Old 08-21-2007, 08:06 AM   #751
The new arms will replace the current arms eventually.
In the mean time, you can take a front CVD and punch the pin out and use them in the rear. Use the lower outer hole in the tower and the inner hole on the arm. Or use the long shock ends. Or you can use Kyo hubs and use the front CVD in the rear. Or use -3' camber. Or you can use 2' rear toe block. Or you can run the hubs all the way back because that pushes the CVD's in more. Every little set-up change makes a difference in the CVD arc & position. For the front, just shim in the CVD's. Pro-line LST 23mm hubs work also if you don't want to run 17mm hubs.
The only time I have ever poped a rear CVD out was when I ran a 3t2s block with the hubs all the way forward, but I normally run them all the way back. With the new arms, they will never pop out.
VP-Pro USA - www.raceVPpro.com
Agama USA - www.AgamaUSA.com
Maxy's Fuel - www.Maxysfuel.com
Machine's R/C H is offline   Reply With Quote
Old 08-21-2007, 09:32 AM   #752
Curious though.. Why Cen concentrated the effort on revising the A-arm as suppose to just make the shaft a little longer?
pedsaktix is offline   Reply With Quote
Old 08-21-2007, 09:52 AM   #753
The new arms will improve the handling and performance. Longer bones would change nothing. I expected them to just make longer CVD's since that would be the cheapest fix (no new mold), but I am happy that they made shorter front arms and longer rear arms to give the truck even more steering instead like I asked back in December of 2006.
They made 3 different lengths for us to try (16 differnt combinations), so we all ran differnt arms last weekend. My truck had more steering then ever even with a front sway bar. I hope they go with my arm set-up. But Andy liked his arm combo as well and I think Chris ran the stock arms and he was the only one to do 14 laps, so they all worked great because it is a great truck. Joey ran another combo and Pudin ran another. But on tight tracks like here in FL, the ones I ran should be the best in theory.
Old 08-21-2007, 10:08 AM   #754
Thanks Gene. that explains it.. great info.
Old 08-25-2007, 06:35 PM   #755
rregl0612's Avatar
Trader Rating: 33 (100%+)
Finally Ready for tomorows Roar race.. Rained in the main last week.. wow what a clean up.. Hopefully weather holds up cause I am not going through that again..( yeah I probly will.) But it will be a pita on brand new bearings.. : )
rregl0612 is offline   Reply With Quote
Old 08-30-2007, 03:46 PM   #756
rregl0612's Avatar
I think my Rusty screws scared everyone away..!!! : )
Old 08-30-2007, 05:00 PM   #757
I thought the brown hardware was HUDY spring steel lol! BTW Nice truggy! Everytime I try to accelerate too hard and my rear on my 8T comes around, I end up missing my matrix.
Losi 8ight-T 1.0 OS Speed JR 9000S/T
Losi 8ight 1.0 C6BB7T 2045 086 Hitec 5997TG/JR 9000S
Losi 22 Tekin RSpro 8.5/JR9000S
All controlled by 3PK/FASST
magbarn is offline   Reply With Quote
Old 08-30-2007, 05:57 PM   #758
MikeyMike1969's Avatar
Gene, just curious why you don't run the rear CNC carriers?
MikeyMike1969 is offline   Reply With Quote
Old 08-30-2007, 07:31 PM   #759
lockmouth's Avatar
I think weight is the main reason, plus it is not needed. To me the front carriers are not needed also. The stock plastic pieces are great to me.
MARIO KNOX
HOTBODIES RACING / FULL THROTTLE RACEWAY (OWNER / OPERATOR)
lockmouth is offline   Reply With Quote
Old 09-02-2007, 06:27 PM   #760
black-knight's Avatar
R/C Tech Charter Subscriber
Iím hoping to race a Truggy for the first time later this month, can anyone recommended a suitable servo spec or model for the Matrix TR...
Thanks in advance.
Black-Knight - None shall pass!
www.nbhc.com.au - www.facebook.com/smaracing
black-knight is offline   Reply With Quote
Old 09-03-2007, 08:22 AM   #761
rregl0612's Avatar
anything atleast 150 oz and .15 or faster..should do minimally
the more torque the better... speeed is a personal option..
Run a 8711 400 oz at .15 and my steering is super fast
Old 09-03-2007, 07:33 PM   #762
ILDRVR's Avatar
Default set up
Does anyone have any setups for an open-dry-hardpacked-clay/dirt-dusty track. Right now I am running:
Front LSD 80wt gear
Center Cross pins 5000
Rear Cross pins 2000
Front Shocks - Piston #1 40 wt
Rear Shocks - Piston #1 35 wt
Tires: Proline Crimefighters zero offset (I used to use the 1/2" but the zero turn in a lot tighter)
This is not too bad, but I was wondering what others have tried.
ILDRVR is offline   Reply With Quote
Old 09-04-2007, 04:38 AM   #763
rregl0612's Avatar
5k in the center seems pretty low.. I run 10 k.. 15 k if im onblue groove...
this is if your looking for more rear bite.. try this..
other than that all sounds well I would move your rear upper arm to the inner middle hole to lengthen your link.. This will make the rear of the truck more controllable by changing your roll center.. also if thats still not enough you can then run it to the outer hole at the wheel..
I run different pistons and heavier oils.. but you should be in the ballpark..
Old 09-05-2007, 08:06 PM   #764
ILDRVR's Avatar
Thanks, Does anyone else have any setup input?
Old 09-06-2007, 05:54 AM   #765
TripleX-JT's Avatar
Send a message via MSN to TripleX-JT
Ill show you mine in Monroe. It seems to work on all tracks in Wisconsin so far.
Josh Thompson
RC Khaos Series
Rc Pro WI
TripleX-JT is offline   Reply With Quote
cen matrix CHAVAN30 Nitro Off-Road 1177 08-05-2011 05:23 PM
CEN MATRIX FRE helivaguy Nitro Off-Road 4 08-27-2008 05:52 PM
Cen Matrix dieseldog20 R/C Items: Wanted to Buy 0 02-06-2008 05:31 PM
Matrix and Matrix TR Factory Race Edition Kits SmoothB R/C Items: For Sale/Trade 4 05-31-2007 05:36 PM
Dye matrix 5 and DYE matrix 4 w/ tanks and halos for sale yuk17bandit Other Items: For Sale/Trade or Wanted to Buy 0 11-07-2006 10:49 AM
