Old 04-24-2007, 04:08 PM   #346
heres more recent pics
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
yes this is Andy's truggy if you were wondering
[IMG][/IMG]
go really fast and turn left....
Robert.Hull is offline   Reply With Quote
Old 04-24-2007, 07:13 PM   #347
Default Cool
Is he running that new radical engine the .28 or .21 they are supposed to be CRAZY!!! What pipe is he running with it. Also are you running the cross pin coversion. Also what tires and rims were you running.
Sponsors:
RCAmerica
Xray
Hudy
Max Power
Majestic Rc
Upgrade RC
RCID
Coopz Lidz(Amazing Work)
Werks Racing
Toys4BigBoys
Rcmtracer.com
losi8ight is offline   Reply With Quote
Old 04-24-2007, 08:13 PM   #348
yea hes running the ops/radical 28 with the ops pipe
i run pro-line 1/2 inch off set wheels with what ever tires i need whitch are pro-line ofcourse
i run genes pins in buggy but not in truggy andy runs the pins in truggy though
Old 04-25-2007, 08:23 AM   #349
lockmouth's Avatar
Trader Rating: 33 (100%+)
Here is a picture of Smolik's truggy from the AIC 5.0
Man that thing was dialed in.
lockmouth is offline   Reply With Quote
Old 04-25-2007, 08:52 AM   #350
Thanks Rob so what Diff oil or grease do you run in the truggy with the lsd diffs.
Thanks again
Joshua
Sponsors:
RCAmerica
Xray
Hudy
Max Power
Majestic Rc
Upgrade RC
RCID
Werks Racing
Toys4BigBoys
Rcmtracer.com
Old 04-25-2007, 09:14 AM   #351
well i used to run grease-5K-grease and ran fine and just last weekend i changed it to 5K-10K-4K and just notice more hole shot and power out of the turn witch is what i wanted but it wasnt enough but i liked the grease because it last about 5-8 races longer than silicone so its kinda a hard decision and will take a few races to figure out what you want but to start of with i would go grease-5-grease and make sure you put a little more grease in front so it will pull you out of a turn rather than push you
if you have anymore questions i will be glad to answer/help you out
Old 04-25-2007, 09:27 PM   #352
Thanks Rob I am sure I will have a few other question when I start building it. It will be here friday or saturday for sure. I have one question for you now actually. Will the matrix 17 mm adpters fit on the truggy so I can run 17mm rims, or will that make the truggy sorta stubby becasue it will not have the offset it needs from the 1/2 offset 23mm rims. Or can I put some dace 17mm 9mm offset adpters on it.
Thanks again
Joshua
Sponsors:
RCAmerica
Xray
Hudy
Max Power
Majestic Rc
Upgrade RC
RCID
Werks Racing
Toys4BigBoys
Rcmtracer.com
Old 04-25-2007, 09:44 PM   #353
yea the 17mm will fit
Old 04-26-2007, 05:14 AM   #354
Trader Rating: 26 (100%+)
proline makes offset 17mm wheels now, so you will be able to get the same dimesnions as with 23mm, I think Gene has been running them lately actually,
bobf24 is offline   Reply With Quote
Old 04-26-2007, 08:16 AM   #355
Default Cool
Cool thanks guys. The way I am probley going to go is get the 9mm offset dace adapters and put them on because I looked at some other truggys to see what the width was and on the 8T the width is 415.9mm and the CEN is 415mm so if I put the dace 9mm offset adapters on it will be the same width of the 8T so I think I am going to go that route.
Also Rob in this post you posted above you ran this diff setup in the lsd diffs well i used to run grease-5K-grease and ran fine and just last weekend i changed it to 5K-10K-4K if so I will prbley go for my track like 5-7-3 then. Thanks
Joshua
(p.s. does anybody know how to change your username because now that I am driving for CEN my username needs to be changed.) Thanks
Sponsors:
RCAmerica
Xray
Hudy
Max Power
Majestic Rc
Upgrade RC
RCID
Werks Racing
Toys4BigBoys
Rcmtracer.com
Old 04-26-2007, 09:24 AM   #356
woulnd't putting 9mm offset hexes put you at 433mm for the width? 415 plus 9mm per side?
Old 04-26-2007, 09:28 AM   #357
what do you mean "for the track 5K-7K-3K"
all i do is RACE thats it i dont bash i just race and 5K-10K-4K is what i changed it to and ran it last weekend and it ran fine and again its all about the drivers feeling of the car and their preference so mabey 5-7-3 will work fine for you or mabey i missunderstood your post
give me some info on your track and ill try and give you a ball park setup
BTW if i miss understood your post let me know so i can give you the right info
as far as UN just go to edit profile and you should be able to go from there and change it
Old 04-26-2007, 09:32 AM   #358
yes it would i forgot to mention that in my post
cause the tr is 415 and the 8 is 415.9 its point 9 so its not that much wider i would just leave it and run 1/2 inch off set rims but it really matters all you have to do is run 1MM off set and your all ready gonna be wider
thanks bobf24 for pointing that out
Old 04-26-2007, 09:41 AM   #359
With non offset wheels the CEN is almost the same as the 8ight T.
With 1/2" offset wheels, the Matrix is much wider.
VP-Pro USA - www.raceVPpro.com
Agama USA - www.AgamaUSA.com
Maxy's Fuel - www.Maxysfuel.com
Machine's R/C H is offline   Reply With Quote
Old 04-26-2007, 01:19 PM   #360
Wow, I did a really ugly job cutting that body for Andy at Gas Champs.
Now that I see it in pictures, I really rushed that one... My bad guys...
Andy is running the OPS 2013 pipe. I can't remember off the top of my head if that's the exact model.
Gene HickerCEN, when you gonna show up out to California??? Thought I was gonna be able to meet you in person at Gas Champs. Gene, I'll try to call you later this week about getting another set of KMW shocks. Bent the one of the front shock bodies at a Demo Event. I should never have used my race buggy at the demo...
Glad to hear all the CEN guys had fun at Alabama.
Simon
s5lin is offline   Reply With Quote
cen matrix CHAVAN30 Nitro Off-Road 1177 08-05-2011 05:23 PM
CEN MATRIX FRE helivaguy Nitro Off-Road 4 08-27-2008 05:52 PM
Cen Matrix dieseldog20 R/C Items: Wanted to Buy 0 02-06-2008 05:31 PM
Matrix and Matrix TR Factory Race Edition Kits SmoothB R/C Items: For Sale/Trade 4 05-31-2007 05:36 PM
Dye matrix 5 and DYE matrix 4 w/ tanks and halos for sale yuk17bandit Other Items: For Sale/Trade or Wanted to Buy 0 11-07-2006 10:49 AM
