Old 08-08-2007, 04:21 PM   #721
ILDRVR's Avatar
Thanks for the help
ILDRVR is offline   Reply With Quote
Old 08-08-2007, 08:04 PM   #722
slaytanic's Avatar
Trader Rating: 20 (95%+)
I may be misinformed but when I spoke with support at Cen they said that you can use the cross pins in the aluminum diff cups. You just need to shim them. I hope it's true cuz I really dont want to switch to the plastic ones
slaytanic is offline   Reply With Quote
Old 08-09-2007, 03:45 PM   #723
outtafocus's Avatar
I had an awesome race this past weekend with my TR.
Aug 4th and 5th were the Alberta finals for the CORCS series. (Canadian Offroad Championship Series)
This race was held in Calgary and was hosted by our local club RCGEARS.
My truck handled very well and I was able to put down some very good laps. I had no problems staying on the tails of Losi and Jammin truggies.
I ended up finishing 2nd in the B main after bump ups were removed.
I am very confident with this truck, and have yet to break anything, well except that servo saver.
I do believe that the CEN cross pins will work in the aluminum diffs but will require you to take your time shimming the gears, Genes cross pins already come with the correct thickness washers and shims to take the guess work out of the equation.
I do not see an issue with the plastic diff cases for the new cross pins, they seem to be working very well for a fellow CEN racer here in Calgary. And they are cheap.
www.rcdepot.ca-Hobbywing-Tekno-TLR-Brass Knuckle Brush Worx
outtafocus is offline   Reply With Quote
Old 08-09-2007, 03:56 PM   #724
TripleX-JT's Avatar
Send a message via MSN to TripleX-JT
What should you run for length of fuel line from the carb to tank?
Also from pipe to tank?
Josh
TripleX-JT is offline   Reply With Quote
Old 08-09-2007, 04:08 PM   #725
outtafocus's Avatar
From the pipe pressure nipple to the tank inlet you would usually want a minimum of 12inches, this helps reduce the pulsing which comes from the engine. Some guys also put a fuel filter on their pressure line to act as an equalizing chamber (I dont)
The fuel line from tank to the carb is probably one for debate. I have seen guys run shortest possible and I have also seen guys have 2 ft of fuel line wrapped around their car.
In thoery the longer the fuel line the longer an engine can run upside down.
Multiple fuel filters seem very popular. .
The biggest thing with fuel line is to run it away from any moving gears and away from the hot engine. Cold fuel is better than hot.
Old 08-09-2007, 11:23 PM   #726
kamlooper's Avatar
Outtafocus, are you coming to the corcs national in bc?
kamlooper is offline   Reply With Quote
Old 08-10-2007, 09:51 AM   #727
Mcran's Avatar
The new cross pins will work with the aluminum diff cases. You just need to use a 1mm thick washer between each small bevel gear and the diff case. The shims that come with Gene’s hardened cross pins work great or you can pick the washers up at the local hardware store. I like the plastic diff cases better also.
Mcran is offline   Reply With Quote
Old 08-10-2007, 01:55 PM   #728
rregl0612's Avatar
Trader Rating: 33 (100%+)
Anyone running the ECK Tek motor mounts I stripped a screw on my stock mounts....
DO they work on the TR.. I know they were made for the buggy!?????
rregl0612 is offline   Reply With Quote
Old 08-11-2007, 04:50 AM   #729
Trader Rating: 19 (100%+)
I'm running a kingheadz mount for a st-r, fits well. I like the idea of the plastic diff cases, it reduces rotating mass, and that's always good.
pooldoc is offline   Reply With Quote
Old 08-11-2007, 12:06 PM   #730
MikaR's Avatar
Here's my TR Arena, this baby rocks.. RB 928 engine. Thanks
I also stripped screw (2 actually) from the longer mount.. I'm using nylocks and longer screws to secure them in place.. works pretty well..
MikaR is offline   Reply With Quote
Old 08-11-2007, 01:31 PM   #731
Yes, always use nuts on the engine plates.
VP-Pro USA - www.raceVPpro.com
Agama USA - www.AgamaUSA.com
Maxy's Fuel - www.Maxysfuel.com
Machine's R/C H is offline   Reply With Quote
Old 08-11-2007, 01:56 PM   #732
Default Thought I this would be a good place to post this
Thought this would be a good place to post this. I have my cen matrix tr for sale, it has less than 2 1/2 gallons threw it, it comes with alot of extra parts,clutch shoes,spring,probley about 4-5 full sets of clutch shoes a springs, I have 17mm adapters on it now but it also comes with the stock 23mm adapters. I am asking 325.00 for the truggy and all the extra stuff that comes with it. Here is the link where I am selling it. http://lstforums.com/forums/viewtopic.php?f=14&t=9435
To contact me just pm me here on this site, if it is easier just email me at, kurthjoshua@sbcglobal.net you can also give me a call at this number 210-639-3951 to make it even easier on you and me so yourself and I can talk direckley to one another, but what ever way is easier for you to contact me is great.
Joshua Kurth
losi8ight is offline   Reply With Quote
Old 08-11-2007, 03:35 PM   #733
http://www.rcpics.net/view_single.php?medid=85811
My Matrix TR Arena is ready for the ROAR Truck Nats.
Http://www.machinesrchobbies.com
Old 08-11-2007, 03:49 PM   #734
rregl0612's Avatar
Default Pool doc
are you running.. KP-315 or KP-316..... ???? will 316 work?
http://kingheadz.com/
Old 08-12-2007, 05:20 PM   #735
http://www.rcpics.net/media/100_0345---rcp1.jpg
http://www.rcpics.net/media/100_0343.jpg
http://www.machinesrchbbies.com
cen matrix CHAVAN30 Nitro Off-Road 1177 08-05-2011 05:23 PM
CEN MATRIX FRE helivaguy Nitro Off-Road 4 08-27-2008 05:52 PM
Cen Matrix dieseldog20 R/C Items: Wanted to Buy 0 02-06-2008 05:31 PM
Matrix and Matrix TR Factory Race Edition Kits SmoothB R/C Items: For Sale/Trade 4 05-31-2007 05:36 PM
Dye matrix 5 and DYE matrix 4 w/ tanks and halos for sale yuk17bandit Other Items: For Sale/Trade or Wanted to Buy 0 11-07-2006 10:49 AM
