Old 08-06-2008, 10:02 AM   #61
Ive got the same EXTECH as above..its not bad, just priced a bit high. I also have a Axial pen one and its pretty easy to use, and accurate for the most part//I do like the lanyard that is supplied for it.
DS
Darth Smoke is offline   Reply With Quote
Old 08-06-2008, 01:55 PM   #62
Can someone explain the water/spit method on the cooling head? What kind of results are you looking for? If you do not want to use spit, will a water dripper (like the kind for eye drops) work? How accurate are the results and is there any difference between water and spit?
rccarracer15 is offline   Reply With Quote
Old 08-06-2008, 02:04 PM   #63
Spit may have a slightly higher boiling point, but not much so either should work. Just like a temp gun, should be used as a backup to visual and audible clues as to how the engine is running.
It sets there and does nothing. Running cool, under 212 Degrees F. May need to lean it out a bit.
Slowing boils off. About right, at least in the ball park for most engines.
Jumps all around and flashes off. Most likely too hot.
Ed M.
bentgear is offline   Reply With Quote
Racers Edge HIGH TEMP BRAKE DISCS Vsfriedmugan Nitro Off-Road 0 08-11-2008 04:53 PM
WTT Racers Edge Glow igniter -4- Temp Gun Marzac2 R/C Items: For Sale/Trade 2 03-17-2008 09:12 PM
FS NIP VENOM SMART/ TEMP (fail safe and on-board temp gauge) factory racer R/C Items: For Sale/Trade 7 07-02-2006 10:49 PM
HELP NON RACERS HELP MORE THAN RACERS SO WAKE UP ALL YOU OFF ROAD RACERS IN MELB/VIC richard 1000 Australian Racing 15 06-20-2006 10:35 PM
By The Racers For The Racers July 12 Hobbytown Glen Burnie pusher R/C Items: For Sale/Trade 9 07-09-2003 07:13 PM
