Old 03-17-2008, 03:13 PM   #901
rezenclowd3's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rezenclowd3
Flip the piece that the rods thread into.
OOMSGFX.COM (no longer painting, but take a look for fun!), Roadrunners RC Club
"Racing drivers have balls, unfortunately, none of them are crystal" (David Coulthard)
"I believe the average IQ of a NASCAR fan is only marginally above the things that hit the windscreen during the race. "
rezenclowd3 is offline   Reply With Quote
Old 03-17-2008, 04:22 PM   #902
FrankBlack's Avatar
Originally Posted by savagebeing View Post
I was having severe tuning issues this past weekend. Pulled that tank from my 5R, and it the stonefilter is also rattling, but has not come loose yet. I could not get my engine to tune for the life of me.
Do I need a new tank? Or is there a way tighten the stonefilter in place? It seems to move up, and down about a 1/4 inch.
Thanks Sean.
As for the Mugen clutch springs, there is a bad batch out there, and has been for a few months. I have read several different threads about broken Mugen Clutch Springs. I would p/u a different brand, as stay away from the Mugens for a few more months.
I emailed mugen and asked them about it, they just told me to replace the tank asap, was sought of expecting a "we will send you a new tank" but no
FrankBlack is offline   Reply With Quote
Old 03-17-2008, 04:24 PM   #903
Turbine_au's Avatar
The threaded part when the brake linkages attach to the horn should sit inside the horn, not outside.
It's mine: http://au.youtube.com/watch?v=usYhSWbmx6s
Turbine_au is offline   Reply With Quote
Old 03-17-2008, 04:48 PM   #904
Trader Rating: 24 (100%+)
Yes flip the plastic pieces that the brake rod threads in to, you need very little travel to actuate the brakes plus the angle will be a lot better for the servo.
Jeff Ford is offline   Reply With Quote
Old 03-17-2008, 05:11 PM   #905
Guess it's time to p/u a new tank.
savagebeing is offline   Reply With Quote
Old 03-17-2008, 06:04 PM   #906
MBX5TR's Avatar
Originally Posted by ezveedub View Post
Thats issue was going around a few month back. Maybe try the Ofna springs. I believe they are the same size.
Oh, I try gluing those brake pads to the brake plates for a change!?!?
Thanks bro for sure they'll be glued next time you see them jajajajaja
Ricardo Jordao Desoto Racing, Serpent, Picco, AKA, EZ Customs, RC Addiction Products.
MBX5TR is offline   Reply With Quote
Old 03-17-2008, 06:18 PM   #907
Slippery's Avatar
Originally Posted by Starter box View Post
Hi Guys,
I am building an MBX5R.
I use an Airtronics 94357 throttle/brake servo with the stock Airtronics servo horn. The fuel tubing on the rod is 10mm long.
With this setup, when going approx. half throttle, the lower brake rod is _very_ close to the spur gear and the splash guard/tank (see attached pix). So close that the collar almost touches the spur gear or the tank.
I am building according to specs and my setup matches Mugen's pictures of a built car. However, I feel that the collar might be to close to the spur gear/tank, so that it could get caught.
Is that amount of little clearance normal?
Thanks for your feedback,
Frank
It is a tricky set-up to get the brakes right , i don't run that much fuel tube only about 5mm for the top link and 3mm for the bottom and once i am happy with the set-up i remove any excess from the back of the rods .
Looking at my bottom rod it is about 2mm from spur gear and i have moved the lever forward 1mm to give the extra clearance , hope the pics help
Attachment 321192
Attachment 321193
Attachment 321194
Slippery is offline   Reply With Quote
Old 03-17-2008, 06:26 PM   #908
hi, does anyone know what it takes to converty an MSR back to buggy form?
lanerbrainer205 is offline   Reply With Quote
Old 03-17-2008, 07:14 PM   #909
TonysScrews's Avatar
Frank,
The angle of your brake rods looks pretty extreme to me. I never had an issue with them on my MBX5, MBX5 Prospec, MSR, MBX5T and MBX5R so I think you just need to play around with it a bit more. If the splash guard gets in the way, you can always shave a bit off, just make sure the rod isn;t hitting the tank.
Tony P.
Tonys Screws LLC
http://www.tonysscrews.com
High Grade Alloy Steel Screws, Screw Kits and Mugen Parts
TonysScrews is offline   Reply With Quote
Old 03-17-2008, 09:45 PM   #910
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
As for the brake rods, you can adjust the lower lever on the center diff forward a bit, but I would try like what someone said earlier and flip the brake pivots over (the end the rods thread into) so the rods thread on the inside of the bolt holding it to the horn. Also make sure the collar ends have the set screws postioned up, so the don't catch or rub the tank, tank guard or spur. The Mugen settings for the brake levers can be a bit off depending on the servo horn you use, so adjust the center diff braqke levers so the rods clear withoout any binding oor touching anything. I personally use Kyosho MP777 throttle/brake linkage. It uses springs and cones to hold the rods centered in the brake levers, instead of fuel tubing, so they don't flop around as much. It also pivots smoother than the Mugen linkage unless you drill out the horn and top brake pivot attached to the servo horn.
The pics attached show my linkage, but the Kyosho ones. As close as they look like touching the spur and tank, they actually clear. Just make to operate the linkage and make sure.
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Old 03-18-2008, 09:50 AM   #911
Tech Legend
Cain's Avatar
Trader Rating: 233 (100%+)
Hey guys,
What is the difference between the MBX5R shocks and the MBX5 shocks size wise? I am not sure what each of them are, and I am trying to decide if I should get an MBX5R car and use it, or, just keep rocking with the MBX5 I have that has some R parts on it, other than shocks and the like.
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Old 03-18-2008, 10:18 AM   #912
I believe the 5R shocks are longer to increase the downtravel of the buddy.
Old 03-18-2008, 10:34 AM   #913
Integra's Avatar
the 5R shocks use the 5T shafts....also the 5R has the different tower's...and liek savagebeing said u get more uptravel in the suspension....there's Lots more to the 5R then Just the shocks tho....the whole front end has is different from what i can tell....and GoooD racin last weekend buddy....I had a Blast.
Old 03-18-2008, 11:42 AM   #914
ezveedub's Avatar
Just to add to the R and T shocks. They are both the same EXCEPT for the pistons. T's run 1.4 hole and R's run 1.5 hole pistons. Also the ackerman, steering ass'y and tire rods are different. The knuckles and arms are reshaped for the longer suspension travel. Also the front kick plate was changed.
I would add the front kickup, ackerman and steering to a MBX5 for now. The longer shocks do help, but you can hold off and run the MBX5 just fine as is.
Old 03-18-2008, 12:07 PM   #915
Tech Legend
Cain's Avatar
If you meant me, racing was fun last weekend. Drive wasn't too bad getting there either. Just need to increase tire selection so not as much wheel slippage, that I think really caused me to dump way early.
So, for the 5R shocks, are the bodies any wider than the standard MBX5 shocks? Sounds like its just a longer shot shaft, and I am assuming longer shock bodies pretty much.
Wonder if it woudl be better if I decided to go with a different brand of big bore shock?
MUGEN MBX5R and (THREE) MUGEN MBX5T PROSPECS F/S or F/T nobike R/C Items: For Sale/Trade 11 02-12-2008 11:49 AM
MUGEN MBX5R F/S tshaec5r R/C Items: For Sale/Trade 25 01-14-2008 07:17 AM
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 09:32 AM
Mugen MBX5R Brand New Mugen Hops Ups and More bretzkej R/C Items: For Sale/Trade 8 05-27-2007 05:57 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 06:45 PM
