Old 03-12-2008, 01:10 PM   #886
thewholeyearinn's Avatar
Thanks for the info gents.
I understand what your saying on the servo linkage setup - thanks!
I don't know who I am I don't know where I've been human junk just words and so much skin stick my hands through the cage of this endless routine just some flesh caught in this big broken machine.
thewholeyearinn is offline   Reply With Quote
Old 03-12-2008, 01:39 PM   #887
Integra's Avatar
awsome....as that stuff does make a HUGE difference if its outta wack.
Old 03-12-2008, 01:48 PM   #888
Hello all I am thinking about getting a Mugen MSR-X5T... what is the difference between it and the MBX5R-T?
lanerbrainer205 is offline   Reply With Quote
Old 03-12-2008, 04:28 PM   #889
FrankBlack's Avatar
Originally Posted by OBMIT View Post
Hey Frank are you going to run the 5R / GRP combo at the Australian Nats?
Tim
FrankBlack is offline   Reply With Quote
Old 03-12-2008, 07:36 PM   #890
Send a message via Yahoo to windellmc
The MSR truck was an early conversion kit for the MBX5 buggy. It is not competitive with modern truggies.
MP9 tki4
Truggy?
windellmc is offline   Reply With Quote
Old 03-13-2008, 06:00 PM   #891
tmperformance1's Avatar
Send a message via Yahoo to tmperformance1
i use a 3mm plastic spacer under the ball stud it reduced bumpsteer to 2.5*. i used hub spacers from a xxxt.
Mugen Seiki,Sidewinder Fuels,Airtronics,O.S.Engines,AKA Products,Ascendency Racing clutches,Fastlane Graphix,TKO,IDRC,M2C RACING
tmperformance1 is offline   Reply With Quote
Old 03-15-2008, 09:36 PM   #892
shawnp.'s Avatar
i was wondering if any other mbx5r owners had any issues with the fuel tank breaking i bought my mbx5r last summer and raced it 3 times it has been sitting ever since i was cleaning it up today and noticed while i had the fuel tank off that there was something rateling inside and found it to be the stone filter had seperated anyways has anyone else had this problem
shawnp. is offline   Reply With Quote
Old 03-16-2008, 06:01 AM   #893
Trader Rating: 24 (100%+)
I've never seen that happen to any Mugens tanks around here and I've used the same tank for 2 years at a time.
Jeff Ford is offline   Reply With Quote
Old 03-16-2008, 03:22 PM   #894
FrankBlack's Avatar
Ive got the same problem, mine hasnt come off yet but its very loose inside there i cant get anything in there to tighten it up, im sure it will come off very soon.
Old 03-16-2008, 04:01 PM   #895
shawnp.'s Avatar
well you can't tighten it up and what happens is it causes air in the fuel line which also makes the engine run irratic
Old 03-17-2008, 09:29 AM   #896
Tech Legend
Cain's Avatar
Trader Rating: 233 (100%+)
I got this from Mugen about the arms issue:
ThatR17;s just what people are saying, we do not have an issue with the lower arms. And are not doing any type of exchange.
Best regards,
Mugen Support
support@mugenracing.com
www.mugenseiki.com
www.mugenracing.com
(949) 707-5607
(949) 707-5614 fax
Strange as it seems to be a known issue on a batch of arms. gives me a bit of pause on there vehicle unfortunately.
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Old 03-17-2008, 11:32 AM   #897
MBX5TR's Avatar
Hey guys i'm having a severe problem with mugen 1.0 clutch springs they have been braking on me for 5 weeks now and i've tryed with diferent shoes i think is a bad batch i was wondering if any of you guys have had any issues
Ricardo Jordao Desoto Racing, Serpent, Picco, AKA, EZ Customs, RC Addiction Products.
MBX5TR is offline   Reply With Quote
Old 03-17-2008, 12:39 PM   #898
I was having severe tuning issues this past weekend. Pulled that tank from my 5R, and it the stonefilter is also rattling, but has not come loose yet. I could not get my engine to tune for the life of me.
Do I need a new tank? Or is there a way tighten the stonefilter in place? It seems to move up, and down about a 1/4 inch.
Thanks Sean.
As for the Mugen clutch springs, there is a bad batch out there, and has been for a few months. I have read several different threads about broken Mugen Clutch Springs. I would p/u a different brand, as stay away from the Mugens for a few more months.
savagebeing is offline   Reply With Quote
Old 03-17-2008, 02:42 PM   #899
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
Thats issue was going around a few month back. Maybe try the Ofna springs. I believe they are the same size.
Oh, I try gluing those brake pads to the brake plates for a change!?!?
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Old 03-17-2008, 02:49 PM   #900
Starter box's Avatar
Default Lower brake rod/collar touches spur gear and tank
Hi Guys,
I am building an MBX5R.
I use an Airtronics 94357 throttle/brake servo with the stock Airtronics servo horn. The fuel tubing on the rod is 10mm long.
With this setup, when going approx. half throttle, the lower brake rod is _very_ close to the spur gear and the splash guard/tank (see attached pix). So close that the collar almost touches the spur gear or the tank.
I am building according to specs and my setup matches Mugen's pictures of a built car. However, I feel that the collar might be to close to the spur gear/tank, so that it could get caught.
Is that amount of little clearance normal?
Thanks for your feedback,
Frank
Mugen MBX5R-1.-brake-rods.jpg   Mugen MBX5R-2.-lower-brake-rod-spur-gear.jpg   Mugen MBX5R-3.-lower-brake-rod-spur-gear.jpg   Mugen MBX5R-4.-lower-brake-rod-splash-guard-tank.jpg
Starter box is offline   Reply With Quote
MUGEN MBX5R and (THREE) MUGEN MBX5T PROSPECS F/S or F/T nobike R/C Items: For Sale/Trade 11 02-12-2008 11:49 AM
MUGEN MBX5R F/S tshaec5r R/C Items: For Sale/Trade 25 01-14-2008 07:17 AM
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 09:32 AM
Mugen MBX5R Brand New Mugen Hops Ups and More bretzkej R/C Items: For Sale/Trade 8 05-27-2007 05:57 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 06:45 PM
