Old 08-04-2007, 09:36 AM   #391
hey guys this thread is great i ordered mine for $275 off ebay havent got it yeat but i have a few questions. will a pull start work with stock engine mounts.2 are all 3 diff cups the same.i guess thats all the questions i can think about now Thanks
tony433 is offline   Reply With Quote
Old 08-04-2007, 09:55 AM   #392
MadHacker's Avatar
Send a message via MSN to MadHacker
Originally Posted by Hellsavage View Post
p.s. Madhacker are U gone test it this weekend?
I will try! I've been very busy with work... I have been sent up to Northern Canada (Northwest Territories). It's a long way from our race track...
Gregg "MadHacker" Messenger
RC Pro - 37G
MadHacker is offline   Reply With Quote
Old 08-04-2007, 10:06 AM   #393
MadHacker's Avatar
Yes, all three diff cups are the same.
I'm not sure about a pull start, but I used a tiger drive starter on mine (Hellfire SS Kit) when I first put it together. The tiger drive backplate had a fair bit of depth to it, about the same as a pull start, so I would assume that a pull start would work.
RC Pro - 37G
Old 08-04-2007, 11:57 AM   #394
thanks aloy i had ordered the nova diff cups and engine mount i guess i'm a tech nube i dont know how that got there??
Old 08-04-2007, 02:36 PM   #395
Hellsavage's Avatar
@Tony443
I whoult drive it with the original diffs (thats personal) when they are assembled ok they last very well. (no argeu about this its my opinion).
The engine mount is fine fore a engine whith a pull start (In my case anyway STS D30M).
@Madhacker
Today I have been driving with my teammate and we both agreed the servo saver is there to stay.
We where more concentrated on dryving reather then stirring. Whitout the mods U posted. So I think it will please U a lot.
I am ownly trying to get U eager to driving it I want your opinion can hardly wait
mzl Hellsavage
Hellsavage is offline   Reply With Quote
Old 08-04-2007, 03:53 PM   #396
If you planning on making more of those servo saver let me know I would love to buy one or planning to sell some.
Clangeddin is offline   Reply With Quote
Old 08-04-2007, 05:14 PM   #397
thanks hellsavage i've had a problem with an ofna that the engine mount was too short for a pull start now all i have to do is to pick out an engine and pipe 90% bashing any ideas guys
Old 08-05-2007, 04:52 AM   #398
soup54....Im running a Mach 427 (.26) from an LST2. I've been runnning it for 6-8 weeks now. Using a JP-1 pipe on it. Starts easy, holds a tune well . Im running BIG tires, 40 series prolines and the motor has more than enough torque to drive them. For an inexpensive motor i think you'll like it.
Craig Hill and Sgt Thomas Hill USMC
FATHER AND SON TEAM RACING
LOSI 8T 2.0 E
TLR 22T
TLR 22SCT
Fast Racing is offline   Reply With Quote
Old 08-05-2007, 12:00 PM   #399
hey there hellsavage how is that sts engine
Old 08-05-2007, 12:56 PM   #400
Hellsavage's Avatar
The engine has done fine but its hard to find a tune. But when its tuned its a gread mill.
Its like I posted my spare because it is at the end of its lifespan. I have run about 20 l she needs a pince.
It was my first mill I ever ran in and I did not do the best job. So I am happy it has come this far.
mzl Hellsavage
Old 08-05-2007, 01:41 PM   #401
thanks fast racing i have an lst2 and that engine screams.are you running the spin start out of the lst also.
Old 08-05-2007, 06:47 PM   #402
Hellsavage-- the sts d30m version 2 is still in my FLM 1.5" extended and slamed (dog bones level with arms) Savage LE, I'm haveing too much fun poping wheelies with that set up to put it into the hellfire!!
So I bought a mach 28 for the hellfire and am breaking it in today, seems to have some pretty good power so far---enough to find the pressure cracks in the front diff from a major crash after my fail safe failed (pretty ironic!!!).
Got the new gears and alum. cases and shims on the way, I hope to have it all here and put together before next weekend!
Fast Racing-- I almost bought the mach 427 but found the mach 28 for @ $32.00 cheaper and so far I'm happy with it, well its a little soon to tell-I'm only on the 5th heat cycle and I thought I'd give the nieghbors a rest from the noise since it is Sunday!
soup54 is offline   Reply With Quote
Old 08-05-2007, 06:53 PM   #403
hellsavage-- on your sts d30m check your head shims, if your running 30% nitro use 1 silver shim, if useing 20% nitro use 1 silver and 1 copper shim.
This might help you get some of your compression/ pinch back, some of the first
d30m's produced came with too many head shims causeing weak compression after awhile.
On the holding a tune part I have found on my d30m that the o-rings in the carb needles were not sealing good, so I used some Team Associated "GREEN SLIME" all around and on the o-rings and that helped me get a better seal hince a better tune.
I hope this helps you out some!! Good Luck!!!
Old 08-06-2007, 03:17 PM   #404
Hellsavage's Avatar
@Soup54
Thanks for the info but as I stated its my spare at this time.
I hope to find a good deal on a C6BB so I have 2 highend engines whith differend caracteristics to fit any track.
Until that time the STS is my spare.
mzl Hellsavage
Old 08-07-2007, 11:01 PM   #405
MadHacker's Avatar
Hello there everyone. I had a chance to take the truck to the track tonight for practice. The verdict on the bronze servo saver... I like it! It works smoothly, and allows for a stiffer spring to be used for more positive action without the servo saver becoming "sticky". The additional weight in no way effects the handling or jumping of the Hellfire. I would buy this part.
Thanks a bunch Hellsavage!
RC Pro - 37G
How long do you take to build your kits... or8ital Electric On-Road 30 06-12-2008 07:16 AM
Hellfire pinion gear 10t how long it last? xxx123 Nitro Off-Road 1 05-05-2008 11:34 PM
Thunder Tiger ST-1 long term test... Sylvain Nitro Off-Road 3 03-11-2008 04:28 AM
Monster GT Long Term Test Sylvain Monster Trucks 0 03-07-2008 03:37 AM
Long term engine storage Xero Onroad Nitro Engine Zone 6 01-28-2005 03:39 PM
