Old 06-29-2007, 08:45 AM   #106
Tech Legend
Cain's Avatar
Trader Rating: 233 (100%+)
vr6: give them a call asnd let us know how it goes.
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Cain is online now   Reply With Quote
Old 06-29-2007, 10:02 AM   #107
MannEdge's Avatar
Trader Rating: 19 (100%+)
Originally Posted by freefallmarine View Post
Anyone running king headz, cooling head's? Do you still use os short plug's or do you use standard long's with the new head button?
Carl. did you purchase the new cooling heads for it? Have you notice a drop in temp with the fuel you use? I was running byrons and my temps were high and since the switch in fuel, I am surprise in the drop in temps. Do you run 30%? If so, did you add a shim?
Manny
MannEdge is offline   Reply With Quote
Old 06-29-2007, 10:10 AM   #108
freefallmarine's Avatar
I havent got the cooling head yet. Im debating if i need it, And wondered which plug it would use. How do you like your's?
freefallmarine is offline   Reply With Quote
Old 06-29-2007, 10:13 AM   #109
MannEdge's Avatar
I think it is a great engine. I need to seal my engine. I think I might have a small leak near the carb, but I think you need to do that with any engine. You cannot go wrong with OS.
Old 06-29-2007, 10:15 AM   #110
Im running 30% odonnell with no extra head shim's. Hot plug's also.
Old 06-30-2007, 09:36 AM   #111
Tech Legend
Cain's Avatar
I am running 25%.
Found my problem the darn flywheel moved. The collet is just not grabbing at all. I put a bunch more shims behind the collet to get more bite, and I also ran another shim prior to putting on the screw that holds the whole assembly together. Didn't get a lock up issue when I fired it up a few times yesterday.
Will try it again today around the house since my younger daughter is not feeling well.
Old 06-30-2007, 07:38 PM   #112
Jason Halvorson's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to Jason Halvorson Send a message via MSN to Jason Halvorson
cain, the same thing just happened to me with my werks B7 PRO...I just lock tited the cluch nut and no more problems....
Jason Halvorson is offline   Reply With Quote
Old 07-01-2007, 07:19 AM   #113
Tech Legend
Cain's Avatar
Jason,
Seriously I locktited it really well. The nut actually was a real pain to remove as it was so locked. But looking at the whole assembly, it was as if the flywheel was up too far so the nut was barely touching everything to lock it down.
I hope to test it again today and make sure that it stays.
Old 07-02-2007, 03:04 PM   #114
Anyone getting leaky front bearing's on there VG's? Also, the King Headz VG cooling head use's stock OS glowplug's.
Old 07-07-2007, 01:34 PM   #115
Tech Legend
Cain's Avatar
I am going to check again here after my next run and see, not sure if I got fuel there by accident or its a leak.
what is the process to remove that bearing if you need to?
Old 07-08-2007, 12:23 AM   #116
R40Victim's Avatar
My bearings seem to be fine, and the cooling head is working well. It does take standard plugs. This is the one I got:
http://www.amainhobbies.com/product_...ducts_id/11532
R40Victim is offline   Reply With Quote
Old 07-08-2007, 12:25 AM   #117
R40, how much did the temp's drop?
Old 07-08-2007, 09:38 AM   #118
Tech Legend
Cain's Avatar
Anyone try those Nova heads that are on ebay?
Old 07-20-2007, 02:22 AM   #119
Anyone run a modded vg yet?? My RB Mod's is sick!! I needed a 14tooth bell and a jp-2, it had so much bottom..9 minute's on a loose and slippery track in race condition's so im hoping for some more fuel milage on a tacky track with less wheel spin.
Old 07-20-2007, 06:38 PM   #120
Tech Legend
Cain's Avatar
My last run when really well guys. Car ran great pretty much all day. Have a slight idle issue but that I think is more of a tune thing. I was going about it the right way till I actually messed with the actual idle screw.
My day only came to an end when the pilot screw that holds the whole clutch assembly together came loose.
Great engine.
Good car to buy for Beginner MesaRacer07 Electric Off-Road 14 06-30-2008 10:40 PM
Good beginner car? RC-HPI Nitro On-Road 38 08-12-2005 03:12 PM
What car should i buy as a beginner (good engine) rc fanatic Rookie Zone 13 05-27-2005 03:24 PM
HPI RS4 RTR:Good Beginner Car? Alex122488 Rookie Zone 4 12-04-2003 09:50 PM
HPI RS4 RTR:Good Beginner Car? Alex122488 Nitro On-Road 5 11-29-2003 07:09 PM
