Old 04-25-2008, 03:57 AM   #1291
Trader Rating: 19 (100%+)
Yes they work fine, get some shims though, you need to shim them as they are shorter.
pooldoc is offline   Reply With Quote
Old 04-25-2008, 04:03 AM   #1292
HWYSHREDDER78's Avatar
Trader Rating: 25 (100%+)
Thanks for the help pooldoc.
HWYSHREDDER78 is offline   Reply With Quote
Old 04-25-2008, 08:33 AM   #1293
I have a ew set of matrix 17mm hexes I probably wont ever use if you want them. I already have a few sets of 23mm wheels and tires. Let me know $15 shipped. I paid like $2 more than that from ebay.
malik is offline   Reply With Quote
Old 04-25-2008, 01:25 PM   #1294
Questions?? Info on the diffs in my FRE truggy
I just recieved my Matrix TR FRE today and I was wonder about the diffs in it. When I looked in the box I found the 3 LSD diffs with aluminum housings and 2 cross pin with plastic housings. I thought I read that the cross pin diffs only work well in the aluminum housings. Should I use the LSD style diffs up front and the cross pin diffs in the middle ,rear. Any input on which diffs to use where and what type of lubricant in them would really help. Also should I order the aluminum housings for the cross pin diffs. Thanks I just talked to sen direct and they told me they don't make aluminum cases for the cross pin diffs only the plastics one.
Stimey131 is offline   Reply With Quote
Old 04-25-2008, 07:28 PM   #1295
Trader Rating: 21 (100%+)
Use the plastic diffs with the cross pins. I am running 7, 15, 3 in my TR.
Colin
Time Zone Raceways www.Timezonehobbies.com
www.ColinBranch.com
C Branch is offline   Reply With Quote
Old 04-25-2008, 07:51 PM   #1296
Default Info about diffs
Colin thank you for reply, but I still have one more quetion. I only recieved 2 cross pins and 2 plastic cases. Do I use them in the front and rear or the center and rear as I read that alot of people run the LSD diffs up front. Thanks
Old 04-25-2008, 08:01 PM   #1297
Hmmm, I run them in all 3 places. If I had to, I would run the LSD in the front.
Colin
www.ColinBranch.com
Old 04-26-2008, 03:07 AM   #1298
Yeah, lsd up front with 80 wt gear oil
Old 04-26-2008, 12:20 PM   #1299
Tree's Avatar
Send a message via ICQ to Tree
A few pictures of my TR Arena FRE. I am break-in a STS engine I had for a while. I am Going to use it as a practice mill. I currently have buggy tires and wheels installed so I don't wear out my more expensive truggy tires.
Team Holy Rollers
HiTec Servos
"N-Tune" Nitro Engine Tuning Dials
Tree is offline   Reply With Quote
Old 04-26-2008, 03:53 PM   #1300
Default Ceramic bearings
Has anyone used any of the ceramic bearing in their Matrix TR. I'm thinking about ordering a Acer Ceramic bearing kit for my TR FRE. I just got it and I haven't started building it yet. I would like to go ahead and get Gene's cross pin conversion kit for the diffs also before I start building it. It would be a lot easier to put the ceramic bearings in when I'm building it then to go back and put them in latter. I could use my stock bearing as back ups. Thanks for your input Michael
Old 04-26-2008, 05:58 PM   #1301
Bearings are all prefirence, if you want them get them. Are those piggybacks from Cen's monster trucks? I have seen them a few times and think they might be worth getting for my local track. Can I have a part number? Thanks
Old 04-26-2008, 07:01 PM   #1302
Tree's Avatar
I bought my set off of ebay but you can use the link below for the Piggyback reservoirs.
http://www.customrccars.com/product_...at=23&custom=0
Team Holy Rollers
HiTec Servos
Old 04-26-2008, 08:01 PM   #1303
Mcran's Avatar
The LSD works really well in the front with 90wt gear oil or 1000 diff oil. Right now Justin is using the pin diffs with 5/20/3.
The stock Cen bearings are great. We use Advantage Ceramic Bearings with the double rubber seals and they work great also. They are much lighter and roll very free. We do take both rubber seals out and clean the grease out. Then put light bearing oil in.
Team Associated, LRP, Reedy, Hobbico - www.hobbico.com,
JConcepts - www.JConcepts.net, Futaba - www.futaba-rc.com,
OS Engines - www.osengines.com, Kal-Gard - www.Kalgard.com,
Murnan Modified Motors - www.Murnanmodified.com
Mcran is offline   Reply With Quote
Old 04-26-2008, 09:20 PM   #1304
I asked this question a page or so back but no answer, will the Kyosho MP 7.5 and 777 knuckles fit?
Old 04-27-2008, 09:17 PM   #1305
Mcran's Avatar
Malik sorry I don't know the answer to that. Gene and Robert will be back from the Truck Nats tomorrow so maybe one of them can answer that for you.
cen matrix CHAVAN30 Nitro Off-Road 1177 08-05-2011 05:23 PM
CEN MATRIX FRE helivaguy Nitro Off-Road 4 08-27-2008 05:52 PM
Cen Matrix dieseldog20 R/C Items: Wanted to Buy 0 02-06-2008 05:31 PM
Matrix and Matrix TR Factory Race Edition Kits SmoothB R/C Items: For Sale/Trade 4 05-31-2007 05:36 PM
Dye matrix 5 and DYE matrix 4 w/ tanks and halos for sale yuk17bandit Other Items: For Sale/Trade or Wanted to Buy 0 11-07-2006 10:49 AM
