Old 11-06-2008, 03:26 AM   #106
razzor's Avatar
Originally Posted by tkhoo View Post
Anyone here can help? Or this engine is already out dated so topic will close?
Somehow that settings dont sound right.
Reset carb to factory settings and retune.
also have you changed out the shim on the engine ??
The motors come with a spare shim in teh box.
Between the 2 shims you should have use the thicker one with 25% nitro.
Use attached settings a a reference.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 11-06-2008, 04:44 AM   #107
tkhoo's Avatar
Trader Rating: 45 (98%+)
Send a message via MSN to tkhoo
Hi razzor, thanks for replying me and the referance file. May I know below is the factory setting? By the way, may i know I should put how many mm shim inside the head with 25% nitro. Thanks.
Adjust needle settings before putting the car on the track
Once the engine is running and has come up to operating temperature (within 15-20 seconds) proceed as follows:
Take the car off the ground, and open the throttle fully.
Main needle
SETTING:
Close completely the main needle and open it 2,5 turns.
Low speed needle front
SETTING:
Close completely the low speed needle front and open it 4 turns.
Low speed needle rear
SETTING:
Close completely the low speed needle rear and open it 1 turn.
Idle speed
Take the car off the ground, and open the throttle fully for 2-3 seconds. Close the carburetor and check the idle speed that occurs immediately after.
- If the engine stops almost immediately, turn the idle adjustment screw clockwise to increase the idle RPM.
- If the idle RPM is too high, turn the idle adjustment screw counter-clockwise to reduce the idle RPM.
1/8 scale buggy: HB D8, Truggy: 1/12 Jammin CRT.5
Radio: Sanwa M8 power by Sanyo Eneloop, Charger: Hot Power 6016
http://pgrcclub.blogspot.com/
tkhoo is offline   Reply With Quote
Old 11-06-2008, 01:50 PM   #108
razzor's Avatar
The engine comes with 1 shim instaled and a extra one in the box, usually its put inside the glow plug card.
Between the 2 shims use the thicker one and only use the axtra one if running 30% nitro.
Casterracing ZX1.5R
Old 11-09-2008, 02:55 PM   #109
Steve Walters's Avatar
Sad news from Axe-Rossi.
http://www.neobuggy.net/modules/news...p?storyid=5051
"CVR" Central Valley Raceway (Madera, CA)
Team "WTF" Racing member
TEAM BCE (Product/Field Tester)
X-Ray 808 (Active Diff)
BCE 8X8 Pro Chassis
OS Speed (XCustoms Head Mod)
Hitec 5995TG (S&T)
M11 & Spectrum.
Steve Walters is offline   Reply With Quote
Old 01-27-2010, 09:39 AM   #110
Torian4000's Avatar
Trader Rating: 49 (100%+)
Torian4000 is offline   Reply With Quote
Old 01-30-2010, 09:12 PM   #111
I run mamba. With (2).20 shims. 30 percent. With very good run times
Mugen mbx6t/coldfusion fuel/aka tires/futaba electronics
kyosho17 is offline   Reply With Quote
axe rossi cobra/mamba helivaguy Nitro Off-Road 5 07-26-2008 07:07 AM
Used Axe Rossi Mamba toycardriver R/C Items: For Sale/Trade 11 07-22-2008 07:10 PM
BNIB Axe Rossi Mamba clarksib R/C Items: For Sale/Trade 2 03-16-2008 01:03 PM
axe rossi mamba .21 for sale voodoo427 R/C Items: For Sale/Trade 3 08-06-2007 06:20 PM
Axe Rossi mamba .21 22Racer Electric Off-Road 5 01-31-2007 09:41 AM
