Old 01-25-2009, 12:38 PM   #1771
Brushlessboy16's Avatar
Trader Rating: 18 (100%+)
Send a message via AIM to Brushlessboy16 Send a message via Yahoo to Brushlessboy16
Does anyone happen to have a spare wing mount set for the matrix that they dont need? Please Pm me.
on another note... I just found a brand new Rcbodies.net Matrix body!
Ben White aka The Flyin' Flashlight
Rc-monster Team Driver
JQ The Car, Neu 1515 1.5D, Mamba Monster, Rc-monster slipperential, Futaba Bls351
Unconventional Techniques, Superior Results.
Brushlessboy16 is offline   Reply With Quote
Old 01-30-2009, 06:59 AM   #1772
Dentman's Avatar
I searched this thread but want to be sure. I'm trying to get my TR arena to take same rims and tires as my Hyper st pro. I bought the matrix c-1 17mm hexes and pins from cen. I guess all I need is some shims???
Which rims will these hexes take, Starndard Offset or 1/2 inch Offset??
I want to run proline tires and wheels.
JAMMIN SCRT TEKIN RX8 TEKIN SCX 4.5 on Thunder Power 50c 5200mah
RC8T FT CE TEKIN RX8 and 2250 with 4s Thunder Power 65c 5300mah
Dentman is offline   Reply With Quote
Old 01-30-2009, 07:14 AM   #1773
the hexes take any 17mm mt rim... no matter what the offset.
your going to need quite a bit of shims..
Old 01-30-2009, 09:01 AM   #1774
Tree's Avatar
Send a message via ICQ to Tree
Buy the Cen Matrix rear axles and you won't need shims for the rear. I may have a set somewhere around my garage that I can sell you. PM me if your interested.
For the front, go to your local hardware store and buy a small package of 8mm washers. You will need 1 washer for each universal. You may need to add a .1 shim to remove any backlash/play from the hexes. Using the washers is a lot better that using a bunch of shims IMO.
Team Holy Rollers
HiTec Servos
"N-Tune" Nitro Engine Tuning Dials
Tree is offline   Reply With Quote
Old 03-17-2009, 04:23 PM   #1775
Can someone tell me where to find the cvd rebuild kits for the cen Cvd's?
Old 04-02-2009, 05:14 PM   #1776
Default COMPLETING TR RACE ROLLER
Tree, not sure if you mind I jump in. I have the Arena RTR (selling to friend) to help finance completing my Matrix TR race roller. I have 17mm Thunder Tiger hubs, front cnc spindles, cnc rear hubs, cnc bellcrank & Gene's upper turnbuckles (f&r), Mugen shock springs, Avid single brake conversion & Badland tires on Max beadlocks & Hpi pins on Ofna dish (both black). I also ordered Jammin jpx.28 turbo race engine. I'm thinking of getting Vantage Racing carbon (top-end) pipe (VR1ST120L-05). Anyone use this pipe before ?
I also heard can use matrix buggy rear axles on TR to get rid of hub shims, but aren't the buggy axles a lot shorter ? If they work, I think Cen has blue cnc buggy axles to match Cen's lightweight blue cnc driveshafts ? I also hear some drivers are using Kyosho strr truggy axles up front to get rid of the front shims, but not sure if this is with the older front arms, or the new shorter front arms ? I hear the new CEN buggy just coming out has CVD. Maybe worth waiting, but how long before new TR comes out, & if they will even work ? Do you know if CEN's new cnc TR driveshafts fit both the Arena RTR & TR race roller ? Reason I'm asking is I think I heard the 7075 FRE chassis will not work on RTR ?
RCROD is offline   Reply With Quote
Old 04-09-2009, 06:49 AM   #1777
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
Well guys, just came from the 5th stage of the national championship in my country (6 stages on first semester, 6 stages on second one) ... my bad luck its still with me, but the performance of my cars its awesome right now.
Truggy. A lot of time without racing truggy class and the car performed excellent, fast and precise, i ended making the TQ so was very optimistic about A-Main (40 minutes). Just prior to the start of a-main i discovered that my engine was flaming out badly and thats very strange due to the fact my engine performed flawlesly just couple hours before !. I started leading the A-Main but just after the start i ended flaming out again, 2 more and i decided to stop the car not going back to the track. After inspection, one of the clutch spings went out from the nut that holds it so it blocked my transmission, DAMN !!!, i think its my fault as i usually use CEN nuts or OFNA ones and during inspection i discovered i installed an old mugen style nut, wich its very "plane" on the "waist" part of it, so the spring came off easily ... that was it for me ...
Buggy. During qualifying, my first round was awesome, VP PRO 803 Strikers tyres were awesome hooked to the trood desition on differential and suspension setup. I ended 2nd just 8 seconds behind the leader. On second round and after half qualy and behing oin the back straight, one of my shocks came off, the upper nut went out and the shock came off, i decided to call it and ended. Third round was leading out and i started to feel that on breaking my car wanted to spin out ... call it to the pit area and was the lower knuckle screw that came off ... damn !!!.
So, i ended qualifying on C-Main on Buggy, i started the C-Main (20 minutes) and the car was awesome and i make it to win that race, so bumped to B-Main (20 more minutes) ... this time the racing was more fierce but the car was very good so i managed to end second just 3-4 seconds behind the leader, didnt wanted to fight for the lead, just make the job to go up to A-Main. Now all goes down ... charged the batteries during the midtime, prepared all with my pitman and just when he switched the car ON, my receiver BURNED OFF !! (s3100 DX3R spektrum one) ... so, while i was hearing how the a-main started, i was waiting for my pitman to do something (if i go down the driver stand, i got disqualified), he grabbed my truggy receiver and installed on the buggy while i was trying to program it for the buggy lol !! ... ended entering to the race 8 laps behind the last position and fought hardly ... when i was 2 laps behind the last position i felt i was making stupid mistakes for the rush to go up in positions, and was not worthy so i called out ... that was for me, winner made 50 laps, i made 35 ...
Very happy with my equipment, tyres, car and engine performed flawlesly, just need little help of god on next races ... thanks a lot to CEN, GO Engines, VP PRO, AVID RC, Ultimate Racing, Carolinas RC and Upgrade RC for the inconditional support down here at the end of the world (Chile - Southamerica).
cya !
[img]http://i221.photobucket.com/albums/dd225/patoconcha/RC2009/20090405_CACH_OFFROAD/yo/IMG_6174.jpg" border="0" alt="Photobucket"></a><br /><br />
</center>
cya !
Patricio "PATO" Concha
E-Mail : pato_concha@yahoo.com
Facebook : http://www.facebook.com/patoconcha
Whatsapp : +56 9 66165085
Tabushi is offline   Reply With Quote
Old 07-27-2009, 11:03 PM   #1778
wriffwraff's Avatar
Default Latest Pic of My Cen Matrix TR Arena
wriffwraff is offline   Reply With Quote
Old 10-26-2009, 12:08 PM   #1779
wriffwraff's Avatar
Default Latest Vid of My TR Arena
I bought a HD camcorder... vids should look better now.
+ YouTube Video
Old 11-30-2009, 02:36 AM   #1780
yuppi1's Avatar
hi guys just found this thread
i have just purchased a cen matrix C1 and just wondering if it is race a race worthy car?
cheers
yuppi1 is offline   Reply With Quote
Old 12-02-2009, 08:13 AM   #1781
Tree's Avatar
Originally Posted by wriffwraff View Post
Hey Wriff, What body is that?
Team Holy Rollers
HiTec Servos
Old 12-02-2009, 08:16 AM   #1782
Tree's Avatar
cheers
The C1 is heavier then the current buggies that are out now. The Matrix is a capable racer and with the weight of the C1, it makes the buggy feel a bit more stable especially if you're just starting out in racing. Good luck with your rig.
Team Holy Rollers
HiTec Servos
Old 12-02-2009, 09:52 AM   #1783
wriffwraff's Avatar
Default bodyrock
how goes it tree? you asked about the body. it's the jconcepts body for the 6T.
+ YouTube Video
here's my latest vid. i'm running the reckward tuning "symbio" body here.
Old 12-02-2009, 09:39 PM   #1784
Tree's Avatar
Wriff, did you have to do any extra trimming to get the body to fit?
Team Holy Rollers
HiTec Servos
Old 12-02-2009, 10:42 PM   #1785
wriffwraff's Avatar
the 6T body is narrow, so if you're running the CEN chassis side guards, and running your body lowered, you'll have to stretch the sides of the body over the guards a little to seat it. also, the front shock tower rubs and takes paint off, so i used my body reamer and dremel to cut nostrils above or around the front shock tower
here's a link to a few pics http://www.truggyracers.com/forum/in...c=10135&st=380
cen matrix CHAVAN30 Nitro Off-Road 1177 08-05-2011 05:23 PM
CEN MATRIX FRE helivaguy Nitro Off-Road 4 08-27-2008 05:52 PM
Cen Matrix dieseldog20 R/C Items: Wanted to Buy 0 02-06-2008 05:31 PM
Matrix and Matrix TR Factory Race Edition Kits SmoothB R/C Items: For Sale/Trade 4 05-31-2007 05:36 PM
Dye matrix 5 and DYE matrix 4 w/ tanks and halos for sale yuk17bandit Other Items: For Sale/Trade or Wanted to Buy 0 11-07-2006 10:49 AM
