Old 05-04-2007, 07:10 AM   #61
MADMAN23's Avatar
Trader Rating: 27 (97%+)
Send a message via AIM to MADMAN23
flameout mean's when you motor stall's.....
MADMAN23 is offline   Reply With Quote
Old 05-04-2007, 07:22 AM   #62
R40Victim's Avatar
A hotter plug typically just advances your timing. If it's running correctly now, you may have just had a bad plug. Even a brand new plug can malfunction. It sounds like your idle is pretty close, I'd go about 1 hour leaner though.
R40Victim is offline   Reply With Quote
Old 05-04-2007, 07:24 AM   #63
MADMAN23's Avatar
i had that happen to me.. like he did i just put another plug in it ..
Old 05-04-2007, 09:48 AM   #64
racer34v's Avatar
Trader Rating: 126 (100%+)
Send a message via Yahoo to racer34v
thanks for the help, makes sense on the timing, hotter plug lights the mixture at less relative compression..... i'll lean it a smidge next time i runit and go back to the 8
thanks!
alan
racer34v is offline   Reply With Quote
Old 05-04-2007, 09:48 AM   #65
racer34v's Avatar
ps tower has a sale 25.00 of 150 order so you can get this engine for 125.00 shipped right now if your a member... i am ordering a backup..!
Old 05-04-2007, 10:03 AM   #66
R40Victim's Avatar
LOL... I bought mine as a back up for my Rex 21...& as I broke it in, I realized I liked the powerband better than the Rex....so now the Rex is the back up!
Old 05-04-2007, 02:12 PM   #67
MADMAN23's Avatar
wow i didnt know os made so many 21 motor's....
Old 05-08-2007, 08:45 PM   #68
MannEdge's Avatar
Trader Rating: 19 (100%+)
What fuel do you guys use? I purchase byron's 30%. Is this the right fuel?
Manny
Rcgroups feedback -
http://www.rcgroups.com/forums/traderratings.php?u=78357
MannEdge is offline   Reply With Quote
Old 05-09-2007, 02:17 AM   #69
racer34v's Avatar
running trinity monster 30%
Old 05-09-2007, 05:51 AM   #70
What is a good clutch system for this engine?
ftfl99 is offline   Reply With Quote
Old 05-09-2007, 06:08 AM   #71
And what is a good (not too expensive) servos for a buggy.
Thanks again
Old 05-09-2007, 07:06 AM   #72
Tech Legend
Cain's Avatar
Trader Rating: 234 (100%+)
I am running a Hitec HS-5945MG servo. More than enough torque for it. Probably good enough for truggy too.
As for fuel, I run Byrons 25%, but will probably go to 20% here. 30% should be fine. Byrons stuff is top notch.
As for your clutch setup, I would say its buggy dependent.
i run 2 carbon shoes 1.0mm springs, and 1 aluminum shoe, 1.1mm springs. Lots of punch still but not as insane as an all aluminum setup. The engine has load of low end so this smooths it out.
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Old 05-09-2007, 07:30 AM   #73
secretsg's Avatar
wrong thread
secretsg is offline   Reply With Quote
Old 05-09-2007, 08:41 AM   #74
Thanks for the info Cain..
Old 05-09-2007, 08:55 AM   #75
Tech Legend
Cain's Avatar
No problem. I am learning too, and the tips I have gotten have really made a difference. Wish I had all that when I had my LST! would have saved my some serious headaches.
Main thing I was told about going to the setup I have other than being softer off the line was that you don't need to have as much maintenance as you do with an all aluminum setup. When I was told guys where checking them (all aluminums) after each 2 or 3 runs, some every run which involves taking the engine off , etc. I definitely wanted to try a different setup. No regrets! And its cheaper too as I get more out of a 4 pack of alloy shoes and can find the carbons dirt cheap.
Good car to buy for Beginner MesaRacer07 Electric Off-Road 14 06-30-2008 10:40 PM
Good beginner car? RC-HPI Nitro On-Road 38 08-12-2005 03:12 PM
What car should i buy as a beginner (good engine) rc fanatic Rookie Zone 13 05-27-2005 03:24 PM
HPI RS4 RTR:Good Beginner Car? Alex122488 Rookie Zone 4 12-04-2003 09:50 PM
HPI RS4 RTR:Good Beginner Car? Alex122488 Nitro On-Road 5 11-29-2003 07:09 PM
