Old 06-09-2007, 05:08 PM   #601
A_Chair_In_Hell's Avatar
Originally Posted by Robert.Hull View Post
just a little 4-way wrench and i think 2 or 3 allen wrenches
Just to let know there are no tools, no wheels, no shell, no shim or crank shaft cone (supply own motor and electrics) but there is 30wt shock oil 5000wt diff fluid, small amount of lube, great 2 stage air filter, clear instructions until you to the brakes setup which is a bit painful... the truck is a great kit to put together as this being my first kit and Truggy, seems to be a very solid truck...just a bit annoyed the the LHS don't advise me on there web site that the Matrix Kit didn't supply the wheels & shell cause I'm a long weekend which I had planned to run the beatch in...Oh well....we are a long time dead!
A_Chair_In_Hell is offline   Reply With Quote
Old 06-09-2007, 06:28 PM   #602
Hey Robert just wodering if you had any more pictures of your Cen Truggy with its lid off? I just would like to see how you have arranged things....Im cool if your unable too...can only ask, Cheers.
Once I have completed mine I will post pictures, be the end of the week
Old 06-09-2007, 07:08 PM   #603
well you got the pro kit so of course you have to supply all that stuff
yea ill get some pics up in a day or two
Robert.Hull is offline   Reply With Quote
Old 06-09-2007, 08:11 PM   #604
As I found out, but the guys @ my LHS were embarrassed because they where unaware...they have done a good deal on wheels and a shell for me...
Old 06-10-2007, 06:59 AM   #605
Trader Rating: 19 (100%+)
Congrats on the win Gene!
pooldoc is offline   Reply With Quote
Old 06-10-2007, 07:42 AM   #606
do you run the fuel line around the engine head right over the exh? I see this all the time and many manuals say to run it like that but I would think the fuel doesn't need to be heated up like that? plus the abrasion factor...
auto2 is offline   Reply With Quote
Old 06-10-2007, 07:44 AM   #607
fuel routing
Old 06-10-2007, 08:24 AM   #608
Default Question
Question. I got the crosspin conversion for my truggy and I was wondering when you put them in is there supposed to be alittle slop in the diffs because I put them in yesterday and ran then but now when I spin the rear diff it like there is a tooth missing because it will spin one way real smooth and the other way it locks up.
losi8ight is offline   Reply With Quote
Old 06-10-2007, 08:58 AM   #609
t4usee's Avatar
Sounds like a broken tooth on one of the spider gears. Genes pins come with washers for you to get the spacing correct. I have bought 2 kits from Gene and only had to run one washer on each end of all the pins. If I were you I would definately pull the diff out to inspect for damage.
t4usee is offline   Reply With Quote
Old 06-10-2007, 09:46 AM   #610
Default Thanks
Thanks T4usee. Yeah I pulled out the rear diff and there was no damage on any of the spider gears. So I pulled out the center diff and no damage either. What I did do this time is I saw that I forgot to put the 6mm washers on the 2 ends of the diff where the cvds slide into so I put 1 6mm washer on each side. So maybe that's what was wrong. I am new to the cen's products so by any chance can you post your setup just so I can see the diffrence between yours and mine. Thank you very much.
Old 06-11-2007, 04:45 PM   #611
PQRS...'s Avatar
diffs... i hate em, in general! i killed my rear in 20 or so tanks? i do have the cross pin mod, so maybe i got the softer ones? ill be ordering the hardened ones asap!! they make it drive killer!
PQRS... is offline   Reply With Quote
Old 06-12-2007, 10:55 AM   #612
Default CEN Matrix TR Arena TQ & 1st Again
http://www.buggy-sport.info/blank.ph...contentid=6614
Machine's R/C H is offline   Reply With Quote
Old 06-12-2007, 11:08 AM   #613
Can we get your setup? Thanks, Pooldoc
Old 06-12-2007, 01:24 PM   #614
http://www.cenracing.com/race/pic/genesetup07.pdf
VP-Pro USA - www.raceVPpro.com
Agama USA - www.AgamaUSA.com
Maxy's Fuel - www.Maxysfuel.com
Old 06-12-2007, 02:42 PM   #615
Is that the setup you ran at Farmer's? Thanks
cen matrix CHAVAN30 Nitro Off-Road 1177 08-05-2011 05:23 PM
CEN MATRIX FRE helivaguy Nitro Off-Road 4 08-27-2008 05:52 PM
Cen Matrix dieseldog20 R/C Items: Wanted to Buy 0 02-06-2008 05:31 PM
Matrix and Matrix TR Factory Race Edition Kits SmoothB R/C Items: For Sale/Trade 4 05-31-2007 05:36 PM
Dye matrix 5 and DYE matrix 4 w/ tanks and halos for sale yuk17bandit Other Items: For Sale/Trade or Wanted to Buy 0 11-07-2006 10:49 AM
