Old 02-26-2008, 12:24 PM   #826
Vsfriedmugan's Avatar
Send a message via MSN to Vsfriedmugan
Does anybody know were i can find aluminum parts.... For the f/r swaybar stops on the diff. boxes?
MBX6>>FUTABA>BYRON FUEL>O.S>ProTek>HITEC
and a mask to inhale nitro fumes
Vsfriedmugan is offline   Reply With Quote
Old 02-26-2008, 12:42 PM   #827
Crim3Wav3's Avatar
Racer's Edge made them...I have 'em on my buggy.
I would check the obvious places: CarolinasRC, Amain, Tiltyard, Speedtech, etc., etc.
Crim3Wav3 is offline   Reply With Quote
Old 02-26-2008, 02:57 PM   #828
the fos's Avatar
has anyone seen how nice the new mbx6 is , its very nice
the fos is offline   Reply With Quote
Old 02-26-2008, 03:15 PM   #829
slow coach's Avatar
We Wish, and you
slow coach is offline   Reply With Quote
Old 02-26-2008, 03:33 PM   #830
Trader Rating: 24 (100%+)
Originally Posted by PACE View Post
Can anyone give me some set up tips for my MBX5R on rough hard packed tracks with high grip? Im having trouble getting the buggy to run stable so it will stay on its wheels and jump cleanly. Should i be using softer or harder springs, thinner or thicker weight oils in shocks and diffs, kick up, ride height or whats the general rules of thumb to follow??
On ours, we wil run th ewhite springs in high bite situations and limit the droop, you want to run as much droop as you can and not traction roll. Droop is very sensitive on the buggy and a great tuning aid.
Jeff Ford is offline   Reply With Quote
Old 02-26-2008, 07:04 PM   #831
PACE's Avatar
So will less droop make he buggy handle rough sections better also?
(less meaning the arms dont come down as much once the buggy leaves the ground right)????
Hold it on!
PACE is offline   Reply With Quote
Old 02-26-2008, 10:54 PM   #832
OBMIT's Avatar
Yes its sexy.......
www.timnicolphotography.com.au
811 Cobra - Ninja - Ace - Spektrum
Plaig RC Bearings
OBMIT is offline   Reply With Quote
Old 02-27-2008, 05:38 AM   #833
No, you need the suspension travel to soak up the bumps.
Old 02-27-2008, 07:39 AM   #834
PACE's Avatar
ok i understand now. What about shock oils? do you generally go thicker on rougher tracks to help soak up the bumps too?
Hold it on!
Old 02-27-2008, 08:06 AM   #835
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
Thinner oil for bumpy/rutted track.
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Old 02-27-2008, 11:50 AM   #836
Starter box's Avatar
Cool
Hi,
Moved the thread below to this forum.
Any comments on the issue with the bulge on the outside of the diff case along the screw?
Thanks,
Frank
Originally Posted by imaxx21 View Post
machined screws..3x14
Originally Posted by ezveedub View Post
Are you using machine threaded screws or coarse threaded. I have the machine threaded screws and have no issues. I believe I used the longest possible, either 12 or 15mm long.
Originally Posted by Starter box View Post
Tony, Thanks a lot for your tips!
I noticed one problem with my 5R diffs though:
I use 3x12mm screws to tighten down the spur gear/bevel gears on the diff cases. However, I noticed on one diff case today, that on the outside of the diff case the longer screws are causing bulges. I believe as soon as a screw gets into the case slightly off the 90 degree angle, it causes the case to bulge. Any thoughts on this? I might want to go one step back to 3x10mm?
Best regards,
Frank
Originally Posted by TonysScrews View Post
Gen,
The Mugen diffs "can" leak in two places:
1] At the out-drive where the S5 o-ring seats
2] At the diff gasket
For the outdrives you need to use a good quality waterproof sythetic grease. Mugen Super Grease, Maxima sythetic grease or Mobil 1 sythetic grease all work well. You can get the Maxima grease from most motorcycle/ATV shops and the Mobil 1 grease is easily found in any auto parts store. Use the grease on the o-ring, on the shim and on the outdrive. Make sure you get grease in that groove on the outdrive. Don't be afraid to put on a lot of grease. The stock o-rings or slightly oversized o-rings both work well with the grease. I also sell the o-rings on my website. Since you're in Australia, I do all int'l orders via email as my cart doesn't support Int'l orders except for Canada, but shipping is cheap for just some o-rings.
On the gaskets, I've used both one or two gaskets on the diffs and it doesn't make a difference as mine never leaked. The two gaskets just feels smoother to me so why I use two gaskets now. But one gasket is fine too if you follow these steps. What I do is sand the diff cups smooth (tip from Chad Bradley when he ran for Mugen) to make sure they seat perfectly against the gears. It only takes about 20 seconds per diff cup and you only have to do it once, then the cups will last you gallons upon gallons. I use a 400, then 800 and then 1200 emery cloth paper. Just use a perfectly flat surface, lay down the paper and slide the cup around in a figure 8 pattern for a few seconds. Start with the 400 and work up to the 1200. Blow them off with compressed air to clean them. But the key to them not leaking here is to use longer screws. The 3x8mm flat head screws are way too short to get a good amount of torque on the gasket without the cup stripping out. Use 3x14mm flat heads and tighten in a star pattern.
If you do this to your diffs, they'll never leak.
Best regards,
Starter box is offline   Reply With Quote
Old 02-27-2008, 05:14 PM   #837
Slippery's Avatar
Frank , I have seen the bulging bolts on my diffs when running the longer screws , haven't had any diff problems for years no real concern
I also run 2 diff gaskets and sand the faces also , but the only difference i measure the case width using some verniers then sand off )0.25mm from the faces as the gaskets are around 0.30mm this way i keep the stock internal clearances etc
I realize most people only sand a tiny bit and then use 2 gaskets so increasing the internal clearances slightly ,which makes a more open diff feeling , I haven't heard of someone blowing a diff because they were running 2 gaskets
just my 0.02cents
cheers
Slippery is offline   Reply With Quote
Old 02-27-2008, 06:56 PM   #838
TonysScrews's Avatar
Frank,
I posted on the other thread but I'll post here too. Grab a 2.5mm drill bit (3/32" will do) and using a cordless drill, run the the bit in and out of each diff cup hole SLOWLY. This will ensure it is the proper size (and clear) for the longer 3mm screw. I haven't had to do this on any of my diff cups, but since this stuff is molded plastic, you can always have a cup that isn't perfect.
Best regards,
Tony P.
Tonys Screws LLC
http://www.tonysscrews.com
High Grade Alloy Steel Screws, Screw Kits and Mugen Parts
TonysScrews is offline   Reply With Quote
Old 02-28-2008, 03:55 AM   #839
OBMIT's Avatar
Hey guys
I am giving the new RC8 clutch a go so far so good i like.
is that a tony screws sticker i see in the top left....
Tim
Plaig RC Bearings
Old 02-28-2008, 05:34 AM   #840
ezveedub's Avatar
Originally Posted by OBMIT View Post
Hey guys
Tim
My friend ripped the RC8 clutch off his RC8 and installed a Mugen Clutch instead. The shoes mushroom easily and stall the engine.
MUGEN MBX5R and (THREE) MUGEN MBX5T PROSPECS F/S or F/T nobike R/C Items: For Sale/Trade 11 02-12-2008 11:49 AM
MUGEN MBX5R F/S tshaec5r R/C Items: For Sale/Trade 25 01-14-2008 07:17 AM
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 09:32 AM
Mugen MBX5R Brand New Mugen Hops Ups and More bretzkej R/C Items: For Sale/Trade 8 05-27-2007 05:57 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 06:45 PM
