Old 07-12-2008, 08:14 PM   #1606
Trader Rating: 19 (100%+)
The arms that are on there I bought from Gene like 2 months ago. I will call him monday and ask him wether he's been selling long or the short arms. I figured from him they would be, I buy all my TR parts from him.
malik is offline   Reply With Quote
Old 07-12-2008, 10:08 PM   #1607
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
Order new arms, and in the meanwhile just drill new pin holes for the front-left hub like 5mm inn and you are set ... i did that until i got the new arms,
cya,
Patricio "PATO" Concha
E-Mail : pato_concha@yahoo.com
Facebook : http://www.facebook.com/patoconcha
Whatsapp : +56 9 66165085
Tabushi is offline   Reply With Quote
Old 07-13-2008, 07:16 AM   #1608
Actually I am going to 17mm hubs as soon as the wheels and tires get here. What does that do for the axles.
Old 07-14-2008, 10:29 AM   #1609
The short arms are the same part #, so there is no way to know unless you compare them to the old ones. I know some of the arms in my shop are the short ones because I checked a few sets. But some are the old ones too.
VP-Pro USA - www.raceVPpro.com
Agama USA - www.AgamaUSA.com
Maxy's Fuel - www.Maxysfuel.com
Machine's R/C H is offline   Reply With Quote
Old 07-16-2008, 06:00 PM   #1610
I went to the buggy hexes today finally, I put 6 8x11.5 shims behind each hex, am I okay like that?
Old 07-16-2008, 09:14 PM   #1611
chrobar's Avatar
What I did was shim the outside of the hub before the hex in the rear. In the front, I shimmed all the way before the hub, hex, and carrier. They should be the last things on the CVD after the bearings. By doing this, you push the CVD farther into the cup therefor eliminating the problem of the CVDs popping out. Another tip I got from a friend is to use an o ring along with a few shims in the front. I also put some fuel tubing on the shock shafts. I'm doing so much because I want to be sure that I won't have a cvd pop out while on the track. I haven't had any issues so far with the oring..just using shims, I had one pop out after a large jump into the face of another one. All I did was gas it a bit and it was all good. I did add one shim after this, just to be sure. The best thing you can do though is get CEN's new arms. They are probably the best solution. I still run the stock long arms.
CEN Factory Team
Matrix C-1 FRE custom brushless, 2000kV, Orion VDS-2015
GST-E, 1500 kV, Hitec 5955TG
Futaba FASST 3PM
chrobar is offline   Reply With Quote
Old 07-16-2008, 09:41 PM   #1612
Tree's Avatar
Send a message via ICQ to Tree
Change to the buggy axles and there is no need to use shims in the rear. You will need to shim the front with one 8mm washer on each side. You can get the washers at any hardware store.
Team Holy Rollers
HiTec Servos
"N-Tune" Nitro Engine Tuning Dials
Tree is offline   Reply With Quote
Old 07-17-2008, 04:25 AM   #1613
TripleX-JT's Avatar
Send a message via MSN to TripleX-JT
I put buggy axles in front and rear. It is a little costly but what isnt in this sport
Josh Thompson
CEN Racing - GO Tech Engines - UPgrade RC - Northern Hobbies - Khaos Designs
TripleX-JT is offline   Reply With Quote
Old 07-17-2008, 07:32 AM   #1614
I am going to try what I did 1st plus I raised my ride hight a bit and if there is any problems I will let you guys know. Gene actually sold me all those shims and said I needed that many so I belive I will be okay and I think I should be okay. I definetly will let you guys know saturday.
TT MT4G3 all tricked
TTST4G3 MT4ed out
JR servos Hitec servos. Gens ace lipos KO radio.
Old 07-17-2008, 07:37 AM   #1615
Tree's Avatar
What did you use to remove the pin from the front axles? I have tried to push and hammer them out but all I did was damage the axle. Also how did you put the pin back in the truggy cvd? Thanks
Team Holy Rollers
HiTec Servos
Old 07-17-2008, 08:55 AM   #1616
I take mineout every couple weeks to check my bearings and what not but you just got to be patient and keep wacking it. when you get the pin out polish all the gunk off of it thats what I do.
TTST4G3 MT4ed out
Old 07-18-2008, 04:32 AM   #1617
TripleX-JT's Avatar
I used a vise to hold the axle and tapped the pin out. Then took the axle and pin from the buggy and tapped it in to the truggy shaft. It seemed to work just fine. It could of been luck too
Josh Thompson
Old 07-18-2008, 08:25 AM   #1618
Postalmal's Avatar
I need to find a brake/throttle linkage for my TR. Will one from any other manufacturer work or will I need to get the one from Cen? Just asking because my LHS does not support Cen and I need it asap.
Postalmal is offline   Reply With Quote
Old 07-18-2008, 08:41 AM   #1619
Get the sportwerks throttle brake linkage. The 1 with the ball ends on it and 1 silver 1 red and 1 blue adjusters. Just put it on mine yesterday. They have them on ebay for like 8 bux.
TTST4G3 MT4ed out
Old 07-20-2008, 04:23 PM   #1620
So after having went to the 17mm hubs I still had the cvd come out then I was thinking, shim the inside of the front of the truggy and have been fin ever since.
TTST4G3 MT4ed out
cen matrix CHAVAN30 Nitro Off-Road 1177 08-05-2011 05:23 PM
CEN MATRIX FRE helivaguy Nitro Off-Road 4 08-27-2008 05:52 PM
Cen Matrix dieseldog20 R/C Items: Wanted to Buy 0 02-06-2008 05:31 PM
Matrix and Matrix TR Factory Race Edition Kits SmoothB R/C Items: For Sale/Trade 4 05-31-2007 05:36 PM
Dye matrix 5 and DYE matrix 4 w/ tanks and halos for sale yuk17bandit Other Items: For Sale/Trade or Wanted to Buy 0 11-07-2006 10:49 AM
