Old 05-29-2007, 06:38 AM   #571
no I ment it works just as good as any filter out there. no need to get something else. :-)
Thanks auto2. There is a lot of great information of this forum and I appreciate everyone's help.
Dr Gonzo is offline   Reply With Quote
Old 05-29-2007, 11:05 AM   #572
The CEN filter fits the nest on the TR Arena imo because it has a tall elbow allowing it to sit on top of the center chassis braces.
VP-Pro USA - www.raceVPpro.com
Agama USA - www.AgamaUSA.com
Maxy's Fuel - www.Maxysfuel.com
Machine's R/C H is offline   Reply With Quote
Old 06-01-2007, 03:17 PM   #573
A_Chair_In_Hell's Avatar
Just out of curiosity what tools come CEN Matrix TR Arena FRE Truggy?
_____________________________________________
CEN MATRIX TR [Arena Factory Race Edition Truggy]
- Gene Hickerson Turnbuckle Mod -
- Lockmouth Steering Mod -
- O.S. Max-21 VZ-B V-Spec -
- O.S. T-2060SC Tuned Pipe -
- HiTec Digital 5955TG -
- Spektrum DX3.0 -
- AT Racing Fuel > More Horsepower - More Torque - More Wear Protection -
A_Chair_In_Hell is offline   Reply With Quote
Old 06-01-2007, 03:30 PM   #574
just a little 4-way wrench and i think 2 or 3 allen wrenches
go really fast and turn left....
Robert.Hull is offline   Reply With Quote
Old 06-01-2007, 04:43 PM   #575
[B]Thanks Robert...and from what i have read the kit also comes with shockie & diff fluid? [/B]
- Spektrum DX3.0 -
Old 06-01-2007, 07:59 PM   #576
ILDRVR's Avatar
My kit did not come with any tools. But it did have the grease and shock oil. Of course many of us use different grease/oil for our set-ups
Tarara Racing
Tea's Hobby Shop & Raceway Park
Cheese City Xtreme RC
ILDRVR is offline   Reply With Quote
Old 06-01-2007, 09:54 PM   #577
yea it comes with a base set up fluids
like i said i might have gotten tools i dont pay attention to what tools it came with cause its not like i really use those little allen wrenches
Old 06-01-2007, 11:14 PM   #578
Sweet I get my CEN Matrix TR Arena FRE Truggy on Monday, so i look forward in being apart of CEN crowd...
- Spektrum DX3.0 -
Old 06-03-2007, 07:04 AM   #579
corpseorourke's Avatar
hey guys i currently have a cen matrix but im having some trouble finding a replacment pullstart can any1 help oh and im living in ireland hence the problem lol
corpseorourke is offline   Reply With Quote
Old 06-03-2007, 10:24 AM   #580
call up headrus hobbies at 626-798-7874 and tell them what you need and they will be able to get it for you
Old 06-03-2007, 07:34 PM   #581
Hey guys, I had a rough day at the track again with my CEN. today my troubles began with both of my front dog bones they kept popping out of my out drives. I have the shoks mounted at the highest hole on the tower, And i have the botom mounted in the inside hole. Does anybody have any help for me? I will appreciate anything. it doing it both of my CEn truggy and buggy. I shelf them after the 2 nd heats tired of dealing with them.
FT_Wacked is offline   Reply With Quote
Old 06-03-2007, 08:42 PM   #582
lockmouth's Avatar
Trader Rating: 33 (100%+)
You can try putting the long shock end on the front, this should fix it. I cut a piece of fuel tubing and put it on the shock shaft to keep it from bottoming out. This seem to fix it for me.
Some long outdrive like the Xray's would be the ticket, or maybe Cen could do a running fix an make the shaft longer???
I haven't had that much of a problem, but they pop out every now and then.
I just got a idea I'll let ya know if i get it to work
lockmouth is offline   Reply With Quote
Old 06-04-2007, 05:58 AM   #583
Trader Rating: 26 (100%+)
I have three options, first is the long shock end, it limits up travel, you can also drop the upper mount to the lower set of holes on the tower to limit uptravel as well, both make the shock bottom out sooner which means the dogbone doens't travel as far in the outdrive, I did find with the long shock ends on the front my truck jumped weird thgouh, because it gives you alot more downtravel,
2nd is convert to the CEN 17mm hexes, you then have to shim the axle, and this moves the dogbone approx 3/16" further into the outdrive, and it wont pop out again, it also means you can use set up jigs for both buggy and truggy, this is the method I went with just for the common set up jig,
3rd, the most difficult because you need a lathe or mill, but you can machine down the 23mm hexes, so the offset between the back face of the hex, and the pin is the same as the 17mm hexes, this means you need to shim them the same as the 17mm hexes, which does the same as above, but you can keep using the 23mm wheels if youve got any,
for the buggy you can use the center diff outdrives, with the hex shape, use them for the front diff as well, the "bowl" in them isn't as deep, so the bones dont pop out as easy, I also have a small pice of fuel tube on the shock shafts to limit up travel like lockmouth mentioned, and I'm in the lower set of holes on the tower,
bobf24 is online now   Reply With Quote
Old 06-04-2007, 06:39 PM   #584
Trader Rating: 19 (100%+)
You mean the dogbone pops out from the shock compressing too much? How long of fuel tubing do you use? Thanks Pooldoc
pooldoc is offline   Reply With Quote
Old 06-04-2007, 06:44 PM   #585
you guys have your front end set up wrong cause i use no tubing and my bones never pop out
cen matrix CHAVAN30 Nitro Off-Road 1177 08-05-2011 05:23 PM
CEN MATRIX FRE helivaguy Nitro Off-Road 4 08-27-2008 05:52 PM
Cen Matrix dieseldog20 R/C Items: Wanted to Buy 0 02-06-2008 05:31 PM
Matrix and Matrix TR Factory Race Edition Kits SmoothB R/C Items: For Sale/Trade 4 05-31-2007 05:36 PM
Dye matrix 5 and DYE matrix 4 w/ tanks and halos for sale yuk17bandit Other Items: For Sale/Trade or Wanted to Buy 0 11-07-2006 10:49 AM
