Old 05-09-2007, 04:05 PM   #76
Jason Halvorson's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to Jason Halvorson Send a message via MSN to Jason Halvorson
i also run the same clutch setup as cain, and i must say its really easy to maintain...however i run this clutch combo on a novarossi P5X and it has loads of bottom end punch....
08 Sponsors Thank you for all your support!!!!
TEAM OCM USA
TEAM GO TECH
TEAM PRO TWISTER MODS
TEAM VP PRO TIRES
OCM RACING DT-19 EVO, GO TECH ENGINES PTM'ED
OCM RACING DT-19T PRO, GO TECH ENGINES PTM'ED
Jason Halvorson is offline   Reply With Quote
Old 05-09-2007, 08:19 PM   #77
MannEdge's Avatar
Trader Rating: 19 (100%+)
Originally Posted by Cain
I am running a Hitec HS-5945MG servo. More than enough torque for it. Probably good enough for truggy too.
As for fuel, I run Byrons 25%, but will probably go to 20% here. 30% should be fine. Byrons stuff is top notch.
As for your clutch setup, I would say its buggy dependent.
i run 2 carbon shoes 1.0mm springs, and 1 aluminum shoe, 1.1mm springs. Lots of punch still but not as insane as an all aluminum setup. The engine has load of low end so this smooths it out.
Hey Cain:
Can you share with us the part numbers and where we can purchase your setup at?
Thanks,
Manny
Rcgroups feedback -
http://www.rcgroups.com/forums/traderratings.php?u=78357
MannEdge is offline   Reply With Quote
Old 05-10-2007, 06:06 AM   #78
Tech Legend
Cain's Avatar
Trader Rating: 233 (100%+)
My stuff was a combination of various parted out items I purchased. my Clutch shoes both aluminum and carbon are from CEN. The Matrix RTR comes with carbons.
As for springs, the 1.0mm come with the Matrix RTR, and I also have some from Sportwerks, and the 1.1mm I am using is also from CEN.
You can also do Mugens as well. Since I have no LHS here, I just by from ebay or those that part out.
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Old 05-13-2007, 04:37 AM   #79
MannEdge's Avatar
I ran 4 tanks through it yet, but I had to stop because I noticed my center diff was leaking. Have to order more diff fluids, thank goodness fluid is not on backorder. LOL
Rcgroups feedback -
Old 05-17-2007, 06:29 PM   #80
racer34v's Avatar
Trader Rating: 126 (100%+)
Send a message via Yahoo to racer34v
what are you guys running for ls and hs needle settings?
racer34v is offline   Reply With Quote
Old 05-19-2007, 11:47 AM   #81
racer34v's Avatar
anyone?
Old 05-19-2007, 08:45 PM   #82
pncstod's Avatar
Trader Rating: 24 (100%+)
Send a message via Yahoo to pncstod
Every engine and climate will have different needle settings so getting someone elses may not help you....
pncstod is offline   Reply With Quote
Old 06-08-2007, 05:36 AM   #83
MannEdge's Avatar
This engine is great for the price you pay for it. Especially, now that you can get a rebate on it, plus if you purchase it at Tower you take a discount and free shipping if you are a member.
I put another tank yesterday(total of 5 tanks) and this coming Sunday I will put several more tanks through it because of the race.
Looking good so far!!!
Thanks DAN!!!
Manny
Old 06-08-2007, 10:03 AM   #84
Tech Legend
Cain's Avatar
To confirm to make sure I doing this right, the low end needle is the one on the opposite end from the top end needle on the sliding part of the carb? Its not the very little needle on lower end of the carb right?
How do I find out more about this rebate?
Old 06-08-2007, 01:14 PM   #85
Davidka's Avatar
Trader Rating: 75 (100%+)
Cain, it depends on the engine but the small screw on the bottom of the carb is not the low needle on any engine. That is the idle stop screw that determines the gap when the carb is closed (it actually prevents the carb from closing all the way). The low needle on most engines is on the end of the slide. On an RG it's on the oposite side of the carb. I can't remember if the VG is the same or not.
Old 06-08-2007, 01:15 PM   #86
slakr's Avatar
Trader Rating: 28 (100%+)
Yes the the low end needle is on the sliding part of the carb.
The high end needle is usually pointing upwards and is physically the largest screw.
The other needle on the lower end of the carb is for idle.
There can also be a third needle opposite the sliding part of the carb, but the O.S. 21 VG does not have one of these.
Tower Hobbies-
Place your order of just $50 or more and for a limited time we'll take $20.00 off the total. All you have to do to claim your savings is use ad number 016D.
slakr is offline   Reply With Quote
Old 06-09-2007, 08:29 AM   #87
Tech Legend
Cain's Avatar
yeah I got this in the email too. similar to another that I took advantage of from tower, except it was 20 bucks off order of $100.
Thanks for the info guys!
Old 06-09-2007, 01:14 PM   #88
MannEdge's Avatar
Tower Hobbies-
Place your order of just $50 or more and for a limited time we'll take $20.00 off the total. All you have to do to claim your savings is use ad number 016D.[/QUOTE]
That ad number does not work.
Old 06-14-2007, 07:17 AM   #89
Dan Reino's Avatar
MannEdge...John I know you were concerned about you OS TG running a little hot this past weekend, But worry not when you make the switch over to Rocket Science 30%, I guarantee, your Temp will come way down, and improve gas mileage......I think for the money,they are a good lil engine....
Dan Reino is offline   Reply With Quote
Old 06-14-2007, 09:55 AM   #90
MannEdge's Avatar
Hey Dan, thanks for you input. I notice at the track over the past weekend there was a lot of people running Rocket Science Fuel and I am going to give it a shot.
Manny
Good car to buy for Beginner MesaRacer07 Electric Off-Road 14 06-30-2008 10:40 PM
Good beginner car? RC-HPI Nitro On-Road 38 08-12-2005 03:12 PM
What car should i buy as a beginner (good engine) rc fanatic Rookie Zone 13 05-27-2005 03:24 PM
HPI RS4 RTR:Good Beginner Car? Alex122488 Rookie Zone 4 12-04-2003 09:50 PM
HPI RS4 RTR:Good Beginner Car? Alex122488 Nitro On-Road 5 11-29-2003 07:09 PM
