Old 01-29-2008, 08:53 PM   #751
Send a message via MSN to newton9266
Regarding spring setup, i bought a new set of Option Spring (Grey) over the weekend and install it pairing with Mugen 450 shock oil on all 4 corners. The results was awesome, the car jump and lands well and has very good respond overall. I'm using 3mm spacer up front and no spacer in the rear.
newton9266 is offline   Reply With Quote
Old 01-30-2008, 04:55 AM   #752
vti-chris's Avatar
How many degrees caster are you all usually running on your mugen?
Xray/OS/Savox/Sanwa
Axial XR10
Sakura Zero S/Castlecreations
RCO
vti-chris is offline   Reply With Quote
Old 01-31-2008, 07:04 AM   #753
Send a message via Yahoo to windellmc
Originally Posted by KyJoe340 View Post
I'm currently running 7-7-3 with everything else stock setup except for my shocks 1 hole inward on the tower front and rear. This setup seems very good on our track which is usually loose but on power in and exiting corners I think the rear breaks loose too easily but it is predictable. I'm usually sliding around every turn. I would just like to stick the rear a little better, would 7-7-2 be a good place to start ?
You might try 5k rear diff oil although 3k is a good all around setup. If you go lighter the car should turn into the corner better and might stick the rear more but if it does get loose it will snap out harder than the heavier rear oil. I felt like 5k handled a lot like 3k only more predictable.
I would suggest going up .25 to .5 degrees of rear toe (if you are not up to 3 degrees yet) or you might try 5k front diff oil as that should make take away a little bit of on power steering.
MP9 tki4
Truggy?
windellmc is offline   Reply With Quote
Old 01-31-2008, 10:43 PM   #754
vti-chris's Avatar
A lot of chassis flex in the middle...around the center diff area.
Can we do anything about it or this is how it should be?
In one race i can notice the U shape in the chassis.
Xray/OS/Savox/Sanwa
Axial XR10
RCO
Old 01-31-2008, 10:45 PM   #755
vti-chris's Avatar
Xray/OS/Savox/Sanwa
Axial XR10
RCO
Old 02-01-2008, 05:24 AM   #756
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
If the you can see or measure a curve in the chassis with a straight edge or ruler, its bent. I had that issue with a DR chassis on a K-Car.
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Old 02-02-2008, 07:32 AM   #757
vti-chris's Avatar
I think i've read somewhere in here that the mugen chassis does flex in the middle easy...so i thought this was normal.
Has anyone also tried a 44T spur gear with a 13T cluct bell?
Xray/OS/Savox/Sanwa
Axial XR10
RCO
Old 02-02-2008, 09:20 AM   #758
Crim3Wav3's Avatar
i've cased a jump on a blue-clay track and, becuase the jump was VERY hard, i noticed when i got home that the chassis had a very noticeable crease going right through the spur gear opening....i've since replaced the chassis. It was a good whack, but....if the chassis were thicker it would more than likely not be a problem.
Crim3Wav3 is offline   Reply With Quote
Old 02-02-2008, 03:40 PM   #759
GREGORY!'s Avatar
hi!can i use a clutch bell from the eight without problem?thanks!
GREGORY! is offline   Reply With Quote
Old 02-02-2008, 03:43 PM   #760
Boadazofa's Avatar
Trader Rating: 33 (100%+)
I am pretty sure you cant because the losi clutch bell is a unique design, but i could be wrong.
Lone Wolf
Boadazofa is offline   Reply With Quote
Old 02-02-2008, 04:30 PM   #761
Integra's Avatar
i dont see a big issue with riggin up the Losi clutch to the Mugen...But u would have to use a Standard bell...as the Stock losi bell or the RR bell is way too deep and would hit the tank when mounted.....i did run a standard bell on my losi clutch once....but on my losi...so maby when i get my mill back from my modder...and i have buddy's 5R still on the bench ill test it out for u guys.....buddy has also been naggin me to rig it and see if it works...so ill let u guys know.
Old 02-02-2008, 08:32 PM   #762
TonysScrews's Avatar
Hi Guys,
I'm just cleaning up my pit boxes (they are getting too heavy...LOL ) and found a ton of spares I don't need. So I posted a TON of NEW Mugen parts & other items for sale over here:
Tons of Stuff 4 sale - Mugen Parts, Servos, etc.
Best regards,
Tony P.
Tonys Screws LLC
http://www.tonysscrews.com
High Grade Alloy Steel Screws, Screw Kits and Mugen Parts
TonysScrews is offline   Reply With Quote
Old 02-05-2008, 04:31 PM   #763
vthondaboi's Avatar
Send a message via AIM to vthondaboi Send a message via Yahoo to vthondaboi
Is everything on the MBX5R interchangeable with the MBX5 besides the 5R shocks?
The MBX5 is really cheap right now and I figure I can get that and upgrade parts as they break/wear out.
Kyosho ST-RR
Kyosho SP2
E-Flite Blade CX2 Heli
vthondaboi is offline   Reply With Quote
Old 02-06-2008, 10:57 AM   #764
CanyonCarverR1's Avatar
Hey Guys,
I have a couple questions on the shocks and towers. I bought a set of X5R shocks to put on my X5 and ran into a problem. They are so long that they limit upward travel.
Questions:
1. Are the shock towers the same height on the X5R and X5? Seems like a taller tower is needed?
2. Are the shock shafts the same on the X5R and the X5-Truggy?
I'm just trying to freshen up my old X5 to run a couple races while waiting for the X6 to come out.
CanyonCarverR1 is offline   Reply With Quote
Old 02-06-2008, 11:33 AM   #765
vthondaboi's Avatar
From my research the old shock towers from the X5 won't work with the X5R shocks.
Kyosho ST-RR
Kyosho SP2
MUGEN MBX5R and (THREE) MUGEN MBX5T PROSPECS F/S or F/T nobike R/C Items: For Sale/Trade 11 02-12-2008 11:49 AM
MUGEN MBX5R F/S tshaec5r R/C Items: For Sale/Trade 25 01-14-2008 07:17 AM
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 09:32 AM
Mugen MBX5R Brand New Mugen Hops Ups and More bretzkej R/C Items: For Sale/Trade 8 05-27-2007 05:57 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 06:45 PM
