Old 06-03-2007, 12:28 PM   #1
Trader Rating: 26 (100%+)
Send a message via AIM to cheesecake
Default losi xxxnt axle pin problem
i keep snapping the pin on my right rear tire. how would i stop that from happening. ive been through 3 and it has destroyed a wheel every time
cheesecake is offline   Reply With Quote
Old 06-03-2007, 10:34 PM   #2
gubbs3's Avatar
Try not cranking down on the wheel nut too hard. Snug is fine, it doesn't have to be muscled on there. Breaking one here or there over a long period of time is one thing, but there is definitely something not right in your case. It's got to be either too tight, or if you have an .18 in it, that would also be the problem.
gubbs3 is offline   Reply With Quote
Old 06-04-2007, 02:55 PM   #3
AzBobby's Avatar
actually it would lead me to believe your wheel nut is either loose or coming loose during driving. and i would replace the wheel nuts. if it in place and tight it will be extremely difficult to break the pin. but when it is loose and the wheel is moving in and out as you land off camber and during turning it would stress the pin and then cause it break. also a loose nut will strip the inside of the wheel as you described. you could also look to a solid pin instead of the rolled pin that it comes with. however you find one that fits tight and everytime you remove the wheel you have to ensure not to let it fall out and lose it in the dirt.
AzBobby is offline   Reply With Quote
Old 06-05-2007, 04:32 AM   #4
if your slipper is too tight you will break those pins too, not saying thats your problem but it might be something for you to check.
T Green is offline   Reply With Quote
Old 10-09-2008, 02:00 PM   #5
RC Dad's Avatar
Send a message via MSN to RC Dad
Been there before. Even tried roll pins but they deformed also until I found the problem. Make sure you put the factory spacer between the bearings on the rear axle so the inner races provide something firm to tighten the nut against otherwise the wheel can be putting alot of stress on the pin when it's tightened rather than on the washer behind it. Forgetting this spacer will either bend or bust the pin or elongate the hole so the pins slide back and forth causing minor wheel wobble. It also greatly shortenes the life of the bearings.
GV2 Pro, XXX4G+, Blitz SCT, CRC GenXL
RC Dad is offline   Reply With Quote
O.S. .12 TR setup for Losi XXXNT and other XXXNT Parts GroffBall R/C Items: For Sale/Trade 4 09-30-2006 07:06 AM
Losi XXXNT Frogster R/C Items: For Sale/Trade 3 07-20-2006 05:18 AM
LOSI XXXNT Racer Reg R/C Items: For Sale/Trade 1 04-01-2006 05:00 PM
RS4 3 AXLE problem help 2Hard2Handle Nitro On-Road 2 04-01-2003 09:38 PM
Losi XXXNT, NXT & JR XR3 FS/FT coastaltony R/C Items: For Sale/Trade 0 11-20-2001 10:12 AM
