Old 04-03-2007, 09:12 AM   #241
Trader Rating: 26 (100%+)
Originally Posted by Machine's R/C H
The RTR TR Arena imo is the best RTR you can get. But to be race worthy, he will need to get the CNC susp holders. Everything else is good or the same as on the FRE.
if he is on a budget, to start I would just run the plastic holders, and when they wear out or break, replace them with aluminum, the plastic will work fine for a while thgouh,
bobf24 is offline   Reply With Quote
Old 04-03-2007, 09:42 AM   #242
VP-Pro USA - www.raceVPpro.com
Agama USA - www.AgamaUSA.com
Maxy's Fuel - www.Maxysfuel.com
Machine's R/C H is offline   Reply With Quote
Old 04-03-2007, 10:40 AM   #243
talking about the plates that hold the hinge pins in correct?
mugenlife is offline   Reply With Quote
Old 04-03-2007, 10:47 AM   #244
Yes
Old 04-03-2007, 11:34 AM   #245
if he later wanted to switch the engine a trinity drake 28 or a werks 28 would drop right in right?
Old 04-03-2007, 11:44 AM   #246
Yes. Any engine will fit.
Old 04-03-2007, 11:47 AM   #247
meaN1's Avatar
Trader Rating: 15 (100%+)
Talking good frikin info
i am new to this forum and i must say that this by far the most informative, in depth discussion i have read about the CEN TR, i am going to be placing my order for one tonite and am glad to see and read all of the info you all have posted. thanks and look forward to reading more...
meaN1 is offline   Reply With Quote
Old 04-03-2007, 01:14 PM   #248
http://www.cenracing.com/race/pic/genesetup07.pdf
This is my current set-up
Old 04-03-2007, 02:26 PM   #249
i doubt if he changes the diffs soon but to start with does the rtr have good fluid in them or should he get some of that kyosho red or black diff fluid?
Old 04-03-2007, 03:39 PM   #250
What is the advantage of running 17mm hex`s for the wheels? also can you post a pic or send it to me of the work done to the rear brace?
fuzz86 is offline   Reply With Quote
Old 04-03-2007, 05:05 PM   #251
The diffs come with grease which will work fine to start with. Then get my cross pin converstion kit.
I am using 17mm hubs to narrow the truck up some. The proto truck had shorter arms but I used extended 23mm hubs. Also, the 17mm hubs are half the weight of the 23mm's. And Pro-line finally released offset 17mm wheels and I like them.
http://h1072672.hobbyshopnow.com/pro...prod=PRO269202
Old 04-03-2007, 05:08 PM   #252
Also, when we were testing the tuck, 17mm wheels would easily strip out. But now I am using the KMW Racing flandge nuts which stop that and really hold the wheel well.
Old 04-03-2007, 09:21 PM   #253
if you havent placed an order yet.....
http://www.headrushhobbies.com/estor...?pid=856&catn=
go really fast and turn left....
Robert.Hull is offline   Reply With Quote
Old 04-04-2007, 10:48 AM   #254
Or here:
Matrix TR RTR with Free Cross pin Converstion kit.
Old 04-04-2007, 06:39 PM   #255
Trader Rating: 14 (100%+)
to anyone wishing to purchase an arena tr, i wish you would give gene a shot. he provides great info and support, i think that is more valuable than the little amount of money you MAY save.
jlo
jlo8864 is offline   Reply With Quote
cen matrix CHAVAN30 Nitro Off-Road 1177 08-05-2011 05:23 PM
CEN MATRIX FRE helivaguy Nitro Off-Road 4 08-27-2008 05:52 PM
Cen Matrix dieseldog20 R/C Items: Wanted to Buy 0 02-06-2008 05:31 PM
Matrix and Matrix TR Factory Race Edition Kits SmoothB R/C Items: For Sale/Trade 4 05-31-2007 05:36 PM
Dye matrix 5 and DYE matrix 4 w/ tanks and halos for sale yuk17bandit Other Items: For Sale/Trade or Wanted to Buy 0 11-07-2006 10:49 AM
