CEN Matrix TR
#1681
Does any one have a measurement from hinge pin to hinge pin on the new shorter rear arms?
I just installed a set of rear arms I picked up from CENDirect, and my rear drive shafts are barely sitting inside the diff out drives.If my arms moves upward even 1/2 an inch the bone pops out.
This is also with very severe negative camber, just to get the bone inside.
Doesnt make much sense because even if this is the old style rear arm, the bone should still be deep enough in the outdrive to stay in there at ride height.
The bones i picked up from ebay but were from a parted out RTR truck. I am using the buggy rear axles but they dont change the position of the bone. The diff is stock plastic diff with cross pins and CEN outdrives.
Any suggestions?
Any suggestions?
#1684
Race Report : August 23th and 24th - 2008
Event : 8th Stage of the 2008 Chilean Offroad National Championship
Classes : 1/8th IFMAR Buggy and 1/8th Truggy
Track : XRC Racing Hobby - Chile
Practice Session : During the practices i managed to setup my buggy and truggy very good giving me a good amount of confidence over the race. This is my first race in my country after a couple of years and the hobby has evolved in a good way, so the competition its very fierce with a lot of fast drivers. The track its very technical with just a few spots to do passing moves.
Qualifying and Semifinals : I ended on the slowest group of the event in buggy and truggy, due to the fact that the qualy groups are pre-assigned based on your last stage result, and this was my first event in Chile this year so i ended on the last/slowest group. Being such a technical track with no wide sections, this became a problem due to the slow traffic so i did my best to qualify the best i could. In Buggy, ended the qualification process in 6th position overall, thats mean 3rd place on the B-Semifinal (IFMAR Tree system, same as used in worlds). And in Truggy on 4th place overall. In Buggy, during the semifinals i had some mechanical problems and when i was in 3rd position (only the first 5 go to the finals) i had to call the day, very sad. In truggy i managed to go to finals, starting in 2nd position.
Finals : Truggy class its something new for me, and i was amazed about how good the CEN Truggy goes. My GO .25 engine + EFRA 2047 GO Pipe gave me confidence to race hard on this one, 30 minutes finals. I did a very good start securing 2nd position from the beggining, but after couple mistakes i was in 4th-5th position by mid race. After my 3rd pit pass, i started to climb positions and got secured again in 2nd position. So, great end in 2nd position and very happy with the track and engine combo, only bad part was tyre selection, i think other choice would be better suited for the track, i used Bowties on qualies and wanted to test Losi's ones that went very good on practice, but ended giving me a loose rear end during finals.
Here you have couple pics, and a video that a friend did of my truck (pink one).
Video : http://revver.com/video/1134837/8th-...-championship/
Equipment used in Buggy : GO .21 5 ports 6.5mm restrictor - GO 2047 Pipe - VP PRO 803 Tyres - OS P3 Plug - Power Save Racing Air Filters - VP PRO Wing - VP PRO 3 Shoe Clutch System - Maxy's Fuel 30%
Equipment used in Truggy : GO .25 6 ports 7mm restrictor - GO 2047 Pipe - Proline Bowties on qualies, Losi XTT's on finals - Novarossi C4 plug - VP PRO Airfilters - M2C Racing 4 shoe clutch system - Maxy's Fuel 30%
cya guys !!, hope to do it better next time !!!
#1685
Well that just doesn't make sense. Are you sure that the carriers are not flipped around? The CVDs are the right ones? I don't get it..maybe some pics?
I don't have anything wrong with the rear CVDs. Are the outdrives you run the right ones? Maybe they're really worn/shaved to look new?
#1686
Well, much to my own disapointment I have found the cause of my rear drive problem.
I am actually converting an extra buggy kit I had sitting around and was using what ever parts I could from that. I built the buggy diffs and used the buggy outdrives.
I have just realized that the TR uses a longer outdrive. Damn, now I need to go order more parts and start the diffs all over again.
Thanks for the help guys.
#1687
Great job at the race Pato! Kind of a slow pit man though. Nice nonetheless!
#1688
"Well there's your problem!" LOL. It's always risky trying to build a truggy with buggy parts not meant for a truggy.
#1689
#1690
Instead of ordering the proper CEN outdrives I have decided to use parts I had on hand.
I didnt want to turn the truck into a Kyosho, but I made this work.
Kyosho Rear uprights/carriers and ST-R universals, this setup puts the drive bone deep into the Matrix buggy outdrive and requires no other mods, except to drill out the universal axle to accept the CEN pin. The Kyosho 17mm hubs will work perfect no mods.
I used the ST-R universal because thats what I had, but the ST-RR light weight ones would be ideal. Both are the same length.
#1693
What center drives are those and can you give me the part numbers for the front and rear? Thanks, Mario.
#1694
PS. Have you seen the picture of the new buggy??
http://www.neobuggy.net/modules/xcga....php?album=136
KYOIFW308
KYOISW052
#1695
http://www.amainhobbies.com/product_...oducts_id/3989
The center/rear is for the Kyosho St-RR
http://www.amainhobbies.com/product_...ducts_id/14808
I think the problem with the Kyosho ST-RR universal binding with the BCE chassis conversion is due to the fact the the Hot Bodies beveled pinion gear is too long. I am using Kyosho ST-RR diffs and I haven's had a problem with binding or bending. I haven't really push the truggy that hard with the BCE conversion yet but I will definatley let you know if I do have a problem.
