Old 03-01-2008, 06:25 PM   #1141
TripleX-JT's Avatar
Send a message via MSN to TripleX-JT
You could check the clutch. Make sure that nothing is binding like the shoes or the bearings.
If that looks good it could be an air leak some where fuel line, tank, or carb.
That is what I check first once my engine starts doing funny things.
Josh Thompson
CEN Racing - GO Tech Engines - UPgrade RC - Northern Hobbies - Khaos Designs
TripleX-JT is offline   Reply With Quote
Old 03-01-2008, 06:52 PM   #1142
Should have mentioned that before. The Clutch was pretty much buggered, so its all been replaced, bearings, clutcc bell, shoes and springs. I've for some fresh fuel line that I'll put on there. Maybe it's the spring that seals the lid shut on the fuel tank? I remember seeing someone saying you can use an old clutch spring or something to hold it down. Maybe the vibration at WOT is enough to pop the lid open for a second.
How do I check the carby for leaks? Whats the deal with fixing up the fuel tank so it doesn't have air leaks?
Jase
Thorin is offline   Reply With Quote
Old 03-01-2008, 07:22 PM   #1143
ILDRVR's Avatar
I have done two different things to seal the lid. First there is an adjustment screw for the seal. By tightening it the seal will expand and loosen it and it will shrink. I have also taken a small piece of old fuel tube, lifted up the cap springs, and placed it under them. This adds alot more tension to the springs to seal the cap.
You can submerge your tank in water, plug one hole and blow through the other to see if your lid leaks.
Good luck!
Tarara Racing
Tea's Hobby Shop & Raceway Park
Cheese City Xtreme RC
ILDRVR is offline   Reply With Quote
Old 03-01-2008, 07:32 PM   #1144
ILDRVR's Avatar
Originally Posted by Thorin View Post
Guys,
Anyway. The problem that I am having is when i hit WOT, the engine flames out. If I go to half throttle it can sometimes splutter as if its not getting fuel (I have checked the fuel line and its all clear, fuel is getting to the carby and no air is getting in). The fuel line to the engine isn't very long, but I haven't had problems with that in the past. I have set the screws back to factory, but its doing the same thing over and over. I have tried leaning it right out, and fattening it up and again, the same thing.
Just a thought about the WOT problem. Is it not getting fuel or flooding? Anyway, if you have not changed your glow plug I would try that first. If it is not getting fuel you could give this a try. I have heard that if your fuel tank pressure line from the pipe is not long enough it could loose pressure under full throttle. I have never had this problem so I am not for sure
Tarara Racing
Old 03-01-2008, 08:06 PM   #1145
TripleX-JT's Avatar
Jase
Take the carb of of your engine. Put a lead of fuel line on it. Put your thumb on one end and your index finger on the other. Put it in water and blow through the fuel line. If you see any bubbles come up you have a leak.
Josh Thompson
Old 03-01-2008, 08:52 PM   #1146
ILDRVR, its not being starved of fuel that I can tell, there is fuel in the lines when it flames out. I can only think of it flooding if that is the case, but it still does it when i am running it very very lean.
Will change the fuel line and glow plug over, and then make sure the fuel tank is sealed. Hopefully that fixes all the problems.
Thanks guys, will check back later with the results.
Jase
Old 03-02-2008, 05:48 PM   #1147
TripleX-JT's Avatar
Good Luck
Josh Thompson
Old 03-02-2008, 09:10 PM   #1148
thorin-whats the probelm? you cant get the engine to stay running?
go really fast and turn left....
Robert.Hull is offline   Reply With Quote
Old 03-02-2008, 10:58 PM   #1149
floss's Avatar
Trader Rating: 32 (100%+)
Whats a good starting point for shock and diff oil on the TR Arena truck.
REDS RACING ENGINES
Model Motorsports
floss is offline   Reply With Quote
Old 03-03-2008, 03:30 AM   #1150
slaytanic's Avatar
Trader Rating: 20 (95%+)
Depends. Are you running the crosspins?
Does anyone have one of these Ofna truggy starter boxes? Bought it cuz it said truggy box. My last one wouldn't fit the TR. Now I get this one together and it won't fit it either. I am pissed! It's not like there is much too them. Did I miss something? The pegs are all the way back and out and the flywheel is still like 3/4 of an inch forward of the starter wheel. I dont wanna run just front pegs cuz thats why I bought this one. Anyone got an idea? Thanks!
slaytanic is offline   Reply With Quote
Old 03-03-2008, 06:43 AM   #1151
just to make sure its not gonna work take the pegs off and line the truck up where it will crank over then see if all the pegs will bolt up
Old 03-03-2008, 09:53 AM   #1152
slaytanic's Avatar
Robert, I will try that when I get back in town. On the road now. The rear pegs either need to go out more or back more and they are already all the way back and out. The front is fin. I actually need to move em in and back a bit. The chassis is pretty wide in the rear. That seems to be the problem. I think I will see if I can get one of those starter plates for it from TKO. When I checked they didn't have one for it. Maybe they will make one though if people ask.
Old 03-04-2008, 05:54 PM   #1153
slaytanic i have this box and use it with my cen tr you need to flip the starter wheel to the side with the switch this is a little involved but you will see it is reversable and then adjust the rear pegs on the back of the chassy close to where the rear arms mount you will only use one front peg on the switch side but once you have it set right on the back pegs it will not move from side to side. it takes a little work to set it up but once you get it there is no better box out there
novenom is offline   Reply With Quote
Old 03-04-2008, 06:20 PM   #1154
slaytanic's Avatar
Thanks man! Thats ggos to hear I didn't waste my money. So there is no way to get all 4 pegs? I wonder if that starter plate will fit on the lid. Thinking of getting one.
Old 03-04-2008, 06:40 PM   #1155
no the chassy is to wide in the front but trust me you dont need it this box will turn over even the most stubborn motors my brothers have the chrome top and its no contest by mid day there charging there boxes not me it will go all day and then some you definetly made the right choice
cen matrix CHAVAN30 Nitro Off-Road 1177 08-05-2011 05:23 PM
CEN MATRIX FRE helivaguy Nitro Off-Road 4 08-27-2008 05:52 PM
Cen Matrix dieseldog20 R/C Items: Wanted to Buy 0 02-06-2008 05:31 PM
Matrix and Matrix TR Factory Race Edition Kits SmoothB R/C Items: For Sale/Trade 4 05-31-2007 05:36 PM
Dye matrix 5 and DYE matrix 4 w/ tanks and halos for sale yuk17bandit Other Items: For Sale/Trade or Wanted to Buy 0 11-07-2006 10:49 AM
