Old 08-04-2008, 07:45 PM   #1651
Trader Rating: 49 (100%+)
i will have a BCE roller on here for sale in the next couple of days with just about all the mods justin's BCE that is pictured in the post above has. the chassis is brand new, no run time, the rest of the truck has one race on it. its my pride and joy, but lack of time to race and this school semester coming up, i need the MONEY.. just a heads up
cleblanc is offline   Reply With Quote
Old 08-04-2008, 08:20 PM   #1652
Tree's Avatar
Send a message via ICQ to Tree
PM sent
Team Holy Rollers
HiTec Servos
"N-Tune" Nitro Engine Tuning Dials
Tree is offline   Reply With Quote
Old 08-04-2008, 08:57 PM   #1653
pm replied to
Old 08-04-2008, 10:29 PM   #1654
SIXPAC's Avatar
couple updated photos with new servos and jammin super big bores. Im going to do buggy braces and servo plate next. u can see in the photo the cut down rear brace (that helps with traction)
Mcran,
what set up in the super big bores?
thx
CEN Matrix TR-0804082000a.jpg   CEN Matrix TR-0804082001a.jpg   CEN Matrix TR-0804082001b.jpg   CEN Matrix TR-0804082002a.jpg
-CEN MATRIX FACTORY SC EXTECH RP.21 JP4-
SIXPAC is offline   Reply With Quote
Old 08-05-2008, 08:46 AM   #1655
Tree's Avatar
Looks good SixPac. What lid are you using?
Team Holy Rollers
HiTec Servos
Old 08-05-2008, 10:25 AM   #1656
SIXPAC's Avatar
Thanks!
I ran a MBX5T stock body and it covers the mud gaurds well, the cab part is too tall and hard to temp. The stock cen body is alittle short for the gaurds. I want a MSR CP 2.0, but no luck... So i think im going with a Mugen proline CP. You know of any better?
Old 08-05-2008, 11:49 AM   #1657
Default Need Help
I have a Matrix TR FRE and I'm not sure what the set screws that are in the lower a-arms are for. Could you let me know how to set them. Thanks for any input on this.
Matrix TR FRE
Hot Mods Novarossi Plus .28 5T w/9886 pipe
DX3R
Stimey131 is offline   Reply With Quote
Old 08-05-2008, 12:56 PM   #1658
TRArena's Avatar
they help protect your shocks from taking the full impact when the arms reach full droop. Firstly, set them so they are flush with underneath the arms then sit the car on a work stand (or an old wheel will do) so that the arms reach full downward extension (spin the wheels to make sure you've got it sitting high enough). Then wind the set screws so they raise the arms a mm or two. Now when the arms reach full downward extension the set screws will touch the 'ears' on the chassis first before the shocks slap to full extension.
TRArena is offline   Reply With Quote
Old 08-05-2008, 07:45 PM   #1659
chrobar's Avatar
That's what they're for. In other words, to adjust droop. I made the mistake of taking the screws out, and I almost killed my rear shocks. Luckily the little plastic parts that go inside the shock cap to mount on the tower broke first.
CEN Factory Team
Matrix C-1 FRE custom brushless, 2000kV, Orion VDS-2015
GST-E, 1500 kV, Hitec 5955TG
Futaba FASST 3PM
chrobar is offline   Reply With Quote
Old 08-06-2008, 09:11 AM   #1660
Mcran's Avatar
SIXPAC – I talked with Justin and he said to the best of his knowledge he used Losi 60 Front Blue Springs & Losi 45 Rear Grey Springs with the stock pistons F/R.
Team Associated, LRP, Reedy, Hobbico - www.hobbico.com,
JConcepts - www.JConcepts.net, Futaba - www.futaba-rc.com,
OS Engines - www.osengines.com, Kal-Gard - www.Kalgard.com,
Murnan Modified Motors - www.Murnanmodified.com
Mcran is offline   Reply With Quote
Old 08-06-2008, 09:32 AM   #1661
SIXPAC's Avatar
I pulled this off the OFNA forums...
The grays front and rear. Pistons are drilled out. Front uses 3 holes at 1.2mm and 3 holes at 1.3mm. Rear uses 3 holes at 1.2mm, and 3 holes at 1.35mm. 37.5 wt in both front and rear...
I used 40 weight front and rear, might use 50 in the front... might be running thursday @ rev. ill let you know how it works....
ackerman. im running middle hole and noticed you guys are running inside hole motor side. Does that work better? Is that reverse ackerman?
thx
Old 08-06-2008, 02:12 PM   #1662
Thanks for the input on the a-arm set screws and I have one more question. I set it up as you described, but I noticed that not all the set screws touch at the same point. Am I only concedrned with it taking some persure off the shocks/arm at full extension or do the arms need to be at identicle downward angles when the set screws set. Thanks for your help.
Matrix TR FRE
DX3R
Old 08-06-2008, 04:27 PM   #1663
chrobar's Avatar
I set mine to be equal. I may have taken some droop out of the shocks, but they're even and the shocks don't take the shock, hehe.
CEN Factory Team
Futaba FASST 3PM
Old 08-07-2008, 12:49 AM   #1664
TRArena's Avatar
yeah you want the arms to be kinda even... if they are not resting about the same position at full droop check the length of the shocks from top of the upper shock cap to the bottom of the shock end to make sure they are the same... if you are using the stock shocks have the front around 114mm and the rear around 138mm. If that doesn't fix it then check the turnbuckle lengths too.. i think the standard inside measurment on the stock ones is about 55mm front and 65mm rear.
Old 08-07-2008, 11:40 AM   #1665
I wanted to know if you use a little of toe-out on the front tires. Thanks for all the help.
Matrix TR FRE
DX3R
cen matrix CHAVAN30 Nitro Off-Road 1177 08-05-2011 05:23 PM
CEN MATRIX FRE helivaguy Nitro Off-Road 4 08-27-2008 05:52 PM
Cen Matrix dieseldog20 R/C Items: Wanted to Buy 0 02-06-2008 05:31 PM
Matrix and Matrix TR Factory Race Edition Kits SmoothB R/C Items: For Sale/Trade 4 05-31-2007 05:36 PM
Dye matrix 5 and DYE matrix 4 w/ tanks and halos for sale yuk17bandit Other Items: For Sale/Trade or Wanted to Buy 0 11-07-2006 10:49 AM
