Old 09-17-2007, 07:46 AM   #136
cornerspeed's Avatar
Originally Posted by ezveedub View Post
I don't think these motors last long. I got one used, installed new Boca bearings, new piston/sleeve, rod, pins & clips. Broke it in on rich setting (fuel rich throttle limited) used only half throttle for 5 tanks (230 average temps), now its been run in the car and tuned for good response while still rich. These motor do not like hot weather & humidity. SoFla weather is killing this thing. Very hard to keep temps under 250 without too rich boggy throttle. Running O'Donnells fuel 20%. Saw upwards of 308 today before shutting it down. Motor seem to lean out when getting hot. Also is mushy in the bottorm end torque area. Will be installing a 13 tooth bell and low end pipe. Mid pipe is OK, but everybody else on the track is killing this motor at local track. I also was told by local guys at track these motor don't last long. Next motor will be back to a Picco/Nova motor. Plus I see way too many used OS motors needing rebuilds or bearings in FS forums.
Low end is too lean. That's what I experienced this weekend with mine. Started richening up the low end and the torque increased and the temp stabilized.
Donny Vinkemulder
TLR Driver
TLR 8ight 3.0 - NovarossiUSA - Spektrum DX3R Pro - Losi Nitrotane VP 30% - Losi Lipo Batteries - Proline Tires - DE Racing - EKD Paint
--- Special thanks to: Dyno, Adam, Todd, and Kevin. Horizon Hobby
cornerspeed is offline   Reply With Quote
Old 10-03-2007, 04:34 PM   #137
jatoman1992's Avatar
Trader Rating: 4 (75%+)
Send a message via Yahoo to jatoman1992
planning on getting a VG/ how woulg it compare to the hyper .21 8-port not race
Pre-mix:
Kawisaki KX125-bored out to a 134cc, VForce reed valves, FMF gold series pipe and shorty silencer, phathead racing cyl head w/ interchangeable domes, and wiseco flat to piston
Nitro:
Ofna Ultra LX Pro- Axial .28 1S w/ JP-2 Pipe, Hitec HS5645MG(steering) and Hitec HS625MG(Throttle/Brake)
Electric:
Losi Micro-T- stock
Coming soon: Associated FT B4- stock
Ofna LX Pro as a roller w/ extras- $150
Starter box(1/8 buggy) w/12V battery- $70
micro T- $50 OBO
Axial .28 1S- 6 gal. thru- $50 OBO
jatoman1992 is offline   Reply With Quote
Old 10-04-2007, 02:46 AM   #138
freefallmarine's Avatar
Wow, I bet itll be a apple to orange's kind of change. I know the OS is smoother trough out the rev's. No one has a better carb than OS. As for power wise i don't really know. Someone out there chime in?
freefallmarine is offline   Reply With Quote
Old 10-04-2007, 01:18 PM   #139
but how long does the OS last for most people, the hyper 8 averages 7-9 gallons for about the same price.
Pre-mix:
Nitro:
Electric:
Losi Micro-T- stock
micro T- $50 OBO
Old 10-05-2007, 01:11 AM   #140
I'vee only got about 3 gallon's on my 2 VG's right now. 1 is modded and the other is stock. 8 to 9 gallons's will be rare for my VG's cause im pretty hard on them. So the 8 port might be your best bet.
Old 10-05-2007, 08:19 AM   #141
actually the 8 port lasts about 5-7 gallons, i looked on other forums about it and that is about the avarage
Pre-mix:
Nitro:
Electric:
Losi Micro-T- stock
micro T- $50 OBO
Old 10-05-2007, 08:30 AM   #142
thebeaumartin's Avatar
just my thoughts on it .i have a vg and is a good motor but my novarossi 3 port is a lot better and just as easy to tune and 3 times the power for only 40 bucks more. and check your compression it sounds like you lost it from running to lean.
thebeaumartin is offline   Reply With Quote
Old 10-06-2007, 09:15 PM   #143
If cost wasnt an issue i would go with the Novarossi also.
Old 10-06-2007, 09:40 PM   #144
rcracer34's Avatar
Send a message via MSN to rcracer34
Thumbs up O.S AND OPS
i run a o.s in my 1/8 scale v-spec never had a problem with it i also run a OPS in my Losi 1/10 The OPS is a very strong motor .12 vey fast temp on the .21 is 222 Deg'S and the OPS is 196 DEG'S WELL KEEP RACING TALK TO EVERY ONE LATER.......
Team Axiom
Factory Driver
Marc Nichols
Team Boca Bearing
www.bocabearing.com
www.axiommotors.com
www.duratraxs.com
www.losi.com
www.rc10.com
www.madmaxxrc.com
rcracer34 is offline   Reply With Quote
Old 10-07-2007, 08:29 AM   #145
hmmm yeah the Novarossi .21 3-Port is only $175 at amainhobbies. heres a link
http://www.amainhobbies.com/product_...oducts_id/9124
Pre-mix:
Nitro:
Electric:
Losi Micro-T- stock
micro T- $50 OBO
Old 10-07-2007, 06:45 PM   #146
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
I wouldn't compare or don't even compare the O.S. VG to a Novarossi. First off, the VG is a ABN engine while the Novarossi is a ABC. Hands down, the Novarossi 3 port will outrun and outlast the O.S. VG. Everyone at my local track will tell you the VG doesn't last very long.
ezveedub is offline   Reply With Quote
Old 10-07-2007, 07:12 PM   #147
yeah ur right
Pre-mix:
Nitro:
Electric:
Losi Micro-T- stock
micro T- $50 OBO
Good car to buy for Beginner MesaRacer07 Electric Off-Road 14 06-30-2008 10:40 PM
Good beginner car? RC-HPI Nitro On-Road 38 08-12-2005 03:12 PM
What car should i buy as a beginner (good engine) rc fanatic Rookie Zone 13 05-27-2005 03:24 PM
HPI RS4 RTR:Good Beginner Car? Alex122488 Rookie Zone 4 12-04-2003 09:50 PM
HPI RS4 RTR:Good Beginner Car? Alex122488 Nitro On-Road 5 11-29-2003 07:09 PM
