Old 06-02-2007, 05:49 AM   #1
tkhoo's Avatar
Trader Rating: 45 (98%+)
Send a message via MSN to tkhoo
Default MBX5 Prospec.
Hi all, I have problem on my MBX5. She understeer , what are the thing I need to adjust, please advise as I am new on buggy. Thanks in advance.
1/8 scale buggy: HB D8, Truggy: 1/12 Jammin CRT.5
Radio: Sanwa M8 power by Sanyo Eneloop, Charger: Hot Power 6016
http://pgrcclub.blogspot.com/
tkhoo is offline   Reply With Quote
Old 06-02-2007, 08:38 AM   #2
shimmyz's Avatar
Your sig states you run touring car. I am new to RC all together but I use a friends hudy touring car setup guide (it comes with the setup station). The same priciples carry over from touring to off road.
shimmyz is offline   Reply With Quote
Old 06-02-2007, 09:33 PM   #3
tkhoo's Avatar
Hi you mean using 1/10 setup station to setup the buggy? If yes, so what should I adjust for to make it not too understeer.........Thanks.
Old 06-02-2007, 10:04 PM   #4
schmelme's Avatar
He means a book that comes with the setup station its a guide for setup changes.
Does the car lack turn in? push under power? In the fast sweepers or tight sections?
Post some of you setup in the car. Mainly diff oils, toe & camber settings. Shock locations. And a big one is do you have the right tires?
schmelme is offline   Reply With Quote
Old 06-02-2007, 11:20 PM   #5
tkhoo's Avatar
Hi thanks for taking your time to reply/ helping me
By the way I am newbie on buggy......I bought her 2nd hand and dunno all the setting as well. I just bashing around sandy field and when turn it take big round to turn.......So can you advise what is best diff oil I need on F/M/R and I try to change and the chamber and toe I needed. thanks in advance.
Old 06-03-2007, 03:29 PM   #6
schmelme's Avatar
Diff oils start with 5k-5k-2k. Shock oils 35wt front 40wt rear. Make sure you have a decent servo and the servo saver is set correctly this can cause a major lack of steering. Camber start with -1.5 front -2.5 rear. Toe out 1degree in the front. Front caster shims middle. Rear toe 2.5degree.
Old 06-04-2007, 08:44 PM   #7
Nitroaddicts's Avatar
Here or Here
Themanuals are great to read over and over and over.
Nitroaddicts is offline   Reply With Quote
Old 06-08-2007, 05:52 AM   #8
tkhoo's Avatar
Thanks schmelme and Nitroaddicts. I will try on above setting. By the way servo saver issit the place on steering which got spring type?
Old 06-09-2007, 12:11 AM   #9
tkhoo's Avatar
I got the answer already. thanks anyway
Old 06-09-2007, 01:14 AM   #10
Thumbs up
Hi guys, I have a brand-new in the box MBX-5 before I put it together I would like to install all the part to make it prospec, can you tell me what parts I would need . or where I can go to find out. Or even a hobby shop that might have a package deal for it. Or if somebody could tell me the parts.I wouldn't appreciate it. Thank you where
rc10bob is offline   Reply With Quote
Old 06-09-2007, 02:45 AM   #11
Turbine_au's Avatar
http://www.carolinasrc.com/Webstore/...idcategory=466
It's mine: http://au.youtube.com/watch?v=usYhSWbmx6s
Turbine_au is offline   Reply With Quote
Old 06-09-2007, 08:10 AM   #12
Turbine, What can I say. Thank you. Great.
Old 11-04-2010, 03:07 PM   #13
eric316's Avatar
aaaaaaaaaaaaaaaa
eric316 is offline   Reply With Quote
FS Mugen MBX5-T Prospec & MBX5-R Both less than 3 gallons! V-Spec Less than 1 gallon! ffpm46 R/C Items: For Sale/Trade 20 08-01-2008 06:27 PM
Feeler Thread Mugen MBX5-R & Mugen MBX5-T Prospec ( both less than 3 Gallon ) FS ffpm46 R/C Items: For Sale/Trade 4 07-28-2008 10:22 AM
whats the difference mbx5 prospec / mbx5 r lynell90 Nitro Off-Road 6 04-24-2008 02:31 PM
mbx5r mbx5 prospec or mbx5 PARTS johndayo101 R/C Items: Wanted to Buy 2 01-14-2008 12:52 PM
MBX5 or MBX5 PROSPEC? Realworld differences? Jeel Electric Off-Road 5 12-05-2004 07:46 AM
