Old 01-21-2008, 09:13 PM   #721
OBMIT's Avatar
Ryan
That new body for Ms skelton looks sweet. Welodone.
www.timnicolphotography.com.au
811 Cobra - Ninja - Ace - Spektrum
Plaig RC Bearings
OBMIT is offline   Reply With Quote
Old 01-23-2008, 02:26 PM   #722
dgraham225's Avatar
Send a message via Skype™ to dgraham225
hey guys, i have my mbx5r for sale if anyones interested, heres the thread"
FS: MUGEN MBX5R
Danny Graham
dgraham225 is offline   Reply With Quote
Old 01-23-2008, 06:23 PM   #723
FrankBlack's Avatar
Im having a small issue with my 5r. I dail my car in via the hudy bench, i get it perfect then i notice on the front end on one side both the camber pivot ball and the steering link are 5mm longer than the other side, a huge difference but hudy is telling me its teh exact same camber and toe out on each side The ackerman is perfectly centred aswell when on the hudy. The track width is dailed in, 138mm each side from the centre of the chassis and the amount of thread visable from the pivot balls is the same like it should be. Only thing i can think of is maybe cause there is more weight on one side of the car than the other the shocks aren't compensating and doing this, is this normal?
FrankBlack is offline   Reply With Quote
Old 01-24-2008, 12:06 AM   #724
Slippery's Avatar
Talking
The method i use is as follows
Set my bottom pivot balls to the same amount of threads or width , and then when i set camber i make sure the side you are setting is always set to 0 degrees toe in on the set-up station , then proceed to set the camber for that side using the top pivot , repeat for both sides then adjust toe-out Last making sure Akerman arm is centred . when you move the steering off centre it starts to alter Camber drastically i think this might be your problem
Slippery is offline   Reply With Quote
Old 01-24-2008, 02:44 AM   #725
Braz's Avatar
Trader Rating: 3 (80%+)
Default Gearing
With the subject of gearing being hot. I had thought about running the truggy diffs and the high tooth clutch bell awhile back in my 5R when i got my RC8. because I thought the purpose behind it and it seems to work for both associated and losi is the higher internal ratio of the diffs= fast spinning mass= at low speeds like when going through corner then accelerating, because the diffs are spinning faster it takes less torque to spin them up= faster acceleration.
correct me if im wrong but like i said it seems to work for the US cars. This increase in snap just can't be produced by an engine.
Or is it a Losi or Associated are lighter than a 5r, why they accelerate harder.
I bought the rc8 as an intrim car to see what it will be like to have a lighter more responsive car. I hope Mugen do there R&D well and take a few hints from there US opponents because, downunder the tracks are getting bigger jumps and lets face it double single sucks(safe) we want to triple(go big).....
Nil for now
Braz is offline   Reply With Quote
Old 01-24-2008, 08:38 AM   #726
tmperformance1's Avatar
Send a message via Yahoo to tmperformance1
make sure both front arms are 5r arms. if one is a mbx5 arm it is shorter.
Mugen Seiki,Sidewinder Fuels,Airtronics,O.S.Engines,AKA Products,Ascendency Racing clutches,Fastlane Graphix,TKO,IDRC,M2C RACING
tmperformance1 is offline   Reply With Quote
Old 01-24-2008, 10:18 AM   #727
Send a message via Yahoo to windellmc
I'm not sure I agree with the Losi and RC8 having better acceleration than the Mugen. I still have trouble following Losi cars on the track because they exit corners so slow. Maybe they accelerate better in a straight line but with the Mugen you can accelerate earlier exiting the corner which seems more important than just overall accel rates.
MP9 tki4
Truggy?
windellmc is offline   Reply With Quote
Old 01-24-2008, 11:03 AM   #728
Tech Legend
Cain's Avatar
Trader Rating: 233 (100%+)
When running my mugen against the competition at the last big race, I didnt' feel like I was being out cornered and all by the rc8's and losi's. With the MBX5R front end I put on to my MBX5, I was able to corner inside my share of losi's, RC8s, jammins, etc. I think it almost had too much steering at times.
The thing that I liked better on the other vehicles and this coudl be due to my current shock setup was the way they sucked up the rythm section better than me. Also, off of really really big jumps, they landed more plush if they missed the down landing.
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Old 01-25-2008, 12:56 AM   #729
windellmc, you makin the trip to the atl?
Old 01-25-2008, 07:11 AM   #730
No trip to Atl for me. The 24hr qualifying would mess me up, and I think I will wait and see how this year goes. I am planning on running the RC Pro race at HX Raceway in April.
MP9 tki4
Truggy?
Old 01-27-2008, 02:57 PM   #731
CanyonCarverR1's Avatar
Somebody mentioned an MBX6, is that fact of fiction. Need a new car soon and am trying to decide which direction to go.
CanyonCarverR1 is offline   Reply With Quote
Old 01-27-2008, 03:13 PM   #732
slow coach's Avatar
New Car = Fact
MBX6 = who knows but probably
Release = thats the unknown but later in year some time is the guesses
slow coach is offline   Reply With Quote
Old 01-27-2008, 11:33 PM   #733
vti-chris's Avatar
Setup Problem.
I got to race yesterday for the first time and i have a few problems with oversteering on-power and understeering off-power.
I currently run 10-10-3 diff oils with 35wt shock oil in all four corners.
I use the 3 degree rear toe in and 0.5 front toe out.
3 degrees rear camber and 2 degrees front.
The car also seemed to be jumping with nose up most of the time.
I'm thinking in going to 7-5-1 in diff oils and lay the wing down and forward to minimize downforce and alter weight balance.
Xray/OS/Savox/Sanwa
Axial XR10
Sakura Zero S/Castlecreations
RCO
vti-chris is offline   Reply With Quote
Old 01-28-2008, 12:51 AM   #734
FrankBlack's Avatar
Im running close the same as you cept for the diffs, 5/7/2 im running and the car is awesome, even on low traction surface
Old 01-28-2008, 08:07 AM   #735
jpz_67's Avatar
Trader Rating: 56 (100%+)
Has anyone put any super bore sized shocks on there buggies yet? I am willing to spend the time and money to see if the car can benefit from a larger volume shock. I just wanted to know which shocks can be put on the buggy and have the least amount of hassle. I am looking at either buying kyosho or jammin shocks simply because replacement parts are readily available. I am not sure which shock would be close to the mugens as far as shock length. Anybody have any feedback.
Agama A215, Futaba, Nitro Pro Fuel, Proline tires, Triton Engines, Savox.
jpz_67 is offline   Reply With Quote
MUGEN MBX5R and (THREE) MUGEN MBX5T PROSPECS F/S or F/T nobike R/C Items: For Sale/Trade 11 02-12-2008 11:49 AM
MUGEN MBX5R F/S tshaec5r R/C Items: For Sale/Trade 25 01-14-2008 07:17 AM
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 09:32 AM
Mugen MBX5R Brand New Mugen Hops Ups and More bretzkej R/C Items: For Sale/Trade 8 05-27-2007 05:57 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 06:45 PM
