Old 12-10-2007, 06:30 PM   #991
rregl0612's Avatar
Trader Rating: 33 (100%+)
woops!!!.. Gene you caught me goin backwards again.. Now if I could just figure out where the finish line is!!!!!!!...
rregl0612 is offline   Reply With Quote
Old 12-15-2007, 08:02 PM   #992
SavageSpawn's Avatar
I picked up some hardened steel Diff Cross Pin kit off of eBay about a month ago and I finally got around to installing them today. My problem is I can not get the diffs apart in my Matrix TR RTR. Did they use a red lock tight?
I have heard about putting items that have red lock in the oven. My question is how long I bake the diffs for and at what temp.
Home depot sells a min blow torch for like 20 bucks would this is easer or more dangerious.
I've come here today to chew bubble gum and kick ass... and I'm all out of bubble gum.
SavageSpawn is offline   Reply With Quote
Old 12-16-2007, 07:14 AM   #993
lockmouth's Avatar
Savage, if yuo have a hot soldering iron just hold it on each screw until they heat up, did try to get it out while the screw is still hot. I have a electric stove, so I just sit the diff on the hot element for 30 second it works perfect
MARIO KNOX
HOTBODIES RACING / FULL THROTTLE RACEWAY (OWNER / OPERATOR)
lockmouth is offline   Reply With Quote
Old 12-16-2007, 06:10 PM   #994
My soldering iron must be a piece of crap so I ended up baking the diffs at 500 degrees for about 7 minutes each. I ended up stripping one screw. I used my Dremed and got it out. So I'm going to try 80wt gear oil in the front with no cross pins. 30,000 in the center and 3000wt in the rear with cross pins.
Old 12-19-2007, 03:41 AM   #995
Default Clutch Question
Guys,
I've totalled my clutch shoes and I need some help. I'm hoping you can answer some questions for me:
* Whats the difference between shorter and longer clutch springs (gold/black etc)?
* Whats the operating difference is there between the carbon and the Aluminum clutch shoes (faster or harder engage etc)?
* You can get more or less teeth on the bell housing, what do more or teeth do?
* Are the clutches, the shoes, springs and the bell housings universal?
* Is there any maintenance that has to be done on the bell housing. Mine isn't really smooth inside after the clutch shoes busted in half. I'm wondering if it needs to be grinded smooth with a dremel or someting?
* I read somewhere that you shouldn't go between Aluminium and Carbon shoes on the same bell housing because of a coating that the carbon deposits on the inside of the bell housing?
* A lot of people seem to use 2 springs of one type, and one spring of another type. This makes sense more or less, in that one shoe engages quicker than the others, is this the reason, is there anything else to it?
I think thats about it for now. I know its a lot of questions, but you guys are really on the ball and have been fantastic in the help department so far.
Jase
Thorin is offline   Reply With Quote
Old 12-19-2007, 11:45 AM   #996
Originally Posted by Thorin View Post
Guys,
* Whats the difference between shorter and longer clutch springs (gold/black etc)? Black is 1.0 and gold is 1.1 (get the gold)
* Whats the operating difference is there between the carbon and the Aluminum clutch shoes (faster or harder engage etc)? Alum does not slip
* You can get more or less teeth on the bell housing, what do more or teeth do? More teeth=higher top speed
* Are the clutches, the shoes, springs and the bell housings universal? No
* Is there any maintenance that has to be done on the bell housing. Mine isn't really smooth inside after the clutch shoes busted in half. I'm wondering if it needs to be grinded smooth with a dremel or someting? Not realy needed if you use alum shoes
* I read somewhere that you shouldn't go between Aluminium and Carbon shoes on the same bell housing because of a coating that the carbon deposits on the inside of the bell housing? Correct, it will eat up the carbon shoes.
* A lot of people seem to use 2 springs of one type, and one spring of another type. This makes sense more or less, in that one shoe engages quicker than the others, is this the reason, is there anything else to it? That is correct, softer engagement
Jase
1
VP-Pro USA - www.raceVPpro.com
Agama USA - www.AgamaUSA.com
Maxy's Fuel - www.Maxysfuel.com
Machine's R/C H is offline   Reply With Quote
Old 12-19-2007, 02:16 PM   #997
rregl0612's Avatar
Guys,
* Whats the difference between shorter and longer clutch springs (gold/black etc)? softer earlier engagement
.. .. .9 middle 1.0. latest hardest 1.1..
aluminum wears a bit slower but requires more maintenance.. checking for splitting in beetween rounds or atleast before a main.. .. alum usually has stronger grab.. but depends on which .. hardness of shoe you buy..
Carbon good for bashing.. and learning.. less maintenance.. cheaper to maintain.. once you go alum.. you rarely go back... both if maintained are usually good for atleast a gallon.. sometimes I get more on alum.. but not often.. usually replaced for peace of mind!!..
* You can get more or less teeth on the bell housing, what do more or teeth do? more teeth on bell faster top end less bottom... vice versa..
For the most part shoes springs. and bells can be interchangeable... really kinda hit or miss..
.. whenever cleaning i always check clutch.. always sand bell before assembly.. or whenever possible.. ( i use dremel to save time..)
running carbons and alum on same bell is True but i do it all the time.. who has money to buy two bells of each tooth you run.. ??/ I just sand em out if carbons were in there.. but rarely ever run the carbons.. only really keep em for spares if im in a pinch...*
yup.. gives a less rippy clutch with quicker wear on one shoe.. benefits easier to drive.. down fall wears one shoe down quicker.. if your replacin one.. your replacin all of em at $20 a set.. I like to get full use....
Jase
Old 12-20-2007, 01:03 AM   #998
Thanks for the clutch info. I've gone with the Al clutch shoes and cleaned up the bell housings, and am using the spare gold springs I had. Previously I was using the gold springs with the blue shoes (cant find them anywhere) so this should do the job well.
I know Robert had the OFNA Super big bore shocks installed, I'm wondering how they went. Mine works I'm just not all that satisfied with the performance I am getting from them. Anyone else used these super big bore shocks? Any issues with installation? Will they install onto the posts that are supplied and fit into the CNC shock towers?
Jase
Old 12-20-2007, 08:38 AM   #999
lockmouth's Avatar
Jase
The Jammin Super Bore shocks work awesome. I'm running 50 wt. losi in the front and 40 wt losi in the rear with the blue springs. The gray spring also work great with the same set-up.
Just use the stand-offs that come with the super bore, there will be no modifications needed.
MARIO KNOX
Old 12-20-2007, 12:26 PM   #1000
Postalmal's Avatar
Default Kyosho bodies
Will the Proline bodies for the Kyosho ST-R and 777 fit well on the Matrix TR and the buggy? Trying to negotiate a deal for these.
Postalmal is offline   Reply With Quote
Old 12-20-2007, 03:33 PM   #1001
I have the CEN blue alum shoes in stock.
machinesrchobbies@hotmail.com
Old 12-22-2007, 06:32 PM   #1002
rregl0612's Avatar
Gene or Andrew..
Is there going to be anyone representing CEN at Motorama this year.. Last year Chris Systma took the win!!..
Gene I love to see you make it but from FL its a haul up to PA..
>> Tracks gunna be awesome they put some cads of it up on tech talk..
anyone else who is within a few hrs of here.. this will be a good race.!!.
http://www.motoramaevents.com/motor_index.php go here for sign ups..
Thanks to my sponsors, My Wallet, endorsed by Some crazy pharmaceutical corporation!!!
Member of "The White Wheel Mafia!"
Bumps and Jumps, Pitstop Hobbies, LCRC!
Old 12-23-2007, 08:51 PM   #1003
I went to the track on Friday and killed the one way bearing in my Cen Matrix TR RTR pre OS engine. My question can I just buy a starter box to start the RTR engine and just leave the pull start in tact? I donít want to deal with one way bearings.
Old 12-24-2007, 12:02 AM   #1004
I totalled the pull start on my OS30. I just removed the spring and most of the cord from the pullstart, and sealed the hole where the cord comes out. Have checked it since and there is no dirt at all in there, and there would only be a very minimal amount of drag as a result.
Jase
Old 12-24-2007, 10:59 AM   #1005
Originally Posted by rregl0612 View Post
Gene or Andrew..
We need info on the race 1st. please e-mail
cen matrix CHAVAN30 Nitro Off-Road 1177 08-05-2011 05:23 PM
CEN MATRIX FRE helivaguy Nitro Off-Road 4 08-27-2008 05:52 PM
Cen Matrix dieseldog20 R/C Items: Wanted to Buy 0 02-06-2008 05:31 PM
Matrix and Matrix TR Factory Race Edition Kits SmoothB R/C Items: For Sale/Trade 4 05-31-2007 05:36 PM
Dye matrix 5 and DYE matrix 4 w/ tanks and halos for sale yuk17bandit Other Items: For Sale/Trade or Wanted to Buy 0 11-07-2006 10:49 AM
