Old 05-07-2008, 01:40 PM   #1351
Mcran's Avatar
Taking that brace out will let the chassis flex and give more rear traction. We never run it before we went to the BCE chassis. For more rear side bit here are some things you can try. Run less camber, smaller sway bar, longer camber link, use a higher roll center (use lower holes on shock tower for rear camber link), Lay the shock down more in the rear (more inclined), more toe-in, move hubs forward “puts more weight on the rear tires”, thinner rear diff oil, larger hole shock pistons #2 or 3, lighter shock oil, lighter spring, lower rear ride height. If I got anything wrong someone please correct me.
Good setup guide: http://www.teamxray.com/teamxray/pro...ria=0&catName=
Download this Manual Xray XB8R and go to the last pages. Very good setup guide.
Here’s one more:
http://www.cenracing.com/race/setup.html
Click on setup guide at bottom of page.
Team Associated, LRP, Reedy, Hobbico - www.hobbico.com,
JConcepts - www.JConcepts.net, Futaba - www.futaba-rc.com,
OS Engines - www.osengines.com, Kal-Gard - www.Kalgard.com,
Murnan Modified Motors - www.Murnanmodified.com
Mcran is offline   Reply With Quote
Old 05-07-2008, 07:51 PM   #1352
Trader Rating: 19 (100%+)
For springs what other ones do you use? I only have the Cen stock green ones, also I run the stock shocks all #2 pistons 60wt fr and 35wt rear. And again thank you.
malik is offline   Reply With Quote
Old 05-08-2008, 09:51 AM   #1353
Mcran's Avatar
The only springs we have run on the TR are the stock green springs. We use 60wt front #1 and 40wt rear #2. That was before changing to the BCE Chassis. We were always trying to take away rear traction to get the truck to rotate more on throttle.
Old 05-08-2008, 11:34 AM   #1354
I am getting ready to go to the advantage brakes and the plastic diffcases. Are the diff cases weight wise going to benefit my out of the hole power, and braking? And are they brittle like should I be easy tightening the screws. I was trying to drop some more weight off my trug and the diff cases and the brakes will do alittle more than I have done already. As we all know any little bit helps. You guys are very helpful again thanks.
Old 05-08-2008, 11:42 AM   #1355
Trader Rating: 21 (100%+)
The diff cases are very strong, don't worry about breaking them.
Colin
Time Zone Raceways www.Timezonehobbies.com
www.ColinBranch.com
C Branch is offline   Reply With Quote
Old 05-08-2008, 07:57 PM   #1356
I just noticed tha Gene came out with the rear upper turnbuckles, anybody ever bent the stockers? I have bent both front uppers before getting Genes ackerman plate and front upper tb's. I will probably just get them anyway just wondering cause I dont remember hearing anybody having trouble with them though.
Old 05-08-2008, 08:06 PM   #1357
I have never bent a rear one, but I can't go one run without bending a front one.
Colin
www.ColinBranch.com
Old 05-08-2008, 09:25 PM   #1358
Questions?? Advantage Brakes
I just want to make sure I've got the install correct for the new brakes. Thats one advantage brake rotor front and back. Also use the metal caliper without the pad until it starts to grab then back off a 1/4 turn or so. Also it says to remove the stock brake disc guides. So just take them out or modify them. Thanks for your help.
Matrix TR FRE
Hot Mods Novarossi Plus .28 5T w/9886 pipe
DX3R
Stimey131 is offline   Reply With Quote
Old 05-08-2008, 09:31 PM   #1359
Yeah the first time on the track a while ago and after a few laps noticed I had no uptravel in front, pulled it in and noticed both front TB's were bent exactly the same way. As soon as I got home I called Gene and went blue up front, they look sweet to so I probably like I said will get the rear anyway plus I belive the rears are a total of 12 grams lighter. Every little bit counts.
Old 05-08-2008, 11:01 PM   #1360
Tree's Avatar
Send a message via ICQ to Tree
Do not use the guides with the Advantage brake rotors
Team Holy Rollers
HiTec Servos
"N-Tune" Nitro Engine Tuning Dials
Tree is offline   Reply With Quote
Old 05-09-2008, 10:25 AM   #1361
Default Clutch bells
I have always used the Cen bells and was possibly wanting to try another brand. Do the mugen bells fit the same as the stock ones shim wise? also I see people tearing down the rtr's on ebay do the rtr's come with the same bells as the FRE? And what other bells do you guys use and how are they?
Old 05-09-2008, 10:51 AM   #1362
Tree's Avatar
I want to try the Eck Tek clutch bells but I cannot seem to find any of them.
Team Holy Rollers
HiTec Servos
Old 05-09-2008, 12:43 PM   #1363
I would like to hear some feedback first but right now I am looking on ebay at the rtr buggy bell and the mugen bell, I am not shure if the rtr cen 1 is hardened and on the Mugen not shure if it works. Any other suggestions would be nice. Also I see on a-main the Protec bells but none of them say Cen type, so I need to know what type cen is I guess. A few guys at the track run the protec rc bells and love them for the price.
Old 05-09-2008, 01:53 PM   #1364
Tree's Avatar
Would the Racers Edge clutch bells work with the Mugen and CEN flywheel and shoes?
http://www.rcnitrotalk.com/168/8th-s...m-racers-edge/
Team Holy Rollers
HiTec Servos
Old 05-10-2008, 10:39 AM   #1365
Default 17mm wheel hexes
Does anybody know if the 17mm wheel hex that comes on the Matrix buggy will fit the Matrix TR. I want to switch to running the proline LPR's. I aso have a question about tire mounting. I read through the instructions for the proline MTR crimefighters and it says to put 2 small dimond shape holes on oppisite sides of the tire. Is this something that needs to be done? It seems to me if i put a small hole in the tire it will just be a place for the tire to start tearing itself apart at high speeds or will they be fine. I already have two 3/16 holes in my wheels on oppisite sides isn't that enough. Thanks for your help guys.
Matrix TR FRE
DX3R
cen matrix CHAVAN30 Nitro Off-Road 1177 08-05-2011 05:23 PM
CEN MATRIX FRE helivaguy Nitro Off-Road 4 08-27-2008 05:52 PM
Cen Matrix dieseldog20 R/C Items: Wanted to Buy 0 02-06-2008 05:31 PM
Matrix and Matrix TR Factory Race Edition Kits SmoothB R/C Items: For Sale/Trade 4 05-31-2007 05:36 PM
Dye matrix 5 and DYE matrix 4 w/ tanks and halos for sale yuk17bandit Other Items: For Sale/Trade or Wanted to Buy 0 11-07-2006 10:49 AM
