Old 12-16-2007, 01:01 AM   #616
maximugen's Avatar
Send a message via MSN to maximugen
also, how hard are you driving the car? bashing or racing?
cuz ive seen people go months without breakin a part when racing, but they put the car down at a bmx track and it lasts 2 minutes
Mugen MBX5r - N/R 367 / Sirio bx STi
Mugen MST1 - JP RS12
Losi JRXSR- LRP SPX and Speed Passion 17.5R
HPI Savage - N/R 528
Trex 250
maximugen is offline   Reply With Quote
Old 12-16-2007, 01:08 AM   #617
FrankBlack's Avatar
Purely racing bud, after i did the first 2 nylon gears at a meet, i stripped the saver down and inspected it, nothing i could see that would cause any worries, i took most of the tension out of the spring to the point that if i went anymore it would come off, tested the saver and it was fine, then was out at the track today and after about a litre of juice it stripped the gear again, i inspected the saver and it wouldnt budge, its like cause of this spring on the top design dirt or something is gettin in there and jamming it up, very frustrating.
FrankBlack is offline   Reply With Quote
Old 12-16-2007, 03:09 AM   #618
are we talking about bind in the saver it self or are we talking pivot balls screwed together too tight? there is nothing about the saver that would cause it to lock up if put together right. you can probably go a long time without totally taking that apart to clean/oil it for it to become an issue for it to be "moving slow". if it locks up there is either very bad bearings in it or the posts are messed up.
mugenlife is offline   Reply With Quote
Old 12-16-2007, 10:08 AM   #619
Slippery's Avatar
Thumbs up
Hi Man , Had the exact same problem with the Saver on the last buggy so i changed to the X5 setup with the spring upside down , But in saying that i have been running the Truggy with the Kit set-up ( Teflon tube) and has been good so fair will be running the new buggy with Kit set-up and Teflon tube , not a fan of the spring on top as on our dusty tracks it accumulates dust under spring and binds Mine would always jump the servo arm around a few splines have never stripped a servo though
Any way if you can't resolve it doesn't take much to change over to the old X5 set-up .
Slippery is offline   Reply With Quote
Old 12-16-2007, 01:46 PM   #620
Winner's Circle's Avatar
Originally Posted by ezveedub View Post
I've been working on that part. If you don't get on the throttle in the air to bring the nose up, it will nose dive. It seems taking out droop seems to level out the car, but I'm going to try a different approach and see if it works. My local track is not as flat as that track you run on. It has a lot of jumps, both small and large with a 8 pack rhythm section make will make or break you in a race if you can't get over it consistently.
I was having the problem of the car dropping the nose on my MBX5T. I changed the rear wing so that it was higher and had more angle and the problem all but disappeared. I also modified my driving slightly but the solution for me was mostly the change in wing angle.
Winner's Circle is offline   Reply With Quote
Old 12-16-2007, 02:56 PM   #621
skeller's Avatar
Send a message via AIM to skeller Send a message via MSN to skeller Send a message via Yahoo to skeller
slinger22....ygpm
skeller is offline   Reply With Quote
Old 12-16-2007, 07:06 PM   #622
Send a message via Yahoo to windellmc
The best fix I have found for the servo saver is the Hitec 5955 servo. The Futaba s9451 is really not enough torque for 1/8 buggy steering.
MP9 tki4
Truggy?
windellmc is offline   Reply With Quote
Old 12-16-2007, 07:15 PM   #623
OBMIT's Avatar
check the pivot balls.
Mine was binding up it was due to too tighter pivot balls. was ony spotted because my mate runs a 5R and his was smooth and free.
Cheers
Tim
www.timnicolphotography.com.au
811 Cobra - Ninja - Ace - Spektrum
Plaig RC Bearings
OBMIT is offline   Reply With Quote
Old 12-16-2007, 11:20 PM   #624
Boz
Trader Rating: 23 (100%+)
Default installing titanium screws for the 1st time....
Iím just about to build a new MBX5R with the Titanium screw kits. What method do you use to start off the threads in the plastic parts?
Boz is offline   Reply With Quote
Old 12-16-2007, 11:29 PM   #625
jpz_67's Avatar
Trader Rating: 56 (100%+)
I usually take my body reamer and make a few passes through the plastic and the screw should then start easily. I would not recommend the titanium screws except in low stress low torque applications. It is not worth the loss of strength for what little weight you may shed.
Agama A215, Futaba, Nitro Pro Fuel, Proline tires, Triton Engines, Savox.
jpz_67 is offline   Reply With Quote
Old 12-17-2007, 06:19 AM   #626
Boz - I have not built a new kit with the Ti screws, but I did install them in a used kit. I think I would build the car with the steel and then put the Ti in. I know it will take longer but it will be the safest bet. Make sure and use a nice new driver for the Ti. The heads are softer than steel and seem a very slight bit looser fitting with the allen driver.
MP9 tki4
Truggy?
Old 12-17-2007, 08:18 AM   #627
MBX5TR's Avatar
Ok for the servo saver issue i've been there and i'm sorry but the only fix is to change the servo saver plastics and if i were you i'll get a jr z9100t for the steering.
about the titanium screws if i were you i would use only the top screws since i changed the hole thing in my mbx5t and i'm having traction problems since my truggy is now lighter than my buggy about the threads you just need to be carefull with the wrench it doesn't matter if its on new or old plastics if your tool isnot aligned properly and the screw head free of dirt you will strip the head.
MBX5TR is offline   Reply With Quote
Old 12-17-2007, 02:58 PM   #628
FrankBlack's Avatar
Replace with the same ones or change to the mbx5 saver? Im very happy with my 9451 on the steering.
Old 12-17-2007, 05:15 PM   #629
Frank you will probably more steering if you switch to a higher torque servo. I also thought mine was fine with the 9350 servo which has a little more torque than a 9451. Then I put in a 9351 and the steering was much better. However I found the plastic gear in the 9351 is not strong enough so I went to the Hitec 5955 and it has been great since July.
MP9 tki4
Truggy?
Old 12-17-2007, 09:28 PM   #630
OBMIT's Avatar
Im using the new futaba BL451 servos. They seem sweet as. As good as the s9351's.
I havent used any other brand servo but im super happy withthe Futaba's.
Tim
Plaig RC Bearings
MUGEN MBX5R and (THREE) MUGEN MBX5T PROSPECS F/S or F/T nobike R/C Items: For Sale/Trade 11 02-12-2008 11:49 AM
MUGEN MBX5R F/S tshaec5r R/C Items: For Sale/Trade 25 01-14-2008 07:17 AM
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 09:32 AM
Mugen MBX5R Brand New Mugen Hops Ups and More bretzkej R/C Items: For Sale/Trade 8 05-27-2007 05:57 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 06:45 PM
