Old 04-09-2007, 07:58 AM   #271
Send a message via AIM to LugNutz Send a message via Yahoo to LugNutz
Has anyone adapted the 17mm buggy hubs on the Arena TR? If so, are they a direct replacement or is there anything else that needs to be purchased? Thanks..
LugNutz is offline   Reply With Quote
Old 04-09-2007, 08:19 AM   #272
lockmouth's Avatar
Trader Rating: 33 (100%+)
Originally Posted by Machine's R/C H
Part MX074 - $7.99 is all you need to do to stop the front upper tie rod from bending.
The mod of removing the front upper arm I have tried. It allows way more flex in the front susp (arm, caster block, upper arm, front shock shafts, ect), so it will completely change the handling of the truck (steering response, bumps, ect). It is not a bad thing, just different. It may be better on bumpy tracks.
Gene I'm going to give it a try if it is handleing different I'm going to cut the stock upper arm an put it behind the rod end and use the upper arm brace with the captured pin to brace it up again.
I just testing it out When the solid rod come out I'll get them. The truck is great right out of the box, I'm just really picky on something like
e-clips and soft turnbuckles I wreck alot so I need the added protection
Gene I hope to meet you at the AIC 5.0 on the 19th - 21st
lockmouth is offline   Reply With Quote
Old 04-09-2007, 03:16 PM   #273
rregl0612's Avatar
17mm hubs are a bit lighter...
I would imagine the Cen hubs from the matrix are a direct fit.. I got a set of Jammin buggy hubs on mine.. You will need to shim them to fit.. and drill out the drive pins.. hardware store had a 8mm washer and used some 8mm shims I had.. the front needs less shimming then the rear...
Only reason I went with Jammin is Ebay and 7.00 for all four..
I probly spent the rest on shims and a drill blank ....... oh well.
rregl0612 is offline   Reply With Quote
Old 04-09-2007, 06:39 PM   #274
yes the 17mm matrix will work just fine
go really fast and turn left....
Robert.Hull is offline   Reply With Quote
Old 04-10-2007, 07:16 AM   #275
I don't like hinge pins either. I use the CEN GS026 & GS027 threaded hins. Ther work everywhere except the rear outer hub pins. For there, I cut don the hinge pins and drilled 2 holes on the arms and use a short screw with a shock mount washer to hold them in - like the Xray uses.
Like this but I use a washer because the hinge pin can push past just a button head only:
VP-Pro USA - www.raceVPpro.com
Agama USA - www.AgamaUSA.com
Maxy's Fuel - www.Maxysfuel.com
Machine's R/C H is offline   Reply With Quote
Old 04-10-2007, 08:29 AM   #276
lockmouth's Avatar
Originally Posted by lockmouth
I got the hinge pin upgrades for the front upper and the front lower hinge pins, but that left me with the e-clips on the outer arms front and back.
I just hate e-clips so I decided to pull out the dremel and solve this problem. I shaved the hinge pin down first, then I made holes in each arm on the front and back side close to the hinge pin hole an used a button head screw to hold them in.
Here is a link to the upgraded capture pins for the front upper and lower.
Front upper
http://www.carolinasrc.com/Webstore/...idproduct=3402
Front lower
http://www.carolinasrc.com/Webstore/...idproduct=3401
Gene you must never notice my Hinge Pin Mod
I do the same thing you do put I do it in the front and the back. I added some flat head screws with red washers for a little extra bling I got the idea from when I use to have my XB8 TQ also.
Here is a recent picture.
Old 04-10-2007, 08:52 AM   #277
lockmouth's Avatar
Gene I have a question what is the weight of your truck race ready?? The truck is bigger than most truggies , but the weight doesn't hold it back. I' m trying to shed weight to make it light, part of the reason I used titanium turnbuckle for all my turnbuckle. I have a lipo pack with micro spektrum. Now I just need to see what wheel, foam, tire combo is the lightest. I think Panther Switch 2.0 with white Panther foams shaved down to molded shape with Proline 23mm 1/2 off-set wheel may be the lightest.
What do you think.
Check this out Gene some guy from truggyracers came up with this. It is a nice idea.
http://www.truggyracers.com/forum/in...howtopic=10465
Old 04-10-2007, 09:39 AM   #278
I tried that on the front outer pin, but broke a front arm once. I think the bolt/nut holds the arm together better and keeps it from spreading and breaking.
I am not sure what my truck weight is. When it was box stock it weighed about 10 pounds 3 ounces. But I think it is closer to 9 pounds 9 ounces now with a bunch of light weight screws and stuff. I am using a lipo now also.
Old 04-10-2007, 07:42 PM   #279
rregl0612's Avatar
Question for you cen guys.. I just gave my local shop some part numbers but he cant find them on Horizon..
Is HRP a better distributor for Cen or does he need to be direct???
Thanks in advance
Old 04-10-2007, 08:12 PM   #280
odoylrulz's Avatar
I've ordered cen parts from my lhs through horizon and found them without a problem. What parts were you looking for anyway? Check if they have it on the website, if it's on the website your lhs has to be able to order it. If they don't have the part you need on the website they probably dont carry it. you could always order from Machine hobbies or Amain or carolinasrc
odoylrulz is offline   Reply With Quote
Old 04-11-2007, 05:14 AM   #281
Trader Rating: 26 (100%+)
they can give the part number to their Horizon Sales rep, and have them special order it, and then after that first time it will always be in the system, but if you need it right away it will take a few weeks for horizon to get the parts,
they can also set up direct with CEN, and have the parts fast, I've never ordered a part direct that CEN didn't have in stock,
for some reason Horizon does't have most of the truggy specific parts listed yet,
bobf24 is offline   Reply With Quote
Old 04-11-2007, 09:47 AM   #282
headrushhobbies.com = CEN parts
Old 04-11-2007, 09:58 AM   #283
headrushhobbies.com = probally not his LHS
Old 04-11-2007, 10:40 AM   #284
Atom357's Avatar
Trader Rating: 17 (100%+)
Call Gene @ Machines RC Problem solved.
Atom357 is offline   Reply With Quote
Old 04-11-2007, 03:16 PM   #285
headrushhobbies = online parts = shipping= DUH
cen matrix CHAVAN30 Nitro Off-Road 1177 08-05-2011 05:23 PM
CEN MATRIX FRE helivaguy Nitro Off-Road 4 08-27-2008 05:52 PM
Cen Matrix dieseldog20 R/C Items: Wanted to Buy 0 02-06-2008 05:31 PM
Matrix and Matrix TR Factory Race Edition Kits SmoothB R/C Items: For Sale/Trade 4 05-31-2007 05:36 PM
Dye matrix 5 and DYE matrix 4 w/ tanks and halos for sale yuk17bandit Other Items: For Sale/Trade or Wanted to Buy 0 11-07-2006 10:49 AM
