you...
www.timnicolphotography.com.au
811 Cobra - Ninja - Ace - Spektrum
Plaig RC Bearings
OBMIT is offline   Reply With Quote
MUGEN MBX5R and (THREE) MUGEN MBX5T PROSPECS F/S or F/T nobike R/C Items: For Sale/Trade 11 02-12-2008 11:49 AM
MUGEN MBX5R F/S tshaec5r R/C Items: For Sale/Trade 25 01-14-2008 07:17 AM
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 09:32 AM
Mugen MBX5R Brand New Mugen Hops Ups and More bretzkej R/C Items: For Sale/Trade 8 05-27-2007 05:57 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 06:45 PM
