Old 08-10-2007, 12:07 PM   #286
scott hughes set up from jakarta nitro worlds.
http://www.mugenracing.com/image/rac...scottwcx5r.pdf
i use this but on the front kick up plate i use -2 with 40w associated shock oil in front 35 in back. i run 5000 f-5000 c -3000 r diff fluid. if the track gets blown out the 5000 in the center makes it easier to drive (for me anyway). the -2 plate makes it steer more on throttle instead of trying to coast a corner. this set up imo is just a good starting point.
mugenlife is offline   Reply With Quote
Old 08-10-2007, 12:31 PM   #287
Trader Rating: 42 (92%+)
i ran the swchartz set-up last weekend on tight track
i cant seem to get my car to rotate good in and out of corners
i want the the rear to come around when i turn the steering wheel
exmpl. exiting and entering corners
icemandolmite is offline   Reply With Quote
Old 08-10-2007, 02:53 PM   #288
Ice, I have a setup you can try if you would like it pm me. it is my standard setup that works very well for me and has more than enough steering, the rear comes around and would be considered a touch loose but it is very controllable.
Mike Elam is offline   Reply With Quote
Old 08-10-2007, 05:19 PM   #289
hey mike a loose car is usally a fast car
i sent you my email address for the set-up
Old 08-10-2007, 07:10 PM   #290
Davidka's Avatar
Trader Rating: 75 (100%+)
Originally Posted by icemandolmite View Post
any body have good base setups for rough tracks
tires are bowties,crimes m3 compound
If you really want to eat up bumps then run the rear shocks with 1.4 pistons and 400 (losi/AE 32.5) oil with the lower shock mounted to the inner hole on the arm. The oil and piston feel very heavy on the bench, ignore it. You will be amazed how you can fly across bumps on throttle. Limit rear droop to what you would normally run (you can use more if you'd like) rest of the car should be the same.
Old 08-16-2007, 03:13 PM   #291
Default linkage
hey guys I'am setting up the linkage in my but not sure where to but fuel tubing and not etc. if you guys can send some pictures of your MBX5R and show how you got your linkage setup that will be much appreciated.
younghovaa is offline   Reply With Quote
Old 08-16-2007, 08:34 PM   #292
Default linkage problems
I don't have any fuel tubing on the throttle side but when i hit the gas the breaks come on what adjustment do I do to stop this?
Old 08-16-2007, 09:50 PM   #293
Suspended
Trader Rating: 440 (99%+)
Check the angles of your front and rear brake linkages for any binding when applying the throttle. Also check your center diff to make sure you don't have the calipers tightened too much causing the brakes to bind.
MattP is offline   Reply With Quote
Old 08-16-2007, 11:10 PM   #294
Turbine_au's Avatar
Look back a couple of pages in this thread. Check to see if you've got the same problem with the adjustment collars being too close to the brake linkages.
It's mine: http://au.youtube.com/watch?v=usYhSWbmx6s
Turbine_au is offline   Reply With Quote
Old 08-20-2007, 10:59 AM   #295
Could someone please list the Schwartz setup for me. All the links from here and SGrid don't allow me to take a look at it. Sounds like a lot of guys are running it and I would like to give it a try...
Thanks in advance everyone.
cwalters is offline   Reply With Quote
Old 08-24-2007, 08:00 PM   #296
I was wondering if a fellow Mugen driver would be able to help me out with a small query. I am running an MBX5R myself and would like to know in what increments do the degrees of rear squat alter, when different eccentric bushings are used. For example, when you have the offset bushing with the hole down, is this 1 degree, with the middle hole bushing is this 2 degree and finally with the offset bushing with the hole up, is this 3 degrees? Just trying to find out what I need to use to basically get 3 degrees of rear anti squat, as I am unsure whether I will need to run the -1 degree rear/rear anti squat/toe plate to achieve what I am looking for.
Hope that made sense!
Cheers.
Ashalak is offline   Reply With Quote
Old 08-26-2007, 09:54 PM   #297
Turbine_au's Avatar
Sorry mate, not sure about the anti squat settings.
Has anyone tried the "long" springs? Do they just mean you can run less ride height clips or is there more of an advantage to them?
Old 08-29-2007, 12:13 AM   #298
Turbine_au's Avatar
Bump...
Old 08-29-2007, 02:10 AM   #299
Slippery's Avatar
Thumbs up
They do mean you can run less spacers 5mm is pretty common around aus running 3mm at the Qld states just gone but it was hammering the chassis bad they will handle better over the rough track also .
Not to sure about the rear Anti squad bushes also mostly run mid bush all the time any way would say it would be 2deg anti squat just looking at the angle
Slippery is offline   Reply With Quote
Old 08-29-2007, 11:04 AM   #300
Running the long springs save you from using 20mm of clips...
Last weekend I think I ended up with 8mm in front and 9mm in rear of the car.
Used the Schwartz setup with a few changes. Car was pretty good.
MUGEN MBX5R and (THREE) MUGEN MBX5T PROSPECS F/S or F/T nobike R/C Items: For Sale/Trade 11 02-12-2008 11:49 AM
MUGEN MBX5R F/S tshaec5r R/C Items: For Sale/Trade 25 01-14-2008 07:17 AM
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 09:32 AM
Mugen MBX5R Brand New Mugen Hops Ups and More bretzkej R/C Items: For Sale/Trade 8 05-27-2007 05:57 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 06:45 PM
