Old 06-01-2007, 04:55 AM   #1
Default Hyper 8 Pro's Mach 21 engine issue..
hey,
Just came back from a run-in of my Mach 21 engine..Got a query to ask:
Noticed that after a tank of nitro, realised that my engine will often emit a loud pitch sound, sounds like a high idling sound, it's tends to goes back to normal idling sounds a few seconds after a complete stop of the buggy..
Is this normal? if not what could be the problem.
Pls advise and thanks in advance.
regards.
viperviper is offline   Reply With Quote
Old 06-01-2007, 10:48 AM   #2
Jason Halvorson's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to Jason Halvorson Send a message via MSN to Jason Halvorson
my novarossi P5X does this....i havent had any problems with the engine, and i have over 2 gallons of 30% through it...
08 Sponsors Thank you for all your support!!!!
TEAM OCM USA
TEAM GO TECH
TEAM PRO TWISTER MODS
TEAM VP PRO TIRES
OCM RACING DT-19 EVO, GO TECH ENGINES PTM'ED
OCM RACING DT-19T PRO, GO TECH ENGINES PTM'ED
Jason Halvorson is offline   Reply With Quote
Old 06-01-2007, 06:34 PM   #3
In this case, it should be normal then.. thanks Jason.
Old 06-01-2007, 11:33 PM   #4
well i dont know if its normal, but just hasnt caused any problems for me....
TEAM OCM USA
TEAM GO TECH
TEAM VP PRO TIRES
Old 06-03-2007, 02:51 AM   #5
MadRacer's Avatar
Trader Rating: 33 (100%+)
Change to a OS P3 plug will have to retune i say.
Never have that problem with myn.
MadRacer is offline   Reply With Quote
Old 06-03-2007, 07:08 AM   #6
hey MadRacer, I'm using OS P6 (Hot).
1. Can P3 fit into this turbo engine? ie is this P3 plug a turbo glow plug?
2. Btw, u hv experience this similar problem with P6 plug?
3. Will this do harm to the engine if i continue to use the P6 plug?
4. Do u know what is the cause of this problem, any reasons or explainations?
Pls advise. thanks.
Old 06-03-2007, 10:18 PM   #7
MadRacer's Avatar
Pls advise. thanks.
Cant explain why it does it but i have had no issue like that useing a p3 plug.
Yes its Turbo or it wouldnt fit in mine either.
The P3 is a hotter plug and comes standard with the OS V SPEC. It is a very popular plug in off road. Being hotter it has better idle characteristics .Unfortunately mine has died . Good luck.
Old 06-04-2007, 05:31 AM   #8
Thanks. Will get the P3 glow to try it out.
Hyper 8 Pro's Mach 21 engine issue.. viperviper Singapore R/C Racers 2 06-04-2007 07:52 AM
mach 28 engine tune issue v1r killer Australian Racing 4 05-18-2007 05:24 PM
F/S,F/T NEVER USED HYPER 7 PBS W/ MACH 28 frankiecmgt R/C Items: For Sale/Trade 1 03-27-2007 04:56 AM
HPI F4.1 vs Hyper 28 Mach Engine foaley77 Monster Trucks 0 01-15-2007 04:42 AM
FS: hyper 7 pcr pro with mach 21 rtr 12a_rx2 Australia For Sale/Trade 4 01-01-2007 06:38 PM
