Old 09-06-2007, 08:21 PM   #766
ILDRVR's Avatar
Sounds good Josh, I take it you will be up Friday afternoon? I will see you at the track.
ILDRVR is offline   Reply With Quote
Old 09-07-2007, 07:36 AM   #767
Mcran's Avatar
Front:
Ride Height: Chassis Level after adjusting rear ride height
Toe Out: +1
Camber : -2
Droop: Max
Sway Bar: None
Shock Oil: Losi 60wt
Pistons: #1
Spring: Stock (Green)
Ackerman: Back Hole
Shock Location: Tower lower outer (4) / Inside on Arm
Camber Link: Upper hole on hub / Bottom hole on tower
Diffs:
Front-7,000 / Center-20,000 / Rear-3,000 (Cross Pins in all)
(You can run the stock Cen diff in the front without cross pins packed with grease for more steering)
Rear:
Ride Height: Arms just above level
Tow & Squat Block: T2S2
Camber: -3
Droop: Max
Sway Bar: Stock
Shock Oil: Cen 30wt
Pistons: #2
Camber Link: Upper Inner hole on hub (B) / Outer upper hole on tower (1)
Lower Hole on Hub: Use the lower hole on bottom of hub
Miscellaneous:
Clutch setup: 13 Tooth Cen clutchbell with Cen blue aluminum shoes / 1.1 springs
Engine: RB-Mods Extreme Modded JP FX21B 5N Ceramic Bearings (Temps around 240 at plug after 30 minute Main)
Pipe: JP-2 with the stock header
Fuel: Byrons Race 3000 30%
Plug: RB or Novarossi #5 Normal
Body: Proline Mugen Crowd Pleazer 2.0 for the MBX5T
Wheels & Tires: Pro-line MTR Holeshots (stock inserts) with 17mm half offset OFNA Rims
Receiver: Spectrum DSM
Battery & Switch: HT Batteries HT220 Li-po 1500ma 7.4V with HT Batteries HT410 7V regulator
Radio: Airtonics M11 with HT Batteries HT310 Li-po 1200ma
Servo: Hitec HS-5955TG Digital steering / Futaba S9351 Digital High Torque Throttle & Brake
This setup has worked great for Justin on all the tracks we have raced on. The most important thing is to pay attention to detail. The smallest things will throw the handling way off. Make sure the truck rolls freely with the servo centered and radio on (No drag brake) and that the throttle is completely closed.
Team Associated, LRP, Reedy, Hobbico - www.hobbico.com,
JConcepts - www.JConcepts.net, Futaba - www.futaba-rc.com,
OS Engines - www.osengines.com, Kal-Gard - www.Kalgard.com,
Murnan Modified Motors - www.Murnanmodified.com
Mcran is offline   Reply With Quote
Old 09-07-2007, 10:47 PM   #768
ILDRVR's Avatar
Great post, It gave me a few ideas to try.
Keep posting set ups, I am always open to try some new things that I may not think about.
Old 09-08-2007, 08:31 PM   #769
MikeyMike1969's Avatar
what parts do you need to convert to 17mm hexes?
MikeyMike1969 is offline   Reply With Quote
Old 09-08-2007, 10:58 PM   #770
17mm hexes and some shims
go really fast and turn left....
Robert.Hull is offline   Reply With Quote
Old 09-09-2007, 12:27 PM   #771
Will the Matrix buggy hexes work?
Old 09-10-2007, 10:31 AM   #772
Mcran's Avatar
We used the 17mm wheel hubs/Hexes (MX043) from the Matrix Buggy. We also used the rear axle from the buggy (MX093) for the rear of the truck, no shimming. You will also need some 8mm shims (KYO96046) Kyosho shims kit 8x10. Shim the inside of the axle between the axle and the back of the inner bearing. That way it will push the dogbones into the outdrive more and stop any problems with the dogbones coming out. If you use the buggy axles on the rear you will need some 3x4mm set screws. The TR axles take a 5x5 set screw. Don't forget the wheel nuts. I had some Jammin nuts but they didn't fit.
Old 09-10-2007, 05:46 PM   #773
black-knight's Avatar
R/C Tech Charter Subscriber
Is there a technical benefit for running 17mm hubs/hexes?
Black-Knight - None shall pass!
www.nbhc.com.au - www.facebook.com/smaracing
black-knight is offline   Reply With Quote
Old 09-10-2007, 08:08 PM   #774
outtafocus's Avatar
17mm hexes are lighter weight than the 23mm ones.
Plus its alot easier to find 17mm truggy wheels on hobby shop shelves, you can use brands other than Proline.
There are several 17mm hexes that will work.
Mugen, TTR and even Losi.
The CEN hexes are a little more expensive.
http://www.amainhobbies.com/product_...ducts_id/10064
and that doesnt include nuts or pins
Losi has a 17mm hex set which includes 2 hexes 2 nuts and the pins you will need.
http://www.amainhobbies.com/product_...oducts_id/7716
TTR standard
http://www.amainhobbies.com/product_...oducts_id/2607
TTR red light weight-requires nuts and pins
http://www.amainhobbies.com/product_...oducts_id/2549
http://www.amainhobbies.com/product_...oducts_id/2550
www.rcdepot.ca-Hobbywing-Tekno-TLR-Brass Knuckle Brush Worx
outtafocus is offline   Reply With Quote
Old 09-10-2007, 08:20 PM   #775
ILDRVR's Avatar
Default brakes
Does anyone else have problems with their brake levers binding when the servo pushes and pulls? It seams like the lever and the guide stick.
Any helpful tips?
Tarara Racing
Tea's Hobby Shop & Raceway Park
Cheese City Xtreme RC
Old 09-10-2007, 08:36 PM   #776
TripleX-JT's Avatar
Send a message via MSN to TripleX-JT
The only time I had them stick was actually the throttle/brake linkage was bent so it really was hard to push or pull the brakes off and on.
Josh Thompson
RC Khaos Series
RC Pro WI
TripleX-JT is offline   Reply With Quote
Old 09-10-2007, 08:38 PM   #777
ILDRVR's Avatar
That is what I thought, but my linkages are not bent??????
Tarara Racing
Old 09-11-2007, 04:36 PM   #778
Default CEN Wins the 1/8th scale National Championships!!!
CEN Racing wins the 2007 Brazil 1:8 Buggy National Championship!!!
http://picasaweb.google.co.uk/kyosho...natoBrasileiro
http://picasaweb.google.co.uk/kyosho...20213569549794
Resultado da Final X Campeonato Brasileiro - Buggy
Data 11/09/2007 06:11:02 | Editoria: Brasileiro
Segue abaixo o Resultado da Final do X Campeonato Brasileiro de Buggy, realizado em Fortaleza no Asa Branca Speedway neste final de semana. Como um piloto Americano não pode ser campeão Brasileiro, conforme o regulamento, o Atual Campeão é o piloto de SP, HENRIQUE WINIK! Diga-se de passagem, merecidamente, pois andou muito, todos os dias do evento!
Clique Aqui para ver o Resultado com as Voltas
Resultado Final da Categoria Buggy
Position Car # Name Laps Time Fastest
Lap Average
Lap
1 2 GENE HICKERSON (USA) 130 1h00m16.313 24.996 27.818
2 3 KRIS MOORE (USA) 128 1h00m03.346 24.953 28.151
3 1 HENRIQUE WINIK (SP) 126 1h00m03.998 24.405 28.603
4 4 MARCELLO BELLO (SP) 120 1h00m01.599 25.346 30.013
5 7 FRED ANDRES (SP) 116 1h00m21.188 26.609 31.217
6 5 GIANCARLO TUDISCO (SP) 114 59m51.861 27.340 31.508
7 10 PEDRO THIEME (PR) 95 1h00m01.149 26.078 37.907
8 9 JORGINHO CARVALHO (DF) 92 1h00m08.058 26.904 39.218
9 6 HEITOR NOGUEIRA (SP) 91 1h00m07.462 26.211 39.642
10 8 FRANCISCO JUNIOR (CE) 73 1h00m11.080 26.629 49.467
Fonte: Organização do Brasileiro 2007
Esta notícia foi publicada no COPA INFERNO
http://www.copainferno.com.br
Endereço desta notícia:
http://www.copainferno.com.br/article.php?storyid=1935
Machine's R/C H is offline   Reply With Quote
Old 09-11-2007, 07:30 PM   #779
ILDRVR's Avatar
Congrats! That looks like a very well groomed track. I have never seen a grass track before. We have a "No green" rule at our track. I thought our pit lane was pretty nice, but that is definatly just a bit nicer
Tarara Racing
Old 09-11-2007, 08:16 PM   #780
ILDRVR's Avatar
How do I get Cen apparel? I must have missed it on the website? I would like to have a t-shirt to wear at big races.
Tarara Racing
cen matrix CHAVAN30 Nitro Off-Road 1177 08-05-2011 05:23 PM
CEN MATRIX FRE helivaguy Nitro Off-Road 4 08-27-2008 05:52 PM
Cen Matrix dieseldog20 R/C Items: Wanted to Buy 0 02-06-2008 05:31 PM
Matrix and Matrix TR Factory Race Edition Kits SmoothB R/C Items: For Sale/Trade 4 05-31-2007 05:36 PM
Dye matrix 5 and DYE matrix 4 w/ tanks and halos for sale yuk17bandit Other Items: For Sale/Trade or Wanted to Buy 0 11-07-2006 10:49 AM
