Like Tree1Likes
CEN Matrix TR
Old 05-04-2007, 05:09 PM
  #436
Is the rtr chassis the same as the FRE chassis? It shows the same part number in the replacement parts on the CEN site but on other sites it list a hard anodized for the FRE???
fuzz86 is offline
Old 05-04-2007, 06:16 PM
  #437
lockmouth's Avatar
Trader Rating: 33 (100%+)
It is the ame thing. I wish the FRE chassis was milled out to shave some weight.
lockmouth is offline
Old 05-04-2007, 06:28 PM
  #438
Trader Rating: 14 (100%+)
the rtr chassis is not hard anodized, the fre is.
lockmouth give me a shout.
jlo8864 is offline
Old 05-04-2007, 10:39 PM
  #439
the fre chassi is NOT the same as the rtr chassi
Robert.Hull is offline
Old 05-05-2007, 05:50 PM
  #440
ILDRVR's Avatar
In two days of track testing, I have now broke two front "A" Spindles. They have broke on the bottom where the screw enters. I have just ordered the red upgrade, but I was wondering if I might have something wrong that I am missing?
Other than that, I am starting to get used to the feel of the truck (a lot different than my old Mammoth ST)
ILDRVR is offline
Old 05-06-2007, 12:50 AM
  #441
you wont have any problems with the cnc upgrade the stock ones are just horrible you didnt do anything wrong no matter who runs them that happens
Old 05-06-2007, 05:52 AM
  #442
t4usee's Avatar
Has any of you guy's run a Sportwerks .26 on your TR? We just bought one to run at club level races. It seems a little dead on the top end and was thinking about going up a tooth on the clutch bell. It has just under a 1/2 gallon on break in and is very tight still. It may start to run better after it loosens up some. We have allways run .21's and have never run anything over that. I know they dont turn alot of rpm's like a .21 but I think it should be better on the top.
t4usee is offline
Old 05-06-2007, 06:49 AM
  #443
ILDRVR's Avatar
Thanks Robert, I thought you were all putting in the upgrade as a precaution not because it was neccessary.
ILDRVR is offline
Old 05-06-2007, 07:26 AM
  #444
i think lockmouth used to run a sportsworks 26, that thing made pretty good power and plenty of top end. maybe he can post if that was what he was running.
jlo
jlo8864 is offline
Old 05-06-2007, 12:25 PM
  #445
yea the cnc knuckles are a must along with the servo saver arm
Old 05-06-2007, 05:20 PM
  #446
ILDRVR's Avatar
Does Cen keep them out of the kit to save on cost or did they hold up during their testing?
This is my first pro kit and I thought items that needed to be upgraded for competitive racing would be included? My bad driving could also account for things breaking?
ILDRVR is offline
Old 05-06-2007, 07:00 PM
  #447
rregl0612's Avatar
Default Not to affend you Gene .. Your the man
For those running the LSD
I tried once again to follow Genes setup without the cross pins leaving the diffs with 80w, 7000, and grease..
but the truck is just to aggressive..
went back to the 22* hubs and loosened it up a bit..
so now running a modified setup witch would be .. all shocks setup as Genes most recent setup.. #2 pistons up front #1 in the back... full droop... and the long shock ends...on the rear.. short up front..
45wght up front 35 in the rear...
Ran a Blowed out rutty track that was dusty and hard pack.. Truck felt very neutral.. good turn in and very stable... probly could have ditched the front sway.. but IM lazy..
Im going to 5 in the center.. I suspect this to be my last major change as the truck feels good at this point. If this helps anybody,,
Still lovin this truck..
rregl0612 is offline
Old 05-06-2007, 08:12 PM
  #448
well the pro kit comes with everything needed except those and it could be cost or because of some other reson im really not to sure off the top of my head
and then again mabey those parts were fine during testing
Old 05-06-2007, 08:16 PM
  #449
ILDRVR's Avatar
Thanks, I didn't know if there really was a reason, but I thought I would ask. Since this is my first kit build, I really have nothing to compare it to.
ILDRVR is offline
Old 05-07-2007, 11:14 AM
  #450
Cost is the only reason. But I don't think most other pro kits come with CNC Knuckles either. I know Kyosho and Xray didn't.
Machine's R/C H is offline
