anyone ever mix and match P/S sets?
i have 2 worn out P/S sets. But when i swap the pistons they have a pretty good fit.
Is it possible for this to work? I don't see why not. It can see it will have really good compression, maybe even pinch but have not installed them yet.
but has anyone ever tried this?
And to be more acurate i have a sleeve that is less worn the fits really well with a piston from a completely worn out sleeve.
Well it is the piston that wears faster than the sleeve, that's why ultimately why sleeve pinching works. You're shrinking the sleeve down to the size of the piston. If the fit is right it should work just fine, I would run that motor rich for two or three tanks to be safe.
like what is the worst that could happen, it not work? or it blow? well if blows its like oh well it was two worn out engines anyways. i took a C6 that hade a ruined crank case and put it in a GRP crank case that had a bad rod, crank, and piston/sleeve. it ran ok i actually ran it at the track one day, but it blew at the house when i was trying to get some more bottom out of it, i just laughed and said oh well atleast i tried to make a running engine out of two broken ones.
So yeah dreaux, you can do that just fine! But be careful like Monty said. You don't want to get it too tight! That can cause some problems.
i have another odd question. If you are looking through the exhaust port and watching the piston go up sleeve you see a couple tiny bubles just for a second. is that normal? I hardly ever look through the exhaust port anymore. I has a crap ton of compression, but maybe they have scratches?
If the engines are bought at the same time you can give it a try. If not then there is a chance different materials are used and so the expansion rate of the piston and sleeve would not match.
I have played with it in the past but the results were mostly a bad running engine or a fast wear on the piston. You will be more save with pinching with the result you will have 2 working P/S sets
I swapped p/s on an old sportwerks.26 It was real tight, so I re-broke the motor in. Ran it on the rich side for the first gallon but as soon as I got it leaned out(240 range), it shot the rod out the side of the case. To me it was funny as hell and it made real cool sound when it blew. If i was to do it again I would go with pinching.
First of all you must make sure you have a piston from another p/s set that is the same as what you are rematching to. You can't take a novarossi piston and put it in an OS engine or whatever ( btw that would never work and was thrown out ther just for example )
I rematch from novarossi , almost all the pistons are the same aside from a few engines that have different bore/stroke ratios . If done properly this method yields the perfect p/s set , trust me .
I am in no way telling you guys to go out and rematch until your hearts content but never be afraid to try something if you think its logical .
