Old 08-07-2007, 08:17 AM   #271
standard c6 with 8mm venturi and stock mbx5R clutch can go 8+ min driving like a mad man (more with heavier springs and more when you dont drive crazy)...i will admit it can be a handful but its driveable. i like it better than my nova 3 port (gets about same run time) and it can run faster times than my s7 as it has more grunt to get through the infeild.
mugenlife is offline   Reply With Quote
Old 08-07-2007, 11:53 AM   #272
flatspunout's Avatar
Location: Somewhere between raising hell and Amazing Grace
Trader Rating: 37 (100%+)
Hey everyone, I'm not a Mugen owner but I do run Mugen shocks on my buggy and I was hoping someone could help me out with properly filling/bleeding them. Thanks!
-rocky b
flatspunout is offline   Reply With Quote
Old 08-07-2007, 12:08 PM   #273
the caps have holes and the bladder at the top pushes the access out the hole. only thing i do is try to make sure there isnt any air in the shocks if im changing oil
Old 08-07-2007, 12:50 PM   #274
So I just fill them to the top, screw the cap on and work the shock to push the excess out? That sounds way too easy...
-rocky b
Old 08-07-2007, 12:55 PM   #275
Trader Rating: 14 (100%+)
not even, just fill them to the top and screw the cap on tight, all the excess oil bleeds out the hole. Just make sure the bladders are not ripped or pushed in.
o.s. power is offline   Reply With Quote
Old 08-07-2007, 10:48 PM   #276
i fill mine up flush to top, then push piston up to get air from under piston, might have to put a little more oil in afterwards. then screw cap on 2 turns then turn shock to 45 degree angle with the air hole pointing up. start compressing shock shaft in all the way. then slowly tighten cap turning the body and keeping the hole in cap pointing up and still at a 45 angle. keeping it up allows air out before oil. tighten down and ready to go. just make sure you dont over fill the oil to begin with could damage the bladder or cripple it while on the car running. I usually always go a touch under flush to cut down on wasted oil, keep it cleaner as im bleeding air, and make sure I am not overfilling it.
Mike Elam is offline   Reply With Quote
Old 08-07-2007, 11:01 PM   #277
Turbine_au's Avatar
Went to replace a broken arm and noticed that Mugen have changed the front lower arms again. Slightly different moulding. Nothing that's going to add much strength, more like a change to maintain a constant wall thickness for a better final moulding.
It's mine: http://au.youtube.com/watch?v=usYhSWbmx6s
Turbine_au is offline   Reply With Quote
Old 08-08-2007, 07:27 PM   #278
nashrcracer's Avatar
R/C Tech Charter Subscriber
one of the guys at the local track took some video from one of our series races in Burns, TN he jumped around a lot but I think I mixed up one good lap from it. Mugen Mbx5 Prospec with a dynimate 21c. I have more but I'm messing with youtube to get the quality right. still never got my setup for a loomy track. and this was that track. next track hard black dirt with lots of jumps and no straight.
just for reference I'm the white yellow and blue buggy just incase you didn't know my colors
http://youtube.com/watch?v=dlztQCOKmdc
BTW bumped after starting in 4th in the "B" and finished 2 seconds behind 6th in the "A"
RC50 As you come into this world, something else is also born. You begin your life, and it begins a journey towards you. It moves slowly, but it never stops. Wherever you go, whatever path you take, it will follow never faster, never slower, always coming. You will run, it will walk. You will rest, it will not. One day, you will linger in the same place too long you will sit too still, or sleep too deep. And when, too late, you rise to go, you will notice a second shadow next to yours. Your life will then be over.
nashrcracer is offline   Reply With Quote
Old 08-10-2007, 11:46 AM   #279
Trader Rating: 42 (92%+)
any body have good base setups for rough tracks
tires are bowties,crimes m3 compound
icemandolmite is offline   Reply With Quote
Old 08-10-2007, 11:48 AM   #280
also for an rb-s7 motor what shoes and springs should i use
Old 08-10-2007, 11:49 AM   #281
Hrdluck13's Avatar
Trader Rating: 8 (90%+)
Use the Schwartz set up but go 350-300 shocks and
2.75/-1 rear toe plate.
I would say Mugen alum with 2 1.0's and 1 1.1 spring
Hrdluck13 is offline   Reply With Quote
Old 08-10-2007, 11:55 AM   #282
for toe do you mean (-1/2.75 plate)
Old 08-10-2007, 12:01 PM   #283
Hrdluck13's Avatar
no, 2.75/-1 anti squat
Old 08-10-2007, 12:04 PM   #284
that would be the rear hingpin insert holes on the bottom
Old 08-10-2007, 12:06 PM   #285
Hrdluck13's Avatar
you are right sorry... I am doing four tings at once here.When it is rough
2.75/-1 rear plate. Neuteral(middle) on the plastic inserts
MUGEN MBX5R and (THREE) MUGEN MBX5T PROSPECS F/S or F/T nobike R/C Items: For Sale/Trade 11 02-12-2008 11:49 AM
MUGEN MBX5R F/S tshaec5r R/C Items: For Sale/Trade 25 01-14-2008 07:17 AM
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 09:32 AM
Mugen MBX5R Brand New Mugen Hops Ups and More bretzkej R/C Items: For Sale/Trade 8 05-27-2007 05:57 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 06:45 PM
