Old 05-31-2007, 05:55 PM   #46
trebor's Avatar
Originally Posted by houston
my favorite losi clutch setup is the khz 7075 shoes w/ 2 gold & 2 silver my other is all carbon with all green springs (losi clutchbell only , not robinson)
later , monty
i also tried the fioroni version of the werks clutch system (identical) and gave up on it after 10 minutes of runtime !!! i am a very good wrench and fast racer and thought the clutch system just sucked and was too much of a pain in the @ss !!!!! lol
I am also running 4 KHZ 7075 w/ 2silver,2gold and its sweet!!
Is the shock bottom caps revised? They look different than the ones I have.
trebor is offline   Reply With Quote
Old 06-01-2007, 12:52 AM   #47
nobike's Avatar
Trader Rating: 147 (100%+)
later , monty
Yo houston, how long did it last with the all carbon with green springs and how did it engage?
nobike is offline   Reply With Quote
Old 06-01-2007, 05:15 AM   #48
tex1's Avatar
Send a message via Yahoo to tex1
Talking
The Werks clutch takes the standard long collet and the Losi clutch takes the US short collet like used on the gas trucks.
Make sure the collet fits well before you try to install and it should be fine.
TEX
www.indyrcworld.net
Indy RC World 2.0 - Garland, TX
T&T RC Cars - Plano, TX
(972) 271-4844
tex1 is offline   Reply With Quote
Old 06-01-2007, 06:32 PM   #49
houston's Avatar
Trader Rating: 91 (100%+)
Talking
nobike: the carbon shoes wear great as long as you spring em right and use the losi clutch bell !! the engagement is best suited for 5 port engines on slightly duffy track or wet loose dirt tracks , wouldnt use this setup for indoor tracks or bluegroove tracks as it would probably accelerate wear profusely !!! king headz 7075 are my favorite fersure !!! you can also try all gold springs on khz shoes , easier on the shoes just a lil less punch . you know what sucks , i know a few high profile team drivers and call em regularly and they still wont admit to using anything but the box stock clutch setup !!! there are alot of ways to setup your clutch , find what works best for your track , driving style , car , and throttle finger !!!!LOLOLOL !
later , monty
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 06-01-2007, 06:52 PM   #50
Originally Posted by trebor
TEX-What collet is it?
The HPI .21 collets (7x6.5mm, part# 86077) work well with the werks, and if you do have a slippage issue where the adjustment nut tightens all the way down it means the flywheel/collet is slipping on the crankshaft usually, try widening the slit in the collet so it bites down more on the crankshaft.
claudacio is offline   Reply With Quote
Old 06-02-2007, 12:55 PM   #51
Trader Rating: 50 (98%+)
Send a message via AIM to micrors4guy
the box stock set up now is 7075 alloy with silvers and carbons with golds. the set up works and lasts with the newer shoes.
micrors4guy is offline   Reply With Quote
Old 06-02-2007, 05:31 PM   #52
xlgraphicspro's Avatar
I hear Dinamite is comming out with a set of long wearing aluminum clutch shoes for the 8ight clutch.
TeamXray RCAmerica Hudy Xlgraphicspro Paint/ Impulse-Rc Clutch shoes.
Xray XB 808 O.S. Speed Or Ninja JX
xlgraphicspro is offline   Reply With Quote
Old 06-03-2007, 12:25 AM   #53
Trader Rating: 39 (100%+)
Dynamite had the shoes out for a couple weeks. I have a set, but haven't tried them. I hear they don't hit as hard as four KHZ 7075 and feels a little like carbon shoes.
ridgewaybodies is offline   Reply With Quote
Old 06-03-2007, 12:29 AM   #54
Aaron Waldron's Avatar
I think I've posted this before.
Try the stock shoe setup with one step softer springs. Blue shoes with gold springs and carbon shoes with greens. I've been running this for a long time now and I think the added driveability of the softer springs will help a lot of people drive smoother.
Aaron Waldron - LiveRC
www.liverc.com
Aaron Waldron is offline   Reply With Quote
Old 06-03-2007, 06:59 AM   #55
Matt Howard's Avatar
This is the same clutch setup I've been running as well, works great
Matt Howard is offline   Reply With Quote
Old 06-05-2007, 01:32 PM   #56
if you want more pop out of the clutch try kingheads 7075 with 2 silver springs and two gold ... a lot of snap
Garrison is offline   Reply With Quote
Old 06-07-2007, 09:29 AM   #57
Can anyone explain to me the advantage of running two different color springs with the same KH 7075 shoes. I've run two different springs with two different types of clutch shoes, but never different springs on the same same shoes. I'm looking to switch from the stock losi clutch to one with either 2 or 4 KH 7075 shoes. Also, I'm currently running an RB C3 because both my S7's need bearings and I've been lazy. Anybody have any spring/shoe suggestions for a budget powerplant. Thanks JB
LuvChunks is offline   Reply With Quote
Old 06-08-2007, 02:20 PM   #58
smoother engagement not all the snap at once
Old 06-12-2007, 09:40 AM   #59
nobike's Avatar
Originally Posted by nobike View Post
Anyone here try four carbon losi shoes? if so what color springs? and how is the wear rate?
anyone else, try an all carbon setup.................
Old 06-12-2007, 10:03 AM   #60
TEX
I just put the #6521 Werks clutch I had laying around from my truggy in my 8 buggy. I used the stock Losi collet and it seems to tighten up nicely. Using the stock Losi bell this set up fits perfectly. I haven't tried it out yet however. I hope I don't have a problem with the collet slipping.
satoch is offline   Reply With Quote
losi 8ight clutch? lynell90 Nitro Off-Road 10 06-02-2008 10:24 AM
LOSI 8ight Clutch!!!! lynell90 R/C Items: Wanted to Buy 0 06-02-2008 10:02 AM
Losi 8ight/8ight-t clutch parts dido41 R/C Items: For Sale/Trade 5 08-06-2007 04:51 PM
Losi 8ight clutch shoes Jammin57 R/C Items: For Sale/Trade 6 08-01-2007 07:57 PM
Losi 8ight Clutch Shoes Hugh R/C Items: For Sale/Trade 1 05-17-2007 08:17 PM
