Old 06-26-2007, 07:35 AM   #106
LKH
LKH's Avatar
Send a message via Skype™ to LKH
Thumbs up 24/6/2007 Team OCM Kaos DT-19 Champion in Miri, Malaysia
3rd
5th
LKH is offline   Reply With Quote
Old 06-26-2007, 08:15 AM   #107
yet another win for the ocm, just keeps getting better.
simon H
flysti is offline   Reply With Quote
Old 06-26-2007, 09:02 AM   #108
speedy2's Avatar
you mean adding in a 0.7 to existing setup? What benefit did you gain from doing this?
no to replace one of the 0.5 mm ocm shimms by a 0.3 shimm
to create more free shock movement
speedy2 is offline   Reply With Quote
Old 06-26-2007, 08:11 PM   #109
devious17's Avatar
no to replace a 1.0 mm ocm shimm by 0.7 shimm
Thanks for the tip
Audio,Video, Disco
devious17 is offline   Reply With Quote
Old 06-27-2007, 11:04 AM   #110
speedy2's Avatar
here is a good starting point
Diffs 5,5,2
drill pistons in shocks to 1.5 Standard 1.4
40wt oil front and back
Rear toe 2.5 -3 deg
Rear Camber 3 deg
Rear shock position top is 2 out from inside and on lower arm inside position.
Rear upper arm inside middle position on shock tower and middle on upright.
1.25 insert facing up for anti squat.
Rear upright position bottom hole.
Medium long wheel base.
front lower arm anti dive 1.25 insert down
front inboard toe. No 1 insert in
Run Full caster and dial out when more steering required.
Steering knuckle inside hole
Front Camber 1 Degree
Front shock position up top is 2 out from inside and inside hole on lower arm.
As a side note I've been messing with set-ups mostly due to lasyness on my behalf but I've now done 2 race meets on dirt with 30k in centre 20k in front and 10k diff oil in rear and was able to dial aggressiveness out of car with geometry. It really does respond well to geometry changes.
I will be going back to original set-up, but I found it was just a good learning curve for me with geometry and driving a difficult car.
The guys on RC net have some good set-ups too try this OCM Kaos DT-19 build pics +50 Pics
_________________
Kev Lewis
O.C.M Australia
Old 06-27-2007, 11:05 AM   #111
speedy2's Avatar
got some input from Australian pilot Nick Drygala
diff meshing: I was running 2 shims on the pinion and 2 on the diff
to mesh closer. Also I was running 8 shims inside the diff instead of
4. Made it very nice and smooth.
Set up : the 1.5mm hole shock pistons try 45 front and 40 rear.
I was using OCM white spings on front and Hong Nor red springs on rear.
Diff 3000 front 7000 centre and 3000 rear.
Spoke to Ian HALEY last night,
He run a strange set up which He said was hard to drive but fast.
1000 in front diff 3000 in centre and 750 in rear.
35 shock oil all round with 1.5mm pistons
Hong Nor red shock springs all round
2.7mm front sway bar
2.8mm rear sway bar
The rear uprights were MUGEN and he said that worked very well.
Old 06-30-2007, 07:56 AM   #112
LKH
LKH's Avatar
Thumbs up
Results Final A Main
1. Lai Kok Heng / OCM Kaos DT-19
2. Chai Kok Chen / Nanda
3. Foo / OCM Kaos DT-19
4. Simon Yii / Nanda
5. Sunny Wong / OCM Kaos DT-19
6. Ah Chor / Hyper 8
7. Alvin / Hyper 8
8. Alexius Lee / Hyper 8
9. Lim Kok Beng / Hyper 8
10. Eric Lim / Hyper 8
LKH Model Sports :Wisma Gorasia , No.14 B, Jln Pahang Barat, 53000 KL ,Malaysia Tel/Fax:603-40225552H/P:6016-2216319 [My website: http://www.lkhmodelsports.350.com/home.htm]
Email :lkhmodelsports58@gmail.com Skype name:lai.kok.heng
(Agama,Jammin,STR8,Serpent,Edam)(BETA,LOUISE ,ART,VP-PRO,Proline,Matrix,GQ)(Alpha,Argus ,RB,,NRS,JP,,SH)(JVD)(Nitro-X)(Max-racing)(ARROWMAX)(Fitec Servo)
Old 07-02-2007, 11:00 AM   #113
KForce's Avatar
Trader Rating: 2 (75%+)
Congrats to Billy Easton for putting his RB Powered OCM into the A-Main at the roar buggy national. He also finished 10th overall in the main. Look out worlds!
Team TQ Fuel
OS Speed Engines
Futaba
Panther Tires
CRCRC Raceway Webmaster
FullThrottle Raceway Webmaster
KForce is offline   Reply With Quote
Old 07-02-2007, 11:16 AM   #114
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
Great to see new brands geting high level results on big races. Good luck on the worlds OCM ...
cya,
Patricio "PATO" Concha
E-Mail : pato_concha@yahoo.com
Facebook : http://www.facebook.com/patoconcha
Whatsapp : +56 9 66165085
Tabushi is offline   Reply With Quote
Old 07-03-2007, 08:49 AM   #115
KForce's Avatar
thanks for the positive comments
Team TQ Fuel
OS Speed Engines
Futaba
Panther Tires
Old 07-06-2007, 09:30 PM   #116
devious17's Avatar
DT-19 is coming out with new option chassis, new steering plate and cnc rear wheel hub, anyone got any info on these items especially the option chassis?
Audio,Video, Disco
Old 07-07-2007, 06:10 PM   #117
pumpkinfish's Avatar
Hey guys my hobby shop just got a buggy in and they know nothing about it. How are yours holding up after some use? Any problems in terms of common broken parts each race? Hows the plastic? I had an Ofna that the plastic just got trashed quickly, I felt like I was always rebuilding the thing
How about support in terms of setups and parts availability?
What buggy would you say this drives the closest to? I have driven Hyper 7, Jammin and Losi 8ight. I actually liked the way the Hyper drove the best. It allowed me to be aggressive when needed and took it like a mule. Is this buggy's driving characteristics similar or more like the 8ight where you need to be patient (of which I admittedly have little)
Yokomo YZ-2, B-Max4 III
Kyosho RT6
Losi 22b, XX4 Worlds
Associated SC10.2, RC10B2, RC10T2, RC10
pumpkinfish is offline   Reply With Quote
Old 07-07-2007, 10:52 PM   #118
Send a message via MSN to DaRaceMasta
wow thats mad azz to hear all this positive info about the buggy, just picked up my OCM this week on thursday just waiting on my gear to arrive.
(VOID TO BE FILLED SOON)-6MIK Racing- REDS 5TE2-Ninja JX21 BO2-REDs Quattro Clutch C&Alu shoes - Highest DT1100- Airtronics mt4
HIPEX 2108 M Manifold - Podified Race Blend Fuel
DaRaceMasta is offline   Reply With Quote
Old 07-07-2007, 11:09 PM   #119
devious17's Avatar
If that is your driving charactoristics then this IS the buggy for you. It is the most robust buggy that I have ever owned and can take punishment way better than a mule
Mine is about 4 race old and about a gallon nitro for training has gone into my DT-19 and I have not changed a single part on the DT-19.........except the wing
Parts availability is dependent on your LHS I think as for my LHS no worries with parts at all.
Checkout the video in this thread and you will see how effortlessly high and far the DT-19 can jump. There were some diff gear tolerance issue sometime back but that has been sorted out.
Audio,Video, Disco
Old 07-08-2007, 05:02 AM   #120
mad set up, gotta love the OS Speed, how is that running? was thinking of grabing one myself but its a bit expensive for a modded V-spec, 569AUD, good to hear that the OCM is getting good results , im itching to get out with my new race gear this weekend should be good.
Some build pics of the Baja SS Wicked Oval, Larger Scales and More 14 07-10-2008 07:31 PM
OCM Kaos DT-19 ARR PICS!!!! nik77356 R/C Items: For Sale/Trade 34 05-21-2008 09:37 AM
OCM KAOS DT19 EVO /W EXTAS $185 PICS slow supra R/C Items: For Sale/Trade 4 03-28-2008 06:18 PM
TC5 Pics ghuber Electric On-Road 39 01-18-2007 07:53 AM
Build up Pics....???? cossie Nitro On-Road 3 01-25-2005 11:40 AM
