Old 05-04-2008, 08:01 AM   #1336
Trader Rating: 19 (100%+)
So I gave in and called Gene yesterday and ordered the cnc knuckles. Thanks Gene, my opening day saturday got rained out. It was going to be my first race with my TR. Well hopefully it wont rain next week.
malik is offline   Reply With Quote
Old 05-04-2008, 08:05 AM   #1337
ILDRVR's Avatar
Originally Posted by chrobar View Post
You could get the sportwerks backplate for the SH engine. It's the backplate that I bought, and it's only $11.99 at amain. It already has "dips" on the corners, so no dremeling is required. It fits perfectly, and I didn't mod anything.
Thanks, I had the Ofna plate, but after I looked at the sportwerks, I see what you guys are talking about. Thanks for the help.
Tarara Racing
Tea's Hobby Shop & Raceway Park
Cheese City Xtreme RC
ILDRVR is offline   Reply With Quote
Old 05-04-2008, 10:20 AM   #1338
Default time for a new body
The body I have been using (MBX5T Proline body) which looked awsome on the TR Has been discontinued. So,, with that said what bodies are you guy's running now that look good?
I am confused as the Pro-Line site has 2 different pictures of bodies. There are 2 pictures that you can look at and both are different. Thanks for any reply's
www.rkhobbies.com
www.tnt-fx.com
Stefan Millay is offline   Reply With Quote
Old 05-04-2008, 12:45 PM   #1339
chrobar's Avatar
I see that Andrew and Gene run the STRR proline body, but some trimming needs to be done. Most other people run J concepts MBX5T illusion body. It fits perfectly and looks sick. It's my next body for sure. The J concepts body is also lighter than proline.
There is a specialty body by RCbodies for the Matrix TR. I'm sure it's great, too, but IMO the J concepts just looks better.
CEN Factory Team
Matrix C-1 FRE custom brushless, 2000kV, Orion VDS-2015
GST-E, 1500 kV, Hitec 5955TG
Futaba FASST 3PM
chrobar is offline   Reply With Quote
Old 05-04-2008, 12:57 PM   #1340
Default About spare parts
I'm getting ready to order some of the cnc hop up parts, but I also want to order some of the spares that I might need. Can you guys give me an idea of some spares that are good to have on race day. Thanks for help.
Stimey131 is offline   Reply With Quote
Old 05-05-2008, 04:50 PM   #1341
Default brake set up
I've got everything together on my TR and I'm now trying to fine tune it all. Can someone explain how to set up my brakes properly as I have never had a vehicle with front and rear brakes.
Old 05-05-2008, 06:34 PM   #1342
Trader Rating: 21 (100%+)
A few pics of my TR.
Colin
CEN Matrix TR-stuff%2520055.jpg   CEN Matrix TR-stuff%2520058.jpg   CEN Matrix TR-stuff%2520059.jpg   CEN Matrix TR-stuff%2520061.jpg   CEN Matrix TR-stuff%2520062.jpg
Time Zone Raceways www.Timezonehobbies.com
www.ColinBranch.com
C Branch is offline   Reply With Quote
Old 05-06-2008, 12:43 PM   #1343
Mcran's Avatar
Tighten the brake disk screws till the pads start grabbing the disk then back off about ľ turn so the drive train turns freely when the servo are at neutral. I always set brake so it takes as little servo travel as possible before the brakes start to grab. We usually run 60% front and 40% rear brake bias. After getting everything setup we roll the TR forward holding up on the rear of the truck then hit the brakes. Then roll the truck backward holding up the front and hit the brake. This is how we set brake bias on the bench, then fine tune on the track. Just make sure your brake end point (EPA) on your radio is set very low then adjust up so you donít bend or break something. We also use the metal brake pads and one Advantage fiberglass brake disk front and rear. Hope this helps.
Team Associated, LRP, Reedy, Hobbico - www.hobbico.com,
JConcepts - www.JConcepts.net, Futaba - www.futaba-rc.com,
OS Engines - www.osengines.com, Kal-Gard - www.Kalgard.com,
Murnan Modified Motors - www.Murnanmodified.com
Mcran is offline   Reply With Quote
Old 05-06-2008, 06:01 PM   #1344
McRan can you give me a link to the Advantage brake disc? Are they made for the TR? Also you use the stock metal pads alone correct? Thanks
Old 05-06-2008, 06:25 PM   #1345
This is where I got mine.
http://www.amainhobbies.com/product_...ducts_id/16716
Colin
www.ColinBranch.com
Old 05-06-2008, 07:43 PM   #1346
yes just use the metal of the brake pads
go really fast and turn left....
Robert.Hull is offline   Reply With Quote
Old 05-06-2008, 07:51 PM   #1347
Tree's Avatar
Send a message via ICQ to Tree
http://www.carolinasrc.com/Webstore/...idproduct=4884
Team Holy Rollers
HiTec Servos
"N-Tune" Nitro Engine Tuning Dials
Tree is offline   Reply With Quote
Old 05-06-2008, 10:34 PM   #1348
Ok thanks, 2 more questions. The brace between the engine and battery box that goes from the chassis to the wing brace, what does it do, both on and off? An I would like to lighten up the drivetrain alittle, can I with no mods put in the plastic diff cases if the diffs I have are the stock pinned ones with the metal cases? Not the lsd diffs or Genes pins, from the factory metal cases with pins. Just making shure I am clear, and is the weight saving worth it?
Old 05-07-2008, 06:35 AM   #1349
slaytanic's Avatar
Trader Rating: 20 (95%+)
Cutting weight in the drive train (rotating mass) is the single biggest improvement you can make IMO. It is like adding free horsepower! It will be snappier off the line and smoother to boot. Help you get up speed for those short run ups to jumps.
Team Epic
Team Terribles~Answer RC~Fastlane Graphics~Torco Race Fuels
XB808 Mamba Max Pro/Tekin 1900kv RC-monster mount and tray 4s
XT8 Hobbywing 150a esc/2000kv combo KILLER! Full rc-monster e conversion. 4s
slaytanic is offline   Reply With Quote
Old 05-07-2008, 07:29 AM   #1350
Yeah I figured that would help I will be getting those asap. Now about the other question, that upright brace in the rear that goes from the chassis to the "wing brace", I am shure taking it out would give alittle chassis flex now would that increase side bite or am I thinking wrong? Does anyone ever run it off or does it do anything at all? I am looking for more rear side bite. Thanks everyone....
cen matrix CHAVAN30 Nitro Off-Road 1177 08-05-2011 05:23 PM
CEN MATRIX FRE helivaguy Nitro Off-Road 4 08-27-2008 05:52 PM
Cen Matrix dieseldog20 R/C Items: Wanted to Buy 0 02-06-2008 05:31 PM
Matrix and Matrix TR Factory Race Edition Kits SmoothB R/C Items: For Sale/Trade 4 05-31-2007 05:36 PM
Dye matrix 5 and DYE matrix 4 w/ tanks and halos for sale yuk17bandit Other Items: For Sale/Trade or Wanted to Buy 0 11-07-2006 10:49 AM
