Old 08-09-2007, 11:06 AM   #121
freefallmarine's Avatar
Anyone else's vg like it at 250/260deg? Mine like's it hot and still has lot's of smoke and when i opened it up to clean it, it was spotless.
freefallmarine is offline   Reply With Quote
Old 08-09-2007, 08:40 PM   #122
wb-racer-ace's Avatar
Trader Rating: 28 (100%+)
Send a message via Yahoo to wb-racer-ace
my VG seems to run the best around 250. ran a 10 minute main, then bumped up to the next main with 2 minutes to fuel up and ran another 15 minutes at 250 without a problem
wb-racer-ace is offline   Reply With Quote
Old 08-10-2007, 07:26 AM   #123
Keep an eye on those bearing's!!
Old 08-11-2007, 01:47 PM   #124
I was running yesterday, and around the 3 minute mark of the heat, it felt like the motor richened up and cut off after a jump. Bad plug?? We tried to restart it, but it sounded like it was running out of fuel???
derricklong38 is offline   Reply With Quote
Old 08-12-2007, 09:37 AM   #125
R40Victim's Avatar
R40, how much did the temp's drop?
Sorry it took so long to answer you, I hadn't checked back on this thread in a while. It dropped the temps about 20 degrees, pretty impressive.
R40Victim is offline   Reply With Quote
Old 08-13-2007, 07:08 AM   #126
Hey, guy's a little off topic but, Whats the diffrence between the 06 v-spec and the 07 v spec? How do you tell the diffrence? I was just reading the for sale thread and everyone was requesting the 07 model. I just wanted to know what the hype was. Thank's.
Old 08-13-2007, 04:43 PM   #127
check the carb, mine did the same thing and it ended up being a air leak in the carb, changed the carb, problem was gone
Old 08-14-2007, 10:28 AM   #128
would it be necessary to change the carb, or could i just seal it? Dont really have the money to buy a new carb
Old 08-14-2007, 09:10 PM   #129
Derrick, call OS. it may be covered under warrenty.
Old 08-22-2007, 11:23 AM   #130
ok i havent had a chance to call o.s. yet, im about 250 miles from all my papers. Nothing was sealed and it was the engines first run in race trim. I have a ,money race this weekend on my first weekend back. any thoughts on it? Should i seal it and try to run it or wait and call os?
Old 08-22-2007, 02:32 PM   #131
cornerspeed's Avatar
I just ordered a OS VG HOT MOD from A-Main this morning. Hoping to achieve some good power, but not over kill like my OS Speed is. Would also like to see 10 minutes to a tank. Think that is possible? I still want to run fast, but I am pretty conservitive on the throttle.
Donny Vinkemulder
TLR Driver
TLR 8ight 3.0 - NovarossiUSA - Spektrum DX3R Pro - Losi Nitrotane VP 30% - Losi Lipo Batteries - Proline Tires - DE Racing - EKD Paint
--- Special thanks to: Dyno, Adam, Todd, and Kevin. Horizon Hobby
cornerspeed is offline   Reply With Quote
Old 08-22-2007, 07:51 PM   #132
I have a RB mod's VG in my Losi 8 and get 11 minutes easy. I also had to go up a tooth on the clutch bell cause there's so much bottom end. I need to switch from my Jp-3 pipe to a Jp-2 though. Im sure you will love the new motor!! Good luck with it!!
Old 08-22-2007, 09:13 PM   #133
11 minutes would be cool. I was thinking of my OS 2060 pipe, but I have a JP-3 that I will try back-to-back once its going. So you running a 14T bell? Have you tried a 47T spur?
Donny Vinkemulder
TLR Driver
Old 09-14-2007, 01:23 AM   #134
What kind of life span are you guy's getting from the VG? is this with aftermarket cooling head's or stock? Im praying it's really not a 2 gallon motor....I love mine.
Old 09-15-2007, 10:35 PM   #135
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
I don't think these motors last long. I got one used, installed new Boca bearings, new piston/sleeve, rod, pins & clips. Broke it in on rich setting (fuel rich throttle limited) used only half throttle for 5 tanks (230 average temps), now its been run in the car and tuned for good response while still rich. These motor do not like hot weather & humidity. SoFla weather is killing this thing. Very hard to keep temps under 250 without too rich boggy throttle. Running O'Donnells fuel 20%. Saw upwards of 308 today before shutting it down. Motor seem to lean out when getting hot. Also is mushy in the bottorm end torque area. Will be installing a 13 tooth bell and low end pipe. Mid pipe is OK, but everybody else on the track is killing this motor at local track. I also was told by local guys at track these motor don't last long. Next motor will be back to a Picco/Nova motor. Plus I see way too many used OS motors needing rebuilds or bearings in FS forums.
ezveedub is offline   Reply With Quote
Good car to buy for Beginner MesaRacer07 Electric Off-Road 14 06-30-2008 10:40 PM
Good beginner car? RC-HPI Nitro On-Road 38 08-12-2005 03:12 PM
What car should i buy as a beginner (good engine) rc fanatic Rookie Zone 13 05-27-2005 03:24 PM
HPI RS4 RTR:Good Beginner Car? Alex122488 Rookie Zone 4 12-04-2003 09:50 PM
HPI RS4 RTR:Good Beginner Car? Alex122488 Nitro On-Road 5 11-29-2003 07:09 PM
