Old 06-19-2007, 02:42 PM   #91
Trader Rating: 36 (100%+)
Website is
http://www.freewebs.com/obsessedfx/index.htm
Thanks for the compliments I don't feel it would be appropriate to divulge what he charged me, but lemme just say that for the skillz he posseses, I was probably undercharged
NitroOB4You is offline   Reply With Quote
Old 06-19-2007, 03:33 PM   #92
that green on the body is very nice...what is it?
flysti is offline   Reply With Quote
Old 06-19-2007, 03:54 PM   #93
Not sure. I'll drop Jerry an email and post back what he tells me.
Old 06-19-2007, 07:45 PM   #94
Trader Rating: 19 (100%+)
Guys, Here is a set up that I have been running.
FRONT : 5000wt
Shocks. 45wt
Spring. Mugen Grey
Piston. 1.6 mm
Tower. Middle hole
Arm Loc. Inner hole
Fr. insert .5 in
Fr. antidive 1.0 up
Fr. upper arm .5 down
Upper arm clip -- Small frt. / Large in rear
Swaybar 2.3 , Track width 274 mm
Camber -2.0 deg
Ackerman. Middle hole
Toe 1 deg out
CENTER : 7000wt
Brake 40% fr / 60 % rear
REAR : 3000wt
Shocks. 35 wt
Spring. Mugen Grey
Piston. 1.6 mm
Tower. 3rd hole from inside
Lower. Outer hole
Rear Antisquat. .5 up
Rear Toe .75 out
Swaybar 2.8
Hub Location. 4mm spacer fr. / 2mm spacer rr.
Rr. Linkage. Inside middle on tower, Middle hole on hub
Camber -2.5 deg
Brandon Powell is offline   Reply With Quote
Old 06-20-2007, 02:02 PM   #95
We just got more Parts and Kits Instock. Please check out our website..
www.rcprocenter.com
Check out our site and SAVE!!!!
rcprocenter is offline   Reply With Quote
Old 06-20-2007, 07:14 PM   #96
This is quoted from the email response I got from him a few minutes ago.
"just a custom mix. A combination of candy green, yellows & green/gold pearl"
He also stated that he is somewhat behind and isn't in a rush to take on new work. It may be worth contacting him anyway, just to see.
Old 06-20-2007, 07:44 PM   #97
Glad to see you have the OCM line! Were are you guys location, nice online site by the way.
Old 06-20-2007, 08:40 PM   #98
no thats fine, i am in australia so having a body painted in the states is not ideal more interested as to what color it was, even thought i run red, black & white on my bodies.
secret ingredients can be left your painternice color.
Old 06-20-2007, 10:42 PM   #99
devious17's Avatar
Brandon, are you running mugen shock system as well? I know that the OCM springs are different in diameter from the mugens.
To stiffen my stock DT-19 springs I "elongated" the springs manually to about an inch from standard while waiting for the option springs to arrive
Audio,Video, Disco
devious17 is offline   Reply With Quote
Old 06-21-2007, 05:55 AM   #100
KForce's Avatar
Trader Rating: 2 (75%+)
yea i contacted jerry he said mid to late july before he can take anymore work on.
Team TQ Fuel
OS Speed Engines
Futaba
Panther Tires
CRCRC Raceway Webmaster
FullThrottle Raceway Webmaster
KForce is offline   Reply With Quote
Old 06-21-2007, 05:44 PM   #101
devious17,
I am running the OCM shocks stock all but the springs. To get more "downtravel " in the front use the middle hole on the tower and inside on the arm. Unthread the shock eyelet a few turns from all the way tight to lengthen it. The I set the droop screw on the arm so that the piston doesn't bottom out inside the shock. The Mugens just happen to be laying around and I new the were stiffer.
Hope this helps.
BP
Old 06-24-2007, 04:26 AM   #102
speedy2's Avatar
http://i45.photobucket.com/albums/f6...2/XR358012.jpg
xb8plastic shockshimms are perfect fit
they come in 1.3 and 0.7 mm dickness
ocm are 2x 1.0 mm
so I put still a 0.7 mm shimm between the shock internal o-rings
to create more free moving shocks
speedy2 is offline   Reply With Quote
Old 06-24-2007, 06:32 AM   #103
devious17's Avatar
you mean adding in a 0.7 to existing setup? What benefit did you gain from doing this?
Audio,Video, Disco
Old 06-26-2007, 02:44 AM   #104
Default Good Stuff Guys
Hi guys, Good to see all are happy with the OCM's ever there. It's Also really good to see you guys helping each other out with set-ups etc. The car is truely awesome hey.
I'm the distributor in Australia for OCM along with Theo Assa a.k.a The "T" in the DT-19
And... Kaos.... Well, You just gotta meet the guys
Kev Lewis,
I'd like to thank my personal Sponsors :-AKA Tyres Australia, Ryper Hobbies and Just Hobbies
The Gear :- Associated RC8 B3 powered by OS Engines
Soapy is offline   Reply With Quote
Old 06-26-2007, 05:07 AM   #105
LKH
LKH's Avatar
Send a message via Skype™ to LKH
Thumbs up
LKH is offline   Reply With Quote
Some build pics of the Baja SS Wicked Oval, Larger Scales and More 14 07-10-2008 07:31 PM
OCM Kaos DT-19 ARR PICS!!!! nik77356 R/C Items: For Sale/Trade 34 05-21-2008 09:37 AM
OCM KAOS DT19 EVO /W EXTAS $185 PICS slow supra R/C Items: For Sale/Trade 4 03-28-2008 06:18 PM
TC5 Pics ghuber Electric On-Road 39 01-18-2007 07:53 AM
Build up Pics....???? cossie Nitro On-Road 3 01-25-2005 11:40 AM
