Old 07-21-2007, 01:46 AM   #346
MadHacker's Avatar
Send a message via MSN to MadHacker
Originally Posted by Clangeddin View Post
Awesome, where you located? Maybe some day I can come check out the track. Man water in there, that will be funny who ever land in it lol
LOL... the water is for the hose, so we can moisten the track surface between heats to keep traction up...
Our track is located in Grande Prairie, Alberta, Canada.
Gregg "MadHacker" Messenger
RC Pro - 37G
MadHacker is offline   Reply With Quote
Old 07-21-2007, 01:48 AM   #347
MadHacker's Avatar
Hey guys. Here's my latest setup sheet. I'm going to race the Hellfire this weekend with this setup, and will let you know how it works.
File Type: pdf Hellfire Setup Sheet, Gregg's July 20_07.pdf (271.7 KB, 202 views)
RC Pro - 37G
Old 07-21-2007, 09:23 AM   #348
Hellsavage's Avatar
I hope this set up works.
If fore some reason U need more stiring.
1 lower your front ride hight.
2 put the ackerman to the back
Let me know if it makes any differense.
mzl Hellsavage
btw your set up looks good
Hellsavage is offline   Reply With Quote
Old 07-21-2007, 11:08 AM   #349
I was wondering is it always to have hard spring on the rear and softer on the front so that way the back won't slide as much?
Clangeddin is offline   Reply With Quote
Old 07-21-2007, 11:14 AM   #350
MadHacker's Avatar
According to what I've read in setup manuals, stiffer springs mean less traction, thus, if you have stiffer springs on the rear, then the rear will have less traction. A little bit less traction on the rear can be a good thing as it helps a car to make a tight corner.
RC Pro - 37G
Old 07-21-2007, 11:17 AM   #351
MadHacker's Avatar
mzl Hellsavage
Thanks Hellsavage.
I know that I have more preload spacers on the front than on the rear in this setup, which might seem like my ride height would be higher on the front... but with the way the shock mount positions are in this setup they actually need more preload, and the front ride height is actually a bit lower than the rear (putting more weight on the front tires for steering).
Discussing this topic has brought something to my attention regarding the Hellfire setup sheet... it's missing a section for recording front and rear ride height.
I'll try more ackerman tomorrow if I need more steering. Thanks for the tip!
RC Pro - 37G
Old 07-21-2007, 11:31 AM   #352
Hellsavage's Avatar
Originally Posted by MadHacker View Post
Thanks Hellsavage.
I know what U mean I had the same 2 weeks ago. But them there was a pro who came up to me and told me to lower the front. I reacted the same as U dit, but dit it anyway. It improved my laps with a full second. Dont know it its in my head or the car but it dit make a difference.
He told me whem the car is stationairy the front looks low. When U hit the throttle the front wil rize. When U stir in to a corner U hit the brakes first U want your front to be as low as possible for max grip when cornering.
Anyway to me it made a difference and its a tuning done in a sec. So U could give it a try. If it is no good go back to old set up in a sec. So U spil 2 seconds trying.
mzl Hellsavage
Old 07-21-2007, 11:37 AM   #353
Hellsavage's Avatar
Thanks Hellsavage.
I notised something to. The things were the arms are mounted to the bulkhead on the front. The front brace is drawn horizontal and on my car its vertical.
mzl Hellsavage
Old 07-21-2007, 12:56 PM   #354
MadHacker's Avatar
mzl Hellsavage
Yeah, that's an option part for the SS kit version. It came stock on the RTR. It allows for front inboard angle adjustment.
I updated the setup sheet, added Ride Height and adjusted a few other things. If you guys like it, I will post a blank version for you all to use.
HPI Hellfire SS Kit Build & Long Term Review-greggs-setup-sheet-july-21_07.gif
RC Pro - 37G
Old 07-21-2007, 12:59 PM   #355
MadHacker's Avatar
mzl Hellsavage
OK, you talked me into it... LOL I'll try lowering the front some more during practice tomorrow and see what happens.
RC Pro - 37G
Old 07-22-2007, 12:46 AM   #356
milenko_76's Avatar
Trader Rating: 32 (100%+)
has anyone tried the different sway bars yet? Whats your opinion on the different tensions?
milenko_76 is offline   Reply With Quote
Old 07-23-2007, 07:09 AM   #357
Hellsavage's Avatar
Heres an update on my servo saver arm.
Yesterday I was invited at a local track for some testing.
We came to the conclusion that with it my Hellfire was one of the best cornering cars at the track. with a very small turning radius.
The track was grass carpet with very high traction. Almost to much for the nubs (stock on the ss).
After a day of racing the arm is still going strong.
My personal opinion is that its a winner. So lets wait for Madhackers opinion and findings and were good to go.
mzl Hellsavage
Old 07-23-2007, 07:13 AM   #358
Hellsavage's Avatar
No yet.
I have a set but dit not use them. I wil check them out asap. I also want to know if they make any differense.
mzl Hellsavage
Old 07-23-2007, 04:42 PM   #359
MadHacker's Avatar
Well, here's the results from the races yesterday...
I TQ'd in qualifiers and took 2nd in the A Main!!!
I'd have to say that this setup is da bomb! The truck felt totally dialed yesterday, and I had a lot of comments regarding how good the truck looked on the track. Spectators were ooo'ing every time I cleared the big triple with ease. The truck flies like a dream, and is very responsive to throttle/brake input mid air to control the attitude.
My steering issues are gone, I took the rhythm section with ease, the truck jumps well, and it also handles the 150' high speed straight with no instability issues at all.
I'm very happy with the truck now. I won't be changing a thing for next race! (except to put on Hellsavage's servo saver when it arrives).
HPI Hellfire SS Kit Build & Long Term Review-greggs-july-21_07-setup-sheet-works-excellent-.jpg
RC Pro - 37G
Old 07-25-2007, 04:10 PM   #360
I have a question on battery/Reciever box. How do you guys maintain the box down?
I have body pin on one end, but the other end nothing holding it down, I can lift it up still. I'm not sure this is a problem when you flip or hit a bump wouldn't your stuff fall out?
How long do you take to build your kits... or8ital Electric On-Road 30 06-12-2008 07:16 AM
Hellfire pinion gear 10t how long it last? xxx123 Nitro Off-Road 1 05-05-2008 11:34 PM
Thunder Tiger ST-1 long term test... Sylvain Nitro Off-Road 3 03-11-2008 04:28 AM
Monster GT Long Term Test Sylvain Monster Trucks 0 03-07-2008 03:37 AM
Long term engine storage Xero Onroad Nitro Engine Zone 6 01-28-2005 03:39 PM
