Old 06-12-2007, 02:37 PM   #61
my buddy has has about two gallons on them then had to replaced them... i just tried the dynimate max life clutch shoes two gold and two green very good on the engagement...
Garrison is offline   Reply With Quote
Old 06-13-2007, 05:52 AM   #62
Losi is coming out with their own long life clutches very soon.
Homer Allman is offline   Reply With Quote
Old 06-23-2007, 09:50 PM   #63
Ran the Werks truggy clutch with the gold spring and carbon shoes on my 8 buggy today. The track conditions varied from quite good traction to quite dusty and slick. The clutch worked great. I simply loosened the nut a bit as the day went on and the track got slicker.
satoch is offline   Reply With Quote
Old 06-28-2007, 09:13 AM   #64
SkarTisu's Avatar
Send a message via AIM to SkarTisu Send a message via Yahoo to SkarTisu
I'm running the Werks clutch on a standard V-Spec in my 8B. The biggest trick was to get the flywheel spacing right for the Werks flywheel. Buy either a 6mm collet and space it .2mm (as long as your collet doesn't sink too far into the flywheel) or buy a 7mm collet and machine it down to 6.2mm. You can use the stock Losi clutch bell, and you want to use the stock Losi crank screw, washer and shims if possible since there isn't much room between the end of the crank and the fuel tank.
SkarTisu is offline   Reply With Quote
Old 02-07-2010, 03:06 PM   #65
Greetings from Venezuela, I have an 8ight T 2.0 and I want to put a 3 shoes clutch, and buy the king headz engine mount to move the engine forward 2mm but I'm not sure what clucth bell used to have this configuration, the Team Losi or standard clucth bell, Someone who has this configuration could help me please.
thanks.
ivancito is offline   Reply With Quote
Old 02-08-2010, 07:49 AM   #66
Originally Posted by KForce View Post
the stock clutch with the 7075 kingheadz is the way to go.
IF you do want to run a 3 shoe then you have to shim the flywheel forward a bunch. or if you buy the kingheadz motor mount it has 2 positions on it, one for stock setup and another one moved forward 2mm for a 3 shoe setup without having to shim the crap outta it.
kyle
hey kyle which CB use con 3 shoes setup in the hkz engine mount, standard cb or the losi cb????
Old 02-08-2010, 08:49 AM   #67
Integra's Avatar
HOLY Skar used to run Losi.....
Old 05-10-2010, 07:48 AM   #68
Tony899's Avatar
Back then everyone in MN ran Losi.
Tony899 is offline   Reply With Quote
Old 05-10-2010, 10:42 AM   #69
Jason Pelletier's Avatar
Trader Rating: 33 (100%+)
Black springs on black composite shoes, Green springs on blue aluminum shoes. This set-up is dialed and the clutch lasts forever on my buggy.
Island Raceway & Hobby
Jason Pelletier is offline   Reply With Quote
Old 05-10-2010, 11:45 AM   #70
I run the standard Losi Clutch, with dyn max life shoes, gold and silver springs and Avid $1 bearings. The only problems I had with my clutch is from USER error. Other than that, it has been good.
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
Old 05-10-2010, 06:25 PM   #71
Trader Rating: 30 (100%+)
Dynamite Max-Life shoes with 2 gold springs and 2 greens.
sdtech58 is offline   Reply With Quote
losi 8ight clutch? lynell90 Nitro Off-Road 10 06-02-2008 10:24 AM
LOSI 8ight Clutch!!!! lynell90 R/C Items: Wanted to Buy 0 06-02-2008 10:02 AM
Losi 8ight/8ight-t clutch parts dido41 R/C Items: For Sale/Trade 5 08-06-2007 04:51 PM
Losi 8ight clutch shoes Jammin57 R/C Items: For Sale/Trade 6 08-01-2007 07:57 PM
Losi 8ight Clutch Shoes Hugh R/C Items: For Sale/Trade 1 05-17-2007 08:17 PM
