Old 11-22-2007, 06:34 PM   #466
on the front shock tower if not then it isnt stock.....mbx5, prospec, and the mbx5R all have AT LEAST that eclip........and the other parts on the car arent stock if it has captured hinge pins like king heads suspension blocks......
mugenlife is offline   Reply With Quote
Old 11-22-2007, 06:49 PM   #467
Turbine_au's Avatar
Upper front arm hingepin uses an e-clip. All other hingepins are locknutted. That's what he meant.
It's mine: http://au.youtube.com/watch?v=usYhSWbmx6s
Turbine_au is offline   Reply With Quote
Old 11-22-2007, 06:49 PM   #468
Jason Halvorson's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to Jason Halvorson Send a message via MSN to Jason Halvorson
the mugen part number is E0123...
08 Sponsors Thank you for all your support!!!!
TEAM OCM USA
TEAM GO TECH
TEAM PRO TWISTER MODS
TEAM VP PRO TIRES
OCM RACING DT-19 EVO, GO TECH ENGINES PTM'ED
OCM RACING DT-19T PRO, GO TECH ENGINES PTM'ED
Jason Halvorson is offline   Reply With Quote
Old 11-22-2007, 07:46 PM   #469
that comes in the kit..... you have more than 4 hinge pins as those are just lower.... the upper front is an eclipon one side captured on the other....then you have the outer rear which are bolt ons as well...
Old 11-22-2007, 08:40 PM   #470
i see what your saying now...
TEAM OCM USA
TEAM GO TECH
TEAM VP PRO TIRES
Old 11-22-2007, 09:15 PM   #471
i was starting to wonder what upgrades you had lol i know the kingz heads pin blocks can be captured in the back and in the back front but they require the old pins unless you want some long ends sticking out. nitro house has some carbons that are alot lighter but require E clips.
Old 11-22-2007, 09:17 PM   #472
i guess i doent mind the eclips...i have never had a problem with loosing any...
TEAM OCM USA
TEAM GO TECH
TEAM VP PRO TIRES
Old 11-22-2007, 09:27 PM   #473
http://www.nitrohouse.com/details_jdcarbon.htm
http://www.nitrohouse.com/options_mbx5r.htm
those and some lotaballs lite pivot balls , lipo reciever pack, some titanium screws (not all) carbon rear shock tower and some diff gear milling and pivot ball screw drilling should get the weight down to something pretty respectable without losing anything (tower optional) i think i am going to also go to plastic rear uprights. with some luck might get it down to under 7 and a half pounds.
Old 11-22-2007, 09:31 PM   #474
rezenclowd3's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rezenclowd3
I do not like them, as I am used to just the 1 that the Losi 8 uses.
OOMSGFX.COM (no longer painting, but take a look for fun!), Roadrunners RC Club
"Racing drivers have balls, unfortunately, none of them are crystal" (David Coulthard)
"I believe the average IQ of a NASCAR fan is only marginally above the things that hit the windscreen during the race. "
rezenclowd3 is offline   Reply With Quote
Old 11-22-2007, 10:07 PM   #475
Nitro$junkie's Avatar
Send a message via MSN to Nitro$junkie
I use the K-fatory super hardened hinge pins which have a flat head screw instead of the hex which i like better cause i started to round the hex heads from taking them out all the time
Futaba
Mugen
Novarossi
Byron's
http://www.hospitalrecords.com
Nitro$junkie is offline   Reply With Quote
Old 11-22-2007, 11:44 PM   #476
FrankBlack's Avatar
My kit jsut arrived and im a little confused with the toe blocks. The front kickup blocks and rear toe block i get but the others im having problems with, the 2 different numbers on most of the block is confusing.
FrankBlack is offline   Reply With Quote
Old 11-23-2007, 12:00 AM   #477
I'm guesing you are reffering to some of the rear toe blocks? Just use ones with only 1 number; 2, 2 1/2, 3.....The ones with a number on the left side of the block are additional anti-sqaut, which are rarely used...
-Steve
Steve Thyen is offline   Reply With Quote
Old 11-23-2007, 12:23 AM   #478
FrankBlack's Avatar
Ok Thx man.
Old 11-23-2007, 03:22 AM   #479
Nitro enthusiasts who want to join the brushless revolution can now convert their 1/8th- scale nitro buggy to electric powered using the Novak 1/8th-scale Conversion Kit. Kits are available for various models of Kyosho™, Mugen™ and Ofna™ vehicles, and include all of the necessary components to convert it to brushless power.
Nitro customers who have never run brushless will now experience longer run times, minimal maintenance, low-end torque and control and incredible top speed.
The Novak Conversion Kit is compatible with the Novak #3020 and #3021 HV High-Voltage Brushless Systems, and is available individually or as a combo kit with these systems. The kit includes a Motor Heat Sink and Motor Mount specifically designed for the Novak 550-size HV motors; Two Battery Boxes for dual 2S Li-Po packs or dual 6-cell Ni-MH packs; and a Steering Servo Mount (replaces dual servo mount set-up as the mechanical brakes and brake servo are no longer needed). Kit includes all the necessary Hardware to complete the conversion.
More info
Futaba
Mugen
Novarossi
Byron's
Old 11-23-2007, 08:19 AM   #480
paulj2's Avatar
More info
Interesting.
Do you have any in depth info on the conversion such as, weight, run times for high end Li-Po, how complete is the kit, etc? Also, where can a person get the complete conversion kit?
Tony (Tony's Screws), is this the conversion you are experimenting with? If so, how is it working?
I was looking at selling my MBX5R and racing truggy class only, this may change my mind.
paulj2 is offline   Reply With Quote
MUGEN MBX5R and (THREE) MUGEN MBX5T PROSPECS F/S or F/T nobike R/C Items: For Sale/Trade 11 02-12-2008 11:49 AM
MUGEN MBX5R F/S tshaec5r R/C Items: For Sale/Trade 25 01-14-2008 07:17 AM
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 09:32 AM
Mugen MBX5R Brand New Mugen Hops Ups and More bretzkej R/C Items: For Sale/Trade 8 05-27-2007 05:57 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 06:45 PM
