Old 10-24-2007, 06:48 PM   #391
Trader Rating: 14 (100%+)
look above for the setup I posted, I'm not bragging, but it has worked really well for me this year at all types of tracks. The car felt really good, the only thing I did to get it to handle the way I wanted to was increase or decrease the droop in the front or rear of the car.
If any of you want a better copy, I'll gladly post it.
o.s. power is offline   Reply With Quote
Old 10-24-2007, 06:48 PM   #392
oops, double post
Old 10-24-2007, 10:29 PM   #393
thanks guys
younghovaa is offline   Reply With Quote
Old 10-25-2007, 01:39 PM   #394
Default pre glued tires
If you get pre mounted tires do you still make holes in the tires?
Old 11-01-2007, 07:06 AM   #395
Turbine_au's Avatar
Anyone tried the 14t clutch bell, noticed much difference from the 13t?
It's mine: http://au.youtube.com/watch?v=usYhSWbmx6s
Turbine_au is offline   Reply With Quote
Old 11-01-2007, 09:06 AM   #396
helps with wheel spin and goes a little faster on top end...only time i would use it is if the track is huge with an easy infield and or traction is a problem. it drives good but my lap times were about a .5 second slower from a tight infield
mugenlife is offline   Reply With Quote
Old 11-01-2007, 10:18 AM   #397
Crim3Wav3's Avatar
i agree with the above.
I've always wanted to know how it would do with a good bottom end motor...i've just never tried it personally. I would think that your runtime would increase slightly too.
Crim3Wav3 is offline   Reply With Quote
Old 11-01-2007, 12:21 PM   #398
it works ok with a c6 never finished a 20 min+ main before though with it so i went back to old faithful. do have a question however. after a weekend or 2 of racing something ends up dragging in the center diff/clutch or brakes making it want to nose dive on jumps...my fix is a cleaning/disassemle reasemble any ideas what it can be?
Old 11-01-2007, 01:18 PM   #399
Crim3Wav3's Avatar
I have found after owning several MBX5 versions that the center diff top plate brake bushings SUCK. After several long mains with heavy braking the bushings are blown and the lever arms become sloppy...i suggest the optional hopup top plates with bearings...King Headz comes to mind.
Also, the brake cams tend to wear rather quickly (IMO) causing the brake engagement point to change....also causing you to either flip it if you havent already and buy a new one if youve already smoothed out both corners of the cam lobe. This makes setting the brakes a pain.
In the end, i would also swap out the standard steel rotors for some G10 units and scrap the "pads" on the shoes. This guy makes some killer G10's for the Mugen.
Look up "xrayeddy" on the forum and shoot him a pm for some.
Old 11-01-2007, 04:26 PM   #400
revo61's Avatar
Trader Rating: 18 (95%+)
Has anyone used carbon fiber shock towers on there mbx5? I know there is a company that makes a rear, who makes a front one?
revo61 is offline   Reply With Quote
Old 11-01-2007, 05:01 PM   #401
the option thunder tiger brake discs are the best period.
Old 11-01-2007, 05:17 PM   #402
Registered User
The best period, lol, you crack me up!!
Loop&Roll is offline   Reply With Quote
Old 11-01-2007, 06:46 PM   #403
and you would probably say the same if somebody told you the GTX was the best esc to, right?
Old 11-01-2007, 07:02 PM   #404
i have the racers edge thick anti locks cradock no pads...think its due to the guides being off? then again it wouldnt explain too much as it works most of the time lol
Old 11-01-2007, 07:46 PM   #405
Registered User
I am not getting into a slinging match with you, but seriously mate, have you tried every brake product on the market... come on... why dont you just say that u use them and you think they are great!!! They are good i use them in my truggy but not my buggy.
You are entitled to your opinion but i am a little sick of ppl saying that brand x is the best just because they use them.
MUGEN MBX5R and (THREE) MUGEN MBX5T PROSPECS F/S or F/T nobike R/C Items: For Sale/Trade 11 02-12-2008 11:49 AM
MUGEN MBX5R F/S tshaec5r R/C Items: For Sale/Trade 25 01-14-2008 07:17 AM
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 09:32 AM
Mugen MBX5R Brand New Mugen Hops Ups and More bretzkej R/C Items: For Sale/Trade 8 05-27-2007 05:57 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 06:45 PM
