Old 05-31-2007, 08:44 PM   #31
KForce's Avatar
Trader Rating: 2 (75%+)
i am at all the midwest proseries races and there will be a slew of us at the buggy nats
kyle
Team TQ Fuel
OS Speed Engines
Futaba
Panther Tires
CRCRC Raceway Webmaster
FullThrottle Raceway Webmaster
KForce is offline   Reply With Quote
Old 05-31-2007, 10:40 PM   #32
Local racer's Avatar
Default Comparison to the Mugen
I have driven the mugen line of cars for a very long time,I recently switch to the ocm and here are the diffrences that I see.The ocm has more acceleration then the mugen and also more on power corning ability,they both are very stable and jump about the same.
The mugen r car comes with all 5mm parts and the ocm has 4mm parts ocm uses eccentric bushings and the mugen dosent.
Overall I think both are very good cars but I have been able to go faster with my ocm it seems to carry more corner speed with good corner exit traction
http://www.tqracing.net
Local racer is offline   Reply With Quote
Old 06-01-2007, 07:46 AM   #33
KForce's Avatar
awesome thanks for the post. glad to see the opinion of someone who has driven the R. the ocm does like to be driven fast
Team TQ Fuel
OS Speed Engines
Futaba
Panther Tires
Old 06-01-2007, 08:09 AM   #34
KForce's Avatar
heres the setup i am currently running. any more of you ocm guys post yours away
Technical. Bumpy. Medium traction.
All I have been adjusting between tracks is spring preload.
Usually Run Bowties, m2 when dusty, m3 when a little slick. When track grooves in I will switch to Holeshot m2 or panther switch soft.
Diff Setup (front to rear) 5000-5000-2000
Brake Setup 40/60 I like more rear brake to make the rear pivot better in the corners.
Front Of Car
Front Toe 0 Blocks
Front Kickup 1 Up
Front Arm 0 (In shock tower)
Big Clip in rear of arm, thin in front against shock tower Shocks 2nd hole down on tower / inside on arm 1.5mm Pistons with 400 oil
2 degrees toe out
Bottom pillow ball no threads showing. Top adjusted to -1 degree camber.
Shock spacers vary just so the arms sit level.
Steering ackerman middle hole. On the steering knuckles 2nd hole.
3mm Sway bar preload
Rear Of Car
Rear Kickup 0.75 going up
Rear Toe 0.75
Shocks 2nd hole down on tower / outside on arms 1.4mm Pistons with 300 oil Shock spacers vary just so the arms sit slightly above level Camber links inside middle hole on shock tower. Middle hole on hubs.
-2 Degree Camber
Hubs outer hinge pin through the bottom hole of hub.
11mm Sway bar preload
Wing JConcepts HD
Kyle
Team TQ Fuel
OS Speed Engines
Futaba
Panther Tires
Old 06-01-2007, 08:49 AM   #35
devious17's Avatar
Originally Posted by Brandon Powell
mugenlife, The suspension on the OCM looks good. The stock kit comes with 1.4 mm pistons and we are drilling them to 1.5 mm. No binding at all and the shocks are very smooth.
BP
Coincidently, we were testing with various teflon and O ring on the shocks and found the best combination that would make the shock shaft move freely without leaking,we are also looking at other spring brands for their better spring rates. We 'll take some pictures to illustrate it.
Audio,Video, Disco
devious17 is offline   Reply With Quote
Old 06-01-2007, 10:29 AM   #36
what kind of down travel does the suspension have?
Mugen MBX5R - retireded Passion
22 3.0 SR Hobbywing 3.1 Stock Spec Trinity 17.5 24k Reilley Motorsports
B6 Hobbywing 3.1 Stock Spec Fantom
22 SCT 2.0 Exotek Hobbywing 3.1 Stock Spec Fantom
Tekno 410SCT Hobbywing ProSC
mugenlife is offline   Reply With Quote
Old 06-01-2007, 11:56 AM   #37
Default Travel
The travell in the rear matches the mugen r car the front could use more travell,I have heard they have a new taller front shock tower and longer front shocks
1/8 racer is offline   Reply With Quote
Old 06-01-2007, 12:19 PM   #38
KForce's Avatar
not sure about the shocks. there is a new front shock tower in the works that will give the front more droop though i do know that.
Team TQ Fuel
OS Speed Engines
Futaba
Panther Tires
Old 06-01-2007, 12:23 PM   #39
KForce's Avatar
here is a pic. the buggy is sitting on 2 parts cases fishing tackle box deals. the other 3 wheels are all touching the floor.
Team TQ Fuel
OS Speed Engines
Futaba
Panther Tires
Old 06-01-2007, 08:07 PM   #40
Trader Rating: 19 (100%+)
Hey guys, how are you build the bottom side of your shocks ?
o ring , spacer , o ring , spacer ??
Also, we are drilling our pistons at 1.5 mm and 1.6 mm on our set ups. I noticed 1.4 in some posted.
Brandon Powell is offline   Reply With Quote
Old 06-01-2007, 08:13 PM   #41
KForce's Avatar
oring-oring-spacer......leave one spacer out it will free the shocks up tremendously.
and yes i run 1.5mm in the front with 400 and 1.4mm in the rear with 300. i run the 1.4mm in the rear because i like to run light oil.
kyle
Team TQ Fuel
OS Speed Engines
Futaba
Panther Tires
Old 06-01-2007, 08:13 PM   #42
I am using the center hole on the upper mount ( front tower) , inner hole on the A-arm mount. Unscrew the shock end so that the total shock length is 108.3 mm total. Mount the upper of the shock first and then drop the eyelet in the lower a-arm and adjust droop til the eyelet matches the inner hole on the arm. This will give you maximum droop without stressing the piston in the shock. You should have more droop after doing this.
Old 06-01-2007, 08:15 PM   #43
KForce's Avatar
and yes i unscrew my shock ends so that 4 threads are showing. then bump your droop screws just enough that it takes the stress off the shock
kyle
Team TQ Fuel
OS Speed Engines
Futaba
Panther Tires
Old 06-01-2007, 08:39 PM   #44
Cool, We are doin the same with the spacer and the droop . Suspension is butter smooth. I will be running it tommorow at a point series race and look forward do seeing how it does.
Old 06-01-2007, 08:54 PM   #45
Trader Rating: 36 (100%+)
I drilled my pistons with a 1/16" (1.59mm) bit. I also run minus a spacer, as Kyle stated. AE 35F /30R. Brandon, thx for the install tip. I am using the same mounting points, but did mine opposite...bottom first. Ill try the top first when I wrench a little tomorrow. Can you explain the shock length though... 8.3mm? I may be missing something but that doesnt make sense to me. What points are you measuring? Or is that a typo? Maybe 83mm?
NitroOB4You is offline   Reply With Quote
Some build pics of the Baja SS Wicked Oval, Larger Scales and More 14 07-10-2008 07:31 PM
OCM Kaos DT-19 ARR PICS!!!! nik77356 R/C Items: For Sale/Trade 34 05-21-2008 09:37 AM
OCM KAOS DT19 EVO /W EXTAS $185 PICS slow supra R/C Items: For Sale/Trade 4 03-28-2008 06:18 PM
TC5 Pics ghuber Electric On-Road 39 01-18-2007 07:53 AM
Build up Pics....???? cossie Nitro On-Road 3 01-25-2005 11:40 AM
