Old 05-13-2007, 03:52 PM   #481
7-10-5 is a good base set up
go really fast and turn left....
Robert.Hull is offline   Reply With Quote
Old 05-13-2007, 05:44 PM   #482
ILDRVR's Avatar
That is for the Stock LSD diffs right? (NO crosspins?)
Tarara Racing
Tea's Hobby Shop & Raceway Park
Cheese City Xtreme RC
ILDRVR is offline   Reply With Quote
Old 05-13-2007, 06:39 PM   #483
rregl0612's Avatar
Trader Rating: 33 (100%+)
Default diff...
maybe you are running on asphalt.. : ) j/k but that sounds super high for the blown out shitz we have around here..
ON stock lsd's I would try 80 wght gear oil front.. 5k middle.. and lightly grease the rear.. use 1/10 diff lube..
I was running 7 middle and if felt about 50/50 so 5k should give to the front a bit..
Just here to try to help and learn.. So Robert i mean no harm to you...
rregl0612 is offline   Reply With Quote
Old 05-13-2007, 07:52 PM   #484
ILDRVR's Avatar
Right now I am running pretty much the same...80wt gear oil front...5000 diff oil mid..and my rear diff is packed full with the grease included in the kit.
?By lightly packing the rear will it speed up the rear wheels? Should I experiment with this?
Tarara Racing
Old 05-13-2007, 08:12 PM   #485
ILDRVR's Avatar
My servo saver adjustment screw backed all the way down during my main this weekend. Should I use blue thread lock on this or is there another fix? I think I have seen a double screw setup before, but is it necessary?
Thank you
Tarara Racing
Old 05-13-2007, 09:00 PM   #486
rregl0612's Avatar
lightly packing the rear will increase rear traction so if it feels skaty or like it wants to come around Do it.. otherwise just leave it..
Personally am thinking of doing the crosspins on just the rear.. so I can run 2 or 3k back there...the lsd are too over-active with silicone for now.. though..
Just my two cents..
Old 05-13-2007, 09:02 PM   #487
rregl0612's Avatar
Default Servo Saver
Oh and I just put a little Blue loctite on it.. was having that prob.. too.. seems to have solved but double nutting would work as well.... You could also try to find a O ring that will fit inside the bell of the retaining nut .. that would work as well not sure of size probly around 10mm if you dont have calipers and want to know I can find out.. O ring probly being the cleanest option and would still allow easy adjustmen..
Old 05-13-2007, 09:29 PM   #488
ildrvr--yea no crosspins
rregl0612-- if i understand what you saying,you want the front to pull the truck in a hole shot ofcourse not alot but you would cause then you would get better steering and handling
if i miss understood you please let me know so i can make sure you get the right info you want
Old 05-13-2007, 10:26 PM   #489
Default My setup is
I have about 12-13 tanks on my new matrix tr pro and so far I have found this set up to work the best. This is just a basic outline of my setup. The track I run on is.
Technical
kind of bumpy
dry most of the time
mid size track
loose
2-5-1 for the diffs and that is with the lsd diffs all around
shocks:
front- 40wt with #1 pistions
rear- 30wt with #2 pistions
rebound front- 0
rebound rear-0
springs front-green
springs rear-green
spacer front-none
spacer rear- 6mm
shock mounting
front shock tower- middle lower
front on arm- most inner hole
rear- shock tower- middle hole
rear- on arm- middle hole
clutch setup- 13 tooth bell
CEN blue aluminum shoes
1.1mm springs
Wing postion- top hole
front hub carrier- upper hole
rear arm postion on hub- Top outer hole
Toe in block- rear- toe in 3.2 and antisquat 2.7 (which is stock)
My set up is real similiar to Jason Ashtons set up on CEN's website for a loose track. I just changed mine up a little bit.
Sponsors:
RCAmerica
Xray
Hudy
Max Power
Majestic Rc
Upgrade RC
RCID
Coopz Lidz(Amazing Work)
Werks Racing
Toys4BigBoys
Rcmtracer.com
losi8ight is offline   Reply With Quote
Old 05-14-2007, 06:10 AM   #490
Trader Rating: 26 (100%+)
Thank you
you can also use a dab of CA, thats a tip from Richard Saxton,
I'm running 80 wt, 20k, 5k with LSD diffs in my truck, 60wt f/ 40wt rear with #2 pistons in the shocks, blue springs, I'm pretty happy with how its working,
bobf24 is offline   Reply With Quote
Old 05-14-2007, 08:19 AM   #491
or you can wrap a tie strap around the bottom of the nut once you set it where you want it
Old 05-14-2007, 11:30 AM   #492
HEy guys
I have question.
I finish my build on my Truggy. I cant seem to get my clutch bell and my center diff to mesh properly. It is almost like i need to move the motor back about 3 or so mm to align in the center. I am using the stock bell and clutch mounted on a Werks B7 28.
Any suggestion will be appreciated.
FT_Wacked is offline   Reply With Quote
Old 05-14-2007, 11:54 AM   #493
Make sure that your engine mounts aren't backwards. I am just now getting to installing my engine in my build. On page 10, section 06-01 in the manual it states, "*Carefully look at each mount and you will see that the distance from the edge to the hole is different on each side. Make sure the edge with the shorter distance to the hole is closest to the rear (pull start side) of the engine."
Just a suggestion.
Dr Gonzo is offline   Reply With Quote
Old 05-14-2007, 01:11 PM   #494
Default Blue springs
Are the blue springs softer or tougher than the green springs.
Sponsors:
RCAmerica
Xray
Hudy
Max Power
Majestic Rc
Upgrade RC
RCID
Werks Racing
Toys4BigBoys
Rcmtracer.com
Old 05-14-2007, 01:27 PM   #495
Default Awesome
Awesome thank you very much bob
Sponsors:
RCAmerica
Xray
Hudy
Max Power
Majestic Rc
Upgrade RC
RCID
Werks Racing
Toys4BigBoys
Rcmtracer.com
cen matrix CHAVAN30 Nitro Off-Road 1177 08-05-2011 05:23 PM
CEN MATRIX FRE helivaguy Nitro Off-Road 4 08-27-2008 05:52 PM
Cen Matrix dieseldog20 R/C Items: Wanted to Buy 0 02-06-2008 05:31 PM
Matrix and Matrix TR Factory Race Edition Kits SmoothB R/C Items: For Sale/Trade 4 05-31-2007 05:36 PM
Dye matrix 5 and DYE matrix 4 w/ tanks and halos for sale yuk17bandit Other Items: For Sale/Trade or Wanted to Buy 0 11-07-2006 10:49 AM
