Old 11-15-2007, 06:53 AM   #436
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
Originally Posted by OBMIT View Post
u missed the punch line. I was having a dig about ur grey short's you wear on ur body never mind.....
Funny thing you mention, I got a pair of grey shorts I always wear to the track!!
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Old 11-15-2007, 05:21 PM   #437
http://cgi.ebay.com/Mugen-Seiki-MBX5...QQcmdZViewItem
Toby Robinson is offline   Reply With Quote
Old 11-16-2007, 03:31 PM   #438
DogboneS's Avatar
Trader Rating: 20 (100%+)
Originally Posted by MaxxBashers View Post
I haven't ran the jammin shocks, but I am using the Kyosho big bores on my mbx-5r and so far love it. What a difference. I am using the kyosho standoff's.
Could you tell us the eye to eye length of the Kyo Big Bores. Would like to compare to the 5R shock length. I'm also curious of the Jammin eye to eye length.
DogboneS is offline   Reply With Quote
Old 11-17-2007, 03:10 AM   #439
Default Droop settings
Finished building my MBX5R. Its so close to my MBX5T truggy I could not believe it as far as build goes. Its my first ever buggy. I currrently drive an MBX5T
Just wondering how much droop you set up on these buggies. And how you measure it for that matter. Defualt says 10m droop with a wheel under the chasis. I have a few wheels and they vary in thickness so this cant be accurate.
How do you guys set and measure your droop and what seetings do you use for varying tracks from grass to rough ?
Regards
Chris
chrisv is offline   Reply With Quote
Old 11-17-2007, 05:23 AM   #440
Turbine_au's Avatar
Use a standard 1/8th unmounted wheel. 10mm from the bottom of the upright to the ground. I've changed my droop screws for button head screws to stop it biting into the chassis so I'm at maximum droop at the 10mm.
It's mine: http://au.youtube.com/watch?v=usYhSWbmx6s
Turbine_au is offline   Reply With Quote
Old 11-18-2007, 10:55 AM   #441
When running the Truggy ring and pinion gears in the 5R, what tooth clutch bell are you guys using? Also using a 44t spur I'm guessing?
Thanks,
-Steve
Steve Thyen is offline   Reply With Quote
Old 11-18-2007, 08:10 PM   #442
TonysScrews's Avatar
16T Clutch Bell.
Regards,
Tony P.
Tonys Screws LLC
http://www.tonysscrews.com
High Grade Alloy Steel Screws, Screw Kits and Mugen Parts
TonysScrews is offline   Reply With Quote
Old 11-18-2007, 08:27 PM   #443
Thnaks Tony. Have you tried this set-up in your buggy?
-Steve
Old 11-18-2007, 10:46 PM   #444
Boz
Trader Rating: 23 (100%+)
Regards
Chris
A Mugen wheel is about 41mm in width.
Boz is offline   Reply With Quote
Old 11-19-2007, 07:42 PM   #445
-Steve
Hi Steve,
Sorry, I haven't had the chance to try the MBX5T ring & pinion in my MBX5R. I have spoken to a few guys that have tried it as well as spoke to Kris Moore about it and they do like running the set up.
Best regards,
Tony P.
Tonys Screws LLC
Old 11-20-2007, 09:10 PM   #446
rezenclowd3's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rezenclowd3
Hey guys, Im looking at another buggy to try alongside my Losi 8. I think the determining factor to buy the MBX5R is how easy are the locknuts for the hingpins to access and remove? I am quite disappointed that they are not captured like the Losi 8 are.
OOMSGFX.COM (no longer painting, but take a look for fun!), Roadrunners RC Club
"Racing drivers have balls, unfortunately, none of them are crystal" (David Coulthard)
"I believe the average IQ of a NASCAR fan is only marginally above the things that hit the windscreen during the race. "
rezenclowd3 is offline   Reply With Quote
Old 11-20-2007, 09:53 PM   #447
Turbine_au's Avatar
If I need to pop the hingepins, I usually take the entire of the assembly. 4 bolts and the chassis brace on the rear. 6 and the brace on the front. Then just undo the hingepin with a hex driver and a spanner. It's fairly easy.
I usually tighten the pin up until it binds with the shock and anti roll bar disconnected. Then slowly loosen the pin until the arm falls due to it's own weight.
Old 11-21-2007, 01:47 AM   #448
hinge pins are easy on the mbx5R...so easy in fact i could care less if they are captured or not...no issues like with E clips
mugenlife is offline   Reply With Quote
Old 11-21-2007, 09:22 AM   #449
It may seem like a silly point (my obsession with ease of repairing the car) but, I know my 8 handles great (twitchy and very aggressive, yet can hug the corners just as well as the others) but I do just want to try something new. With quality like Mugen, Losi and Xray, I choose by ease of maintenance. Its easy to adjust to a driving style of a vehicle, and with the number of adjustment options on these toys, its also easy to dial in a driving style.
Old 11-21-2007, 09:32 AM   #450
Jason Halvorson's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to Jason Halvorson Send a message via MSN to Jason Halvorson
the hinge pins on the R are captured...
08 Sponsors Thank you for all your support!!!!
TEAM OCM USA
TEAM GO TECH
TEAM PRO TWISTER MODS
TEAM VP PRO TIRES
OCM RACING DT-19 EVO, GO TECH ENGINES PTM'ED
OCM RACING DT-19T PRO, GO TECH ENGINES PTM'ED
Jason Halvorson is offline   Reply With Quote
MUGEN MBX5R and (THREE) MUGEN MBX5T PROSPECS F/S or F/T nobike R/C Items: For Sale/Trade 11 02-12-2008 11:49 AM
MUGEN MBX5R F/S tshaec5r R/C Items: For Sale/Trade 25 01-14-2008 07:17 AM
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 09:32 AM
Mugen MBX5R Brand New Mugen Hops Ups and More bretzkej R/C Items: For Sale/Trade 8 05-27-2007 05:57 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 06:45 PM
