Old 07-21-2008, 07:38 AM   #1621
Trader Rating: 19 (100%+)
So I was checking my clutc out after my 1st race day with my new mill and noticed I snapped 1 of my King Heads Mugen hard shoes!!! I just got a new set of Cen springs and want to try the Cen shoes but no place I deal with has the blue ones in stock. Will the red ones be okay, I know they wont last as long and I am going to try 2 alum and 1 composite. Which wasrecommended to my by the guy who modded my mill. That way I will get 2 clutches because they come in a 4 pack.
TT MT4G3 all tricked
TTST4G3 MT4ed out
JR servos Hitec servos. Gens ace lipos KO radio.
malik is offline   Reply With Quote
Old 07-22-2008, 12:29 AM   #1622
TRArena's Avatar
hey malik, 2 ali and 1 carbon will do two things - less 'grab' and less wear on the bell. it works better on loose / soft tracks rather than high bite / smooth tracks. Your modded mill has prob got a fair amount more torque than your previous motor hence the recommendation from your guy. I would strongly recommend the blue shoes tho as IMHO the red ones are just too soft and i go thru them like butter. You can get them from here if you're stuck -
http://www.headrushhobbies.com/estor...pgrade%20Parts
or from cen direct
TRArena is offline   Reply With Quote
Old 07-26-2008, 09:01 PM   #1623
Mcran's Avatar
Some Pic's of Justin's BCE TR:
Team Associated, LRP, Reedy, Hobbico - www.hobbico.com,
JConcepts - www.JConcepts.net, Futaba - www.futaba-rc.com,
OS Engines - www.osengines.com, Kal-Gard - www.Kalgard.com,
Murnan Modified Motors - www.Murnanmodified.com
Mcran is offline   Reply With Quote
Old 07-26-2008, 10:24 PM   #1624
TRArena's Avatar
thnx for posting these...
1. what threaded hinge pins have you used on the front and rear arms (hub/hub carrier) - they seem a better fit than the k-factory ones i have used?
2. are the diff cases kyosho or new cen ones?
3. is the plastic servo saver the earlier ofna one?
4. any reason you not using the new ali dog bones (i know the front one takes a bit of modding to make it fit unless the buggy ones have been released?)
5. What rear hubs are you using?
Cheers.
Old 07-27-2008, 09:51 AM   #1625
Trader Rating: 21 (100%+)
Cheers.
I have the aluminum dog bones in my TR and ther was no modding necessary. Drop them right in.
Colin
Time Zone Raceways www.Timezonehobbies.com
www.ColinBranch.com
C Branch is offline   Reply With Quote
Old 07-27-2008, 01:55 PM   #1626
TRArena's Avatar
Colin
hey colin, they don't fit the BCE Arena unless you shave the shaft of the pinion. I have done it on a few of them now. Apparently the buggy one (MXS50) fits fine but I haven't been able to get any from CEN yet.
Old 07-27-2008, 08:58 PM   #1627
Oh sorry, I didn't realize we were talking about a BCE conversion
Colin
www.ColinBranch.com
Old 07-28-2008, 02:19 AM   #1628
TRArena's Avatar
some pics of my new mill, pipe and lid (paint by Mike Czech) ...
CEN Matrix TR-c2xpro-matrix1a.jpg   CEN Matrix TR-c2xpro-matrix5a.jpg   CEN Matrix TR-c2xpro-matrix6a.jpg   CEN Matrix TR-c2xpro-matrix7a.jpg   CEN Matrix TR-c2xpro-matrix8a.jpg
Old 07-28-2008, 11:42 PM   #1629
SIXPAC's Avatar
Sweet trucks.
My truck is bad ass with the new motor. REV changed the track to small jumps that take the right line to clear. im working on hook up and shocks now. Do you use the jammin shock bolts and studs on the super BB setup?
anybody have problems with the upper arms? i pulled the threaded plastic part off the a frame. so Genes turnbuckles wont fix that... any longer style uppers with the right spindle line? mugen? jammin. We need to take leverage off that upper...
i cut my chassis brace and seems to work good. Hot set up on buggy brace? do not mill the chassis for flex? losi stye? cen buggy? ideas?
Got 2 5955 servos coming and going to try holeshots for better hook up.
body you guys are running? any lines on the MSR CP 2.0
still trying for action photos, my buddys are flakes!
THX
-CEN MATRIX FACTORY SC EXTECH RP.21 JP4-
SIXPAC is offline   Reply With Quote
Old 07-29-2008, 10:37 AM   #1630
Mcran's Avatar
For the front I used 3mmX35mm hex head screw and cut to length. For the back I used Mugen and cut about 3mm off the front and rear of the arms with a razor so I could get the nut all the way on.
The rear hubs are Kyosho. I used the front dog-bones for the TR and used a punch to get the pin out of the CVD. Then I put the rear bones on and put the pin back through. Have to be patience doing this but it works very good.
The center diff is Jammin with the Kyohso 48 spur gear. We use the stock diffs with pins in the front and rear. Jammin is lighter and since it only opens from one end there is less chance of the diff leaking oil on the brakes.
Ill be glade when Cen gets the new diffs and lighter drive train out for the buggy and TR. The current F/R CVDs are durable but very heavy.
We got one blue dog-bone for the buggy and one for the rear of the TR for testing from Cen. That was a long time ago and both are worn-out now. We just received new ones for the TR yesterday. They are very durable, light, and last a long time. They are selling faster than Cen can get them in stock.
Old 07-29-2008, 02:37 PM   #1631
TRArena's Avatar
Thanks for the reply....
Nice mod for the rear cvd. I used to use the Kyosho STRR rear but had to grind down the rear pinion to fit the BCE Arena... never thought of doing it your way
As far as the new blue driveshafts are concerned, are you using the buggy one (MXS50) on the front or have CEN made a new front one to fit the BCE TR?
Old 07-29-2008, 03:53 PM   #1632
TripleX-JT's Avatar
Send a message via MSN to TripleX-JT
I am going to be using the Hot Bodies ring and pinion for the BCE conversion. My question is can I use the Cen diff cup or do I need to use a Hot Bodies cup. I tried both the Cen plastic and aluminum but the holes dont seem to line up. I dont know if I am missing something or not. If anyone could shed some light on the subject that would be great.
Josh Thompson
CEN Racing - GO Tech Engines - UPgrade RC - Northern Hobbies - Khaos Designs
TripleX-JT is offline   Reply With Quote
Old 07-29-2008, 04:01 PM   #1633
They will fit directly on the CEN cups. Thats how I have been running mine.
Colin
www.ColinBranch.com
Old 07-29-2008, 04:04 PM   #1634
TripleX-JT's Avatar
That is what I thought to but it seems like the screws are going to go in at an angle. I guess if I put the screws in and never unscrew until the cup needs to be replaced it should be fine.
Josh Thompson
Old 07-29-2008, 04:23 PM   #1635
Mine lined up perfectly.
www.ColinBranch.com
cen matrix CHAVAN30 Nitro Off-Road 1177 08-05-2011 05:23 PM
CEN MATRIX FRE helivaguy Nitro Off-Road 4 08-27-2008 05:52 PM
Cen Matrix dieseldog20 R/C Items: Wanted to Buy 0 02-06-2008 05:31 PM
Matrix and Matrix TR Factory Race Edition Kits SmoothB R/C Items: For Sale/Trade 4 05-31-2007 05:36 PM
Dye matrix 5 and DYE matrix 4 w/ tanks and halos for sale yuk17bandit Other Items: For Sale/Trade or Wanted to Buy 0 11-07-2006 10:49 AM
